Old 05-19-2016, 10:14 AM   #1
Lorne
Drives: 2013 Subaru BRZ, 1999 Dodge Neon
Early 2013 models have bad tune?
Someone on reddit is claiming that the early 2013 models are problematic due to a problem with the tune (It had to do with hard on/off throttle at WOT), the injector seals would get rekt and eventually the engine would lean out and go boom boom if driven hard.
I'm just wondering if there's any truth to this as my car sees track days and is driven hard once in awhile... It only has 17000KM and if this is a real issue, is there any way to fix it? also, when would the problem start to become evident
Lorne is offline   Reply With Quote
Old 05-19-2016, 11:29 AM   #2
Some light reading for you:
http://www.ft86club.com/forums/showthread.php?t=38397
http://www.ft86club.com/forums/showthread.php?t=36129
http://www.ft86club.com/forums/showthread.php?t=36008
http://forums.anandtech.com/showthread.php?t=2335327
Bonburner (05-20-2016), chaoskaze (05-19-2016), Lorne (05-19-2016)
Old 05-19-2016, 11:32 AM   #3
Please note the last line of the TSB before everybody panics!!!!!
Bonburner (05-20-2016), chaoskaze (05-19-2016), FRSBRZGT86FAN (05-19-2016), GoobyFRS (05-21-2016), kthxbai (05-27-2016), Teseo (05-19-2016)
Old 05-19-2016, 11:49 AM   #4
Lorne
Just went through the threads and I'm not liking what I'm seeing. I shift at similar numbers on the track every so often. I really don't want to have to replace those seals as it looks like the biggest pain in the ass job ever. I'm unsure if an ecutek tune would fix the issue? I see a lot of info here but everyone saying mostly the same thing.
Old 05-19-2016, 11:53 AM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
either OFT or ECUTeck tunes includes fix on this.
The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post:
FRSBRZGT86FAN (05-19-2016), Teseo (05-19-2016)
Old 05-19-2016, 12:03 PM   #6
Keep in mind those are older posts. The later ECU flashes are said to take care of the problem. Yours may even already be flashed to a newer level.
Old 05-19-2016, 12:30 PM   #7
HunterGreene
Hail Magnet
HunterGreene's Avatar
Is this something that would have been done if the car was taken to the dealership for routine maintenance? Wonder if I should schedule my next oil change there and see if I was reflashed or not.
It has priests in it?
Old 05-19-2016, 12:37 PM   #8
Depends on your dealer would be my guess. Mine checks such things but from what I understand they are the exception not the rule when it comes to service departments.
HunterGreene (05-19-2016)
Old 05-19-2016, 01:14 PM   #9
DAEMANO
Time Traveller
@Lorne
As posted above and in countless threads, it's a known issue and a TSB was issued to fix it. Since it's a TSB, go to any dealership (take the TSB # if you want) and they will reflash your ECU. It doesn't have to be a special dealer, any will do it.
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 05-19-2016, 01:27 PM   #10
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
3 years later it really didn't impact that many people, sky was falling on the forums for a few months but most cars have and will survive even with the original early tune. Yup, ECUtek and OFT incorporate the fix but won't help if the seals are already damaged.
Ultimately it's diagnosible and fixable before catastrophic failure occurs.
Originally Posted by DAEMANO View Post
@Lorne
Every dealership I called would not commit to flashing the car, they said they would reflash ONLY if the tech observed idle hunting on a test drive. I decided not to waste my time. It's not always guaranteed.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
FRSBRZGT86FAN (05-19-2016), Lorne (05-19-2016), Tcoat (05-19-2016)
Old 05-19-2016, 01:36 PM   #11
DAEMANO
Time Traveller
@Lorne
I wouldn't let Strat's experience keep you from contacting your local dealer and specifically requesting the re-flash. Especially because the issue is well known and documented.
The Following 4 Users Say Thank You to DAEMANO For This Useful Post:
FRSBRZGT86FAN (05-19-2016), HunterGreene (05-19-2016), Lorne (05-19-2016), strat61caster (05-19-2016)
Old 05-19-2016, 02:53 PM   #12
D18
D18's Avatar
Drives: Scion FR-S (Hot Lava)
To share my experience from driving at the track, I used to notice a hard stutter as the fuel was cut in and out at redline. But with newer OFT tunes it's much smoother. As I hit redline the fuel isn't fully cut and the RPM's just hold there.
On another note, I generally do try to shift around 7k to 7.2k. Don't like hitting redline, but sometimes your focus is elsewhere!
D18 is offline   Reply With Quote
The Following 2 Users Say Thank You to D18 For This Useful Post:
Bonburner (05-20-2016), Tcoat (05-19-2016)
Old 05-19-2016, 05:34 PM   #13
Lorne
I just got back from the dealership and while they did reflash the car, I'm unsure if the issue was resolved... On the paperwork it said "idle control and emissions". I plan on getting the ecutek or OFT in the near future anyway so until then, I will just have to take it easy on the car (gonna be hard). Thanks everyone!
The Following 2 Users Say Thank You to Lorne For This Useful Post:
DAEMANO (05-19-2016), JEFFSTYLE (05-31-2016)
Old 05-19-2016, 05:38 PM   #14
strat61caster
That sounds correct, the TSB (I believe it is linked above) made no mention of the change with respect to the DI seals and tables it altered and was described as being a change to the idle and emissions settings.
Probably a move pushed out of fear of it being used as a legitimization of track and autocross usage for the car by Toyota USA.
ineedyourdiddly
are there any differences in frs models 2013, 2014 ans 2015? Stratoside Scion FR-S / Toyota 86 GT86 General Forum 24 01-30-2016 07:04 PM
2014 vs 2013 models Rocketman1 BRZ First-Gen (2012+) — General Topics 26 01-05-2014 03:26 AM
Do the 2013 and 2014 FRS models have the same engines? Turbo_FRS Scion FR-S / Toyota 86 GT86 General Forum 83 12-16-2013 12:36 AM
**New 2013 XXR 531 & 535**OZ Racing Formula**2013 Enkei**Unique New Models JoeBoxer Wheels and Tires 49 04-04-2013 06:28 AM
2013 Porsche Boxer is revealed early DIG1992 Other Vehicles & General Automotive Discussions 62 09-05-2012 01:26 PM
