Ricer
Auto Shifting in Manual Mode
So I just received the lovely engine check light on my A/T FR-S, and whenever I'm in manual mode, it's auto shifting at around 7,100 rpm. Anybody know the reason why or how to fix it?
Thank You, Last edited by phantasticity; 06-14-2016 at 05:54 PM. |
#2 |
CEL disables a lot of stuff, may include flappy paddles.
#3 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
You need to find out what is actually causing your CEL first.....
Either get your own code reader or see if your local auto parts shop will let you use theirs. Once you know what the code is it will be a lot easier to fix the problem..... Just to eliminate the possibility, are you sure that you did not set your rev limiter at 7,100? That might force it to upshift on you even with 100% throttle in manual mode. Probably not a good idea to keep revving it up to 7,100 while you have a CEL as well.....
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
| The Following User Says Thank You to Tectoniic For This Useful Post: | mixtape (06-16-2016) |
#4 | |
Ricer
#5 | |
#FiftyShadesOfBlue
Drives: 2015 FR-S
You and us need to know what code you have so we can try to help. A CEL can pop up from so many different things ranging from your gas cap not being tightened to a rod punching a nice hole in your block. Once you have the code google it as someone has most likely ran into it before and you will probably find out if it is something trivial or something you should be concerned about EDIT: To somewhat amend my earlier post: I have an A/T as well. Even if you set the rev limiter it will just bounce off of it and jerk the car in manual mode so it should not be auto shifting.
| The Following User Says Thank You to Tectoniic For This Useful Post: | Tcoat (06-16-2016) |
#6 |
Drives: 2017 Camaro 1SS
Go to autozone, they will tell you the code for free. Then tell us the code. Or google the code.
#7 |
Ricer
#8 | |
Ricer
#9 |
Off Topic
P0171 is running lean. Do you have any mods on your car such as header, tune, or intake?
#11 |
Drives: '15 Scion Frs Steel
Not to rob the thread but i also have a a/t and when im in manual mode and have the vsc sport on and hit heavy traffic i get a code(dont remeber which one) but its for the cam shaft positioning sensor or something along those lines
Sent from my SGH-T999N using Tapatalk |
#12 | |
Not a troll
#13 |
Drives: frs
#14 |
Contract? /人◕ ‿‿ ◕人\
| Shifting with a manual... | Jen | Scion FR-S / Toyota 86 GT86 General Forum | 110 | 04-22-2014 11:46 PM |
| is it possible to rejigger the auto manual mode shifter to flip gear up/down? | chickdigger802 | BRZ First-Gen (2012+) — General Topics | 14 | 10-18-2013 09:17 PM |
| A Week of A/T Manual Shifting Mode | Ocala FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 98 | 05-15-2013 03:35 AM |
| More MPG in manual mode (AT) | aceangel | BRZ First-Gen (2012+) — General Topics | 11 | 03-27-2013 02:12 PM |
| hard shifting in sport mode AT | sofrsnsokleen | Issues | Warranty | Recalls / TSB | 11 | 12-12-2012 12:13 PM |
