Old 06-03-2016, 08:44 PM   #1
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
Loud squeaking coming from trunk area
I keep hearing intermittent squeaking noises coming from somewhre in the trunk area - it happens any time the frame of the car is shifting (i.e. going over bumps or grade changes in a road, etc).
It sounds like a high pitched squeak similar to the sound of foam or rubber rubbing against a smooth surface. It's so loud I hear it over normal volume music.
My first thought was it must be the foam tool holders under the floormat in the back - so I removed them all temporarily. I still hear squeaking.
Next I thought it must be the spare tire rubbing against the metal frame of the car - so I removed the spare temporarily. I still hear squeaking.
Sooner or later I'm going to get desperate enough to have someone else drive the car while I root around the trunk listening for where the noise is coming from.
Has anyone else experienced this noise and found the culprit? I didn't hear this when I bought the car, it started within the last few thousand miles.
treminaor is offline   Reply With Quote
Old 06-03-2016, 08:54 PM   #2
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Maybe your tail light rubbing on the bumper? Try press the rear bumper right below the tail light and see if you can recreate the noise.
Old 06-03-2016, 08:57 PM   #3
treminaor
"DGM BRZ"
treminaor's Avatar
I hear noise from the bumper flexing against the fender but it's not really the noise I've been hearing. No noise from the tail lights when I press.
Also tried pressing on the top of the taillights themselves - they don't move at all.
Old 06-03-2016, 09:02 PM   #4
Sigh-on-Rice
I see. I had squeaking noise from tail light rubbing the bumper after I had the tail light replaced for condensation problem. I thought you had the same problem since I saw your avatar having after market tail light. For me, only driver side was making the noise and not the passenger side. So, I knew it wasn't normal. If it's normal, then both side should make the noise.
Old 06-03-2016, 09:25 PM   #5
treminaor
"DGM BRZ"
treminaor's Avatar
Ha, yeah good catch. I put the lights in myself and made sure I got the bolts nice and tight, so that's probably not the issue although it was a good thing to check. I've been racking my brain trying to think what rubber parts are in the trunk area and I hadn't thought of the light gaskets yet.
Loud clunking underneath driver's side area: suspension, chassis, or wheel related? loading_please_wait Issues | Warranty | Recalls / TSB 4 06-18-2015 04:13 PM
what kind of meets are coming up in the seattle area? slyphen Northwest 8 01-30-2015 04:24 PM
Coming from M.D.going to the Poconose (stroudsburg area)... KslayFRZ NY / NJ / CT / PA 46 05-07-2014 03:12 AM
any meets coming up in the nj area? love 4 boost NY / NJ / CT / PA 22 06-12-2013 10:47 AM
Scion FR-S Coming to Atlanta area fastdrivingjr Scion FR-S / Toyota 86 GT86 General Forum 17 05-17-2012 11:56 PM
