#15 | |
Drives: '13 BRZ Lmtd
[Edit] Well I tried turning everything else off and it made no difference to the GPS failure of the Nav. I completely shut off my phone, I turned Bluetooth off on the head unit, I switched the audio to FM then turned it off: and still no GPS lock with blinking one to three dots for status. I tried with the car off in acc mode while four red reception bars showed steady, then started the car and stopped at a stop sign for three minutes with five red reception bars and never got a lock. I did all this testing in a school parking lot with a good view of the sky. Total testing time: 20 minutes. Total GPS lock: zero. Last edited by DSPographer; 06-19-2012 at 11:25 PM. |
#16 | |
Drives: Ford festiva
[ame="http://www.youtube.com/watch?v=1jVNXQPWQgM&feature=plcp"]http://www.youtube.com/watch?v=1jVNXQPWQgM&feature=plcp[/ame] Turning off bluetooth and xm have no impact. XM and bluetooth otherwise work fine. I would complain that XM signal is a little poor but I don't really care. |
| The Following User Says Thank You to DigDloppyFonkeyBick For This Useful Post: | DSPographer (06-20-2012) |
#17 |
Drives: '05 Outback Wgn, '05 Lotus Elise
subaru stock gps suck! I use the gps on my phone instead. waaaaay more reliable. It is hard to hold it though while I'm driving. There is no right place to put it upright.
#18 |
Here is my example with five unlocked satellites:
[ame="http://www.youtube.com/watch?v=TKX6Mt0a3sE&feature=plcp"]http://www.youtube.com/watch?v=TKX6Mt0a3sE&feature=plcp[/ame] This isn't the only condition where the unit fails to lock. Sometimes it just continuously shows 2 dots on the signal indicator, but the location is still wrong and the status shows GPS off: in that state it doesn't show the spinning satellite icon on the map display so I can't get to the reception page. Last edited by DSPographer; 06-20-2012 at 09:19 AM. |
#19 |
Seasoned Spirit
Drives: 2013 DGM BRZ Premium
My GPS always loses signal when I go through a certain part of my neighborhood which happens to be under some power lines at an intersection. It takes a good five minutes to get a new lock.
#20 |
I've posted in the other thread in the electronics section but just wanted to add the same thoughts.
Mine either has no signal or does what someone else says, it cycles between a strength of 1-3 dots and updates the map erratically with me on a road about 5 miles from my actual location. There is a specific freeway where this happens every time travelling in the south direction, I can't get a good signal at all anywhere. When I change over to another freeway and am headed east, it picks the signal back up and seems fine... I'm hoping this isn't a hardware issue but I will call SOA just to get it documented since it's an obvious issue... I can use a handheld GPS and my phone while in the car and it has no issues. |
#21 |
I did some more investigation. From the Imprezza forum and some experimentation I found out the GPS antenna is under the dash behind the head unit. The roof antenna is just for XM and FM. You can restart the head unit without shutting off the car by pressing and holding the map then the audio buttons. You can enter the head unit service menu by pressing and holding the map, then the voice command, then the audio buttons all together. In the service menu there is a GPS and vehicle sensor status. Looking at the vehicle sensor status it shows the wrong speed as shown below. I wonder if this is part of the problem? (Note: this wrong data on the navigation diagnostic display is from the speedometer sender, not the GPS)
![]() By the way, when the head unit is doing its blinking signal status dance, in the service menu the GPS status is constant with signal levels according to the height, but not color, of the bars on the head unit reception page. Last edited by DSPographer; 07-15-2012 at 05:08 PM. |
#22 |
Good info. I got good lock in 5 minutes this morning on the way to work.
Next time it goes bizerk I'll check the menus on mine. I wonder if we could fashion a gps antenna extension to put it in a better location. |
#23 |
ZC6A2B82KC7J
Drives: 2002 WRX
I wonder if there is something metal in the vent structure that could be blocking the signal?
#24 |
Na-Nu Na-Nu
Drives: 2013 Subaru BRZ Limited (GBS)
I don't want to be that guy but do you think we are having enough issues to actually complain to Subaru about this?
LIMITED 6MT Galaxy Blue Silica
#25 | |
Dear John: Thank you for your message to Subaru of America, Inc. At this point in time, we suggest you arrange to have the navigation system on your 2013 Subaru BRZ inspected by an authorized Subaru dealership. We depend on our dealers to inspect and diagnose concerns with Subaru vehicles. Once we have the results of the dealer's inspection, we can determine how we will help you. We appreciate the opportunity to be of service! Sincerely, Judy York, CDS E-Mail Representative, Subaru of America, Inc. [THREAD ID:1-XFEAB8] -----Original Message----- From: xxxxxxxxx@yahoo.com Sent: 6/20/2012 07:55:30 AM To: CustDlrServices@subaru.com Subject: (SR #:1-2021244595) Vehicle Problem My new BRZ has a problem with the NAV not locking GPS satellites. Other owners on ft86club.com report the same problem. Here is a description of one symptom: http://www.ft86club.com/forums/showt...468#post267468 Note the thread was started by an owner whose dealer changed everything but couldn't fix the problem. |
#26 | |
I've already contacted Subaru NA directly and my dealer is talking to them as well. I paid a premium on the subaru versus the scion to get the headlights and nav. I expect them to work. My nav fails 75+% of the time so I certainly expect this to be corrected. BTW...the response I got back from subie na: Dear MR Floppy: Thank you for your message to Subaru of America, Inc. We are sorry to learn of the difficulties you have experienced with the navigation system on your BRZ. We will research this further and get back to you by the end of the week. We appreciate you taking the time to contact us! Sincerely, Judy York, CDS E-Mail Representative, Subaru of America, Inc. I suggest everyone who has flakiness with their nav to email subaru. More datapoints will help. We're also likely to have better success if you doing a good job describing the symptoms and are polite. For example: "You c*ck suckers need to fix my busted-a$$ get me places box". |
#27 |
ZC6A2B82KC7J
Drives: 2002 WRX
I'm going to my dealer today to get some paperwork so I'll make sure I have the service manager report it.
#28 |
I did some more testing in my case and I found if I waited a few minutes in my driveway for the Nav to get good satellite reception it worked the entire same drive where it previously didn't work. I think it's when I start moving without it first syncing up it has a terrible time ever getting a satellite signal. This time around it never lost signal.
Tomorrow morning I'll try it again just leaving right away and see if it ever gets a good signal. |
| Turn signal lights | Brzer | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 10-18-2012 01:36 PM |
| BRZ signal light bulb | ubersoph | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-20-2012 01:26 AM |
| BRZ Bluetooth issues? | Shizuma | Electronics | Audio | NAV | Infotainment | 3 | 06-13-2012 12:06 AM |
| LED exterior and turn signal conversion | fenton | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-07-2012 11:33 PM |
| Clearance issues? | eriktherod | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 05-31-2012 03:50 PM |
