Drives: Frs
Shift Knob not flushed
Hey guys just got a flossy shift knob and it doesn't sit all the way down and there an annoying white strip. Any way I could solve this?
#2 |
Drives: 2016 STI DGM
I think I just kept screwing
![]() That being said, did you use any of the bolts that came with your knob? I did not use any that came with mine.
Subaru STI :![]() |
#3 | |
Also, you can use that small nut/bolt to adjust stop point so the gear pattern or logo is aligned well. |
#4 | |
Drives: Frs
Yeah I screwed the nut all the way down and the knob but when I do it's still misaligned so I'm still stuck. I was thinking of buying the Raceseng reverse lockout to cover the white strip but I don't want to drop 80+$ just to cover it .... |
#5 |
Drives: BRZ. R34 GT-T
I have a red Raceseng reverse lock that I'd be willing to sell for 50$. Maybe 4 months old in near flawless condition.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
#6 |
Not going to lie... I literally used a few small bits of toilet paper stuffed into mine to get it aligned correctly! It did end up covering a lot more of the white that you're showing. I think I can barely see it when trying. I'll try snap a pic tomorrow and if you haven't heard from me by noon hit me up as a reminder to snap a shot of mine.
EDIT: Found link I'd posted in the past of car w/Flossy (Sorry for the big pics). Let me know if that view isn't good enough and I'll get more like at the angle you're showing etc. LINK: http://www.ft86club.com/forums/showp...&postcount=137
Subaru STI :![]() Last edited by Kimsey47; 05-20-2016 at 11:56 PM. Reason: Added link |
#7 |
Drives: Scion FR-S 10 Series #2263
Pretty sure the nut is not the correct type if it's all the way down and the knob is still sitting so high up.
You need a "jam nut" - it is half the height of a regular nut: https://www.belmetric.com/zinc-plain...dkccef7dhn44u1 If that's the nut you have, then there may be something wrong with the threads in your shift knob, it may need to be re-tapped / chased to clean it out. |
#8 |
#9 |
JDM Vaping Stance Nation
Drives: 2013 White
You're gonna need a reverse lockout adapter. My Blox knob came with it but since it sat out in the sun it turned from black to a copper/brownish color.
Here's what I'm referring to.
Clueless
#10 |
If he has a Flossy shorty heavyweight knob, it should screw all the way down, hiding the white part of the reverse lockout. He shouldn't need an adapter.
#11 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
| The Following User Says Thank You to weederr33 For This Useful Post: | Kimsey47 (05-22-2016) |
#12 |
I ran into the same issue when I put on my knob, what I did was just get a stainless nut lockdown and trimmed the plastic slider just below the top of the lockout top. The look came out great and I don't have to get a custom lockout.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#13 | |
#14 |
LMGTFY
Drives: 13 FRS, 91 Miata
Sounds like a bunch of you got the wrong knob.
Thinking you guys got a knob for a car that doesn't have the reverse lockout. |
| SOLD: carbing shift knob infocus shift boot digital camo | toby714 | Interior Parts (Incl. Lighting) | 6 | 07-02-2015 10:33 PM |
| FS: WeatherTech Mats/Shift Knob/Shift Boot/Sunshade (WI) | wgnzlz | Interior Parts (Incl. Lighting) | 8 | 06-09-2014 10:36 PM |
| FS Raceseng 86 AT Shift Knob and Cusco Red SPin Turn Knob | Unidentified | Interior Parts (Incl. Lighting) | 2 | 01-06-2014 10:55 PM |
| Flushed Taillights | R4PT0R-X | Cosmetic Modification (Interior/Exterior/Lighting) | 31 | 09-23-2013 11:16 PM |
