#2941 | ||
Drives: '13 FRS - STX
![]() I was lazy so looked where I thought I'd find the fastest answer. The second post in this thread is from Jim Drago on setting up a Spec Miata. "Oh that's not a fast car, what a joke!" Jim Drago hustled his Spec Miata around Laguna Seca in 1:45 to an 86's 1:51 with Pobst behind the wheel. That's a Miata with <130 horsepower and race slicks that are measley 205's, oh and 1/16"-1/8" toe out at the front according to him. http://mazdaracers.com/topic/4636-to...ht-line-speed/ Ultimately setting up a racecar is done to the drivers taste, what works for one guy can be a nightmare for another, you can do whatever the hell you like, but saying shit like this is just downright silly. And I decided to spend another 2 minutes googling and found this: Quote:
In this post there's a spyshot of Raikkonen's test Lotus setup sheet showing 1mm toe out on each front wheel (along with an Arrows setup sheet that agrees): http://f1framework.blogspot.com/2012...car-setup.html I mean, if you know something that Renault F1 team (Edit: the same team that gave Schumacher and Alonso world championships) doesn't that would help a guy like Kimi Raikkonen go faster you could probably make some good money. Last edited by strat61caster; 05-16-2016 at 04:04 PM. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | OkieSnuffBox (05-16-2016), ScionOfHorus (05-16-2016) |
#2942 | |
- Andrew |
#2943 | |
Drives: 2013 Firestorm FR-S
However, in talking with the suspension guy at ZF Race Engineering he said that I should be good to add springs up to 200lbs/in stiffer without needing a revalve.
"Shark_Bait88, the man whos spent the most money modding his stock FR-S and its still stock." -@jdnguyen
#2944 |
First timer...
Does bigger sear bars, end links, and rear lca cause more noise? I'm.getting uhh by noises over smaller bumps like on brick roads. Also, how much do you need to torque the rears of time flex Zs once it's on the car? Thanks. |
#2945 |
Off Topic
For #1, something isn't tightened all the way. Check it all again and you'll probably find the culprit.
| The Following User Says Thank You to gramicci101 For This Useful Post: | BRZHarley (05-27-2016) |
#2946 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#2947 |
Thanks
My last set of tires had more wear on the edge. Got a new set and went for alignment.
I have stock suspension with Front Camber plate and rear LCA. I asked the shop for increased camber and he asked what tires I was running. I am using 200TW street tires, right now AD08R. He said in his experience more than ~2.5 front/2.0 rear on street tires isn't beneficial. He recommended I get some suspension upgrades, at least stiffer springs and if coils he recommended RCE Tarmac 2. The reasoning being even if I increase camber the soft stock suspension is still going to cause edge wear on the tires. Does this sound reasonable? I was hoping not to spend a lot of $ on suspension.
#2948 | |
You're not going to break anything running what you've got, enjoy it, one of the best bangs for the buck imo.
#2949 | |
driving smoother faster
Drives: Sold
I wonder how many track hours it takes to wear out OEM shocks |
#2950 |
Drives: 2015 Ultramarine FR-S MT
I'm wondering the same thing, I currently have 52 track days averaging 2 hrs of on track time per day and still going strong.... When I find out I'll let you know
![]() Not the smoothest track around either...(Harris Hill Road)
Last edited by TEWwild; 05-27-2016 at 07:58 PM. Reason: Added video for reference |
| The Following User Says Thank You to TEWwild For This Useful Post: | dp1 (05-27-2016) |
#2951 | |
Drives: Sold
That's great! Anybody experienced (unexpected) premature OEM shock failure from track use? |
#2952 | |
Drives: '23 BRZ Limited
As a reference. Like everything else, heat is what kills everything. |
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | dp1 (05-28-2016) |
#2953 |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
What's a good STX-ready/ performance minded rear alignment setting? I'm currently running a slight bit of toe-in, and one my RCE yellow springs my rear camber is a bit too droopy (and not even, so I've got a little camber wear on my back right). I'm going to install LCA's soon.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build Ceramic Coated Gruppe-S UEL/OP Konig Hypergrams RS4 200tw Koni Yellows, Eibach Springs Ferodo DS2500's
#2954 | |
Will definitely need around -3 up front. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Keenercarguy (06-05-2016) |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
