Old 05-17-2016, 03:45 PM   #1
KDad2
KDad2's Avatar
Drives: 2013 Raven
Stalled while driving
First time this ever happened... I had just exited the freeway this morning on the way to work and my car lost power while driving. It seemed like it wasn't getting any fuel. It downshifted several times while in manual mode as it was just crawling along at this point. Each time I pressed on the gas, nothing would happen and my speed kept decreasing. I was able to pull over into an empty drive then it just shut down abruptly as I was slowing to a stop. This all happened fairly quickly. I still had electrical power even though it stalled. After a few tries I got it running again and it acted like nothing ever happened. I took it easy the rest of the way by keeping the RPMs low. Thank goodness it started up again as I wasn't in the best area of town.
Here is my setup: 2012 (Typo… 2013) AT FRS bought new [in 2012] and now has 30k miles, drop in filter, intake tube, Invidia N1 catback, OFT, and replaced the battery a few months ago. I'll plug in my OFT this evening when I get home and see if it throws any codes. I did check to see if it would start a few minutes ago and all sounded good.
KDad2 is offline   Reply With Quote
Old 05-17-2016, 04:32 PM   #2
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
last time that happened to me intake was disconnected (yours may be coming loose at some spot and causing the issue). check your fittings
fumanchu1 is offline   Reply With Quote
Old 05-17-2016, 04:36 PM   #3
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
Drives: Series.Hyperblue BRZ
2012 frs? They had those?
hypebrz is offline   Reply With Quote
Old 05-17-2016, 04:36 PM   #4
KDad2
KDad2's Avatar
Drives: 2013 Raven
Thanks, I sure will check that out before driving home.
Old 05-17-2016, 04:41 PM   #5
KDad2
KDad2's Avatar
Drives: 2013 Raven
Ha! Yeah, didn't you know... Good catch on my typo... 2013, purchased in 2012.
Nice build. The spoiler looks good.
I'm hoping that I can make it to the Twisted Sisters route this summer.
The Following User Says Thank You to KDad2 For This Useful Post:
hypebrz (05-17-2016)
Old 05-17-2016, 05:03 PM   #6
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
Lol I didn't know it was a typo, thanks man!
Old 05-17-2016, 08:41 PM   #7
Had you recently filled up with gas ...... ??
(back-in-the-day .... I would have called it vapor lock.)
Tcoat (05-17-2016), Ultramaroon (05-17-2016)
Old 05-17-2016, 08:53 PM   #8
No CEL?
Old 05-17-2016, 10:14 PM   #9
Did you smell fuel in the cabin?
Old 05-17-2016, 11:48 PM   #10
KDad2
KDad2's Avatar
Drives: 2013 Raven
Nope. Quarter tank left.
No CEL?
Nothing showed up that I can recall. But, I may not of even noticed as i was in heavy traffic and was quickly looking for a place to pull over. Second thought was to make sure my S&W was ready. Ha!
Also, no ECU codes displayed on OFT.
No fuel smell.
One side of the intake tube clamp was a little loose. But, not much. The tube was still snug and in proper alignment. So I tightened it up about 1/2 maybe 3/4 of a turn before heading home. This could of been the issue as I tested the acceleration well. No problems.
Thanks everyone. I'll see how it does tomorrow and chime back in.
Tcoat (05-18-2016)
Old 05-18-2016, 12:19 AM   #11
Well, I wouldn't put your S&W away just yet.
I don't see how the intake "sucking a little air" past the MAF, would stop the engine from running ...... ??
Ultramaroon (05-18-2016)
Old 05-18-2016, 12:50 AM   #12
I'm also going to say that's not it.
Mine mysteriously died once but the circumstances were quite different. That's why I asked about the fuel smell.
Staying tuned.
KDad2 (05-18-2016)
Old 05-18-2016, 06:05 AM   #13
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Get an OBD2 reader and the Torque app. then you can watch the fuel rail pressure in case this happens again. There a LOT of things that can cause a car to stall out and Torque can help you watch a lot of things and get a better idea of what system failed. Fuel comes to mind first, but that's a guess.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
KDad2 (05-18-2016)
Old 05-18-2016, 09:31 AM   #14
KDad2
KDad2's Avatar
Drives: 2013 Raven
Just ordered on Amazon Prime the ieGeek WiFi Wireless OBD-II Mini ELM327 OBD2. Also got the Ultra Flat Low Profile Extension Cable. I always wanted to get one for my OFT. Should be here Friday.
So I was just driving along and WTF! Respect BRZ BRZ First-Gen (2012+) — General Topics 10 05-06-2016 03:12 PM
Driving on PCH through Big Sur was so fun wrb Northern California 4 12-02-2013 10:46 PM
Driving section - actually driving the things somewhere bcj Site Announcements / Questions / Issues 6 04-08-2013 11:28 AM
Driving too much! F3dzo Scion FR-S / Toyota 86 GT86 General Forum 15 07-15-2012 01:14 AM
Forum seems to have stalled... Dimman Scion FR-S / Toyota 86 GT86 General Forum 27 07-23-2010 05:08 AM
