Old 06-04-2016, 02:56 AM   #7253
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by Scaldy View Post
I joined the Sprintex club this week! I'm super impressed. Really happy with the performance. I'm up here in Vancouver so I just wanted to thank my shop AJR and the tuner, Indy Speed shop.
Congrats! Make sure you check the oil level & intercooler coolant once a month with the rear end jacked up so the charger is level with the ground.
The Following 2 Users Say Thank You to stockysnail For This Useful Post:
brybot (08-15-2016), Chad86 (06-04-2016)
Old 06-06-2016, 06:28 AM   #7254
Rich196
Drives: GT86
Does any one run WMI, Water meth injection with the sprintex?
If you do I assume that you are injecting at the throttle body.
Could you give me an outline of your setup.
Nozzle Size
Size of tank
Mix ratio of water to meth
How many miles you get before the WMI is empty.
When the meth starts to inject.
Rich196 is offline   Reply With Quote
Old 06-06-2016, 06:37 AM   #7255
ajc209
Drives: GT86 Cosworth
Nozzle Size
Size of tank
There's a chap in the UK running water injection. I think fitted by Abbey Motorsports.
ajc209 is offline   Reply With Quote
Old 06-07-2016, 04:37 PM   #7256
sterny331
Drives: 2013 brz limited
for those of you with the kit without the intercooler.. are there any issues with temps? ive heard a mixture of reviews on both kits.. hard to say if the intercooler kit is worth it. also what kind of digital monitoring systems are you running to monitor boost and oil temps?
sterny331 is offline   Reply With Quote
Old 06-07-2016, 04:56 PM   #7257
brianhj
Drives: 2017 Camaro 1SS
I've driven both. I've never tracked so this is purely from a street/daily driver perspective. Mine ran fine without the intercooler as a daily driver, back and forth to work. For track I'd guess you'd definitely need the intercooler but for street, based on my experience, I'd say it's absolutely not required.
Sent from my LG-D851 using Tapatalk
brianhj is offline   Reply With Quote
Old 06-07-2016, 08:13 PM   #7258
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Less power on hot days for sure. Seems to me to mostly be dependant on intake air temp. Heatsoak seems to clear up within seconds. But that's the butt dyno talking.
Intercooler required for smaller pulleys and more boost.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
The Following 3 Users Say Thank You to riboyster For This Useful Post:
Dream20b (06-08-2016), Jeremiahlee34 (06-11-2016), Rifle (06-09-2016)
Old 06-08-2016, 11:05 AM   #7259
sterny331
cool thanks for the prompt responses. i was looking at a brz with the 210 kit. has a 10.5 psi pulley (not sure what size that makes it off the top of my head) no intercooler on the vehicle. seems to have been fine for the past 2 years without it. i dont do any track days but i do a lot of spirited street driving. also the monitoring system for boost and oil temps are just through the phone with a obd2 port plug in and a fancy application. kind of a bummer there are not permanent gauges. but those can always be added. just a little weary of the buying process. i dont want to run into finicky problems constantly day in and day out. and from the research of done it can happen. im decently mechanically inclined so im not afraid to dig into it a bit. but it still needs to be a realistic daily driver that im not under the hood every other day.(it will by my only car). so any more input would be great thanks guys. PS ive owned a brz before.. but it was just uel headers, full exhaust, oft and e85.
Old 06-08-2016, 12:50 PM   #7260
brianhj
As long as the supercharger is installed properly and has a good tune the only reason you would need to be under the hood is to check oil level. Which you should do a on weekly basis or so.
The Following User Says Thank You to brianhj For This Useful Post:
Old 06-08-2016, 12:57 PM   #7261
Dream20b
Y u do dis?
E85 helps keep temps down too, considerably.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 06-08-2016, 01:36 PM   #7262
sterny331
im not talking about basic supercharger maintenance. im just talking about stupid little finicky issues and what not. but yea im sure ill run the e85 map all summer and back to 93 in winter if i even drive it much in winter. im just surprised that theres no intercooler and not an indefinite way to monitor everything without plugging your phone in. if it was mine i would want to be monitoring afrs constantly. and oil temps. and boost. because anything can happen at anytime really... and if something happens and u dont have your phone plugged in you could run into some serious problems
Old 06-08-2016, 05:50 PM   #7263
sterny331
anyways.. has no intercooler, no oil cooler, no catch cans. (i would have at least gone catch cans and oil cooler to stay as safe as possible) also car is on stock clutch... what would u expect to pay for something like this? has full exhaust, headers, intake kit, i guess it makes over 260whp with all of this on e85. not sure what the stock clutch is good to anyway.
Old 06-08-2016, 06:16 PM   #7264
Dream20b
Y u do dis?
I hate to be the pot calling the kettle black, but I wouldn't buy a modified car from someone else, especially not a dealership.
Dat Hot Lava Doe
Old 06-08-2016, 06:16 PM   #7265
Kodename47
Kodename47's Avatar
Drives: UK GT86
@sterny331 monitoring boost isn't really necessary, neither is AFR monitoring that crucial.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-08-2016, 07:45 PM   #7266
Dream20b
Y u do dis?
AKA this is not a turbo.
Dat Hot Lava Doe
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
