Old 05-14-2016, 02:27 PM   #1
kev60625
Drives: 2013 WRB Subaru BRZ
Safe to drive with 17mm endlink/strut bolt not fully tight?
Hello, I feel like a complete noob and bad for this! So I was trying to install new springs and once I tried to remove the bolt that holds the swaybar endlink and strut (17mm bolt), I couldn't get it out. I used an allen key to hold the endlink and then used my socket, unfortunately I think the allen key came out a little and after a while of turning, only the top part of the bolt was "loose" and had a gap, while the bottom of the bolt is flush. If I stick the allen key in and move it around, I can get it flush on whichever side I want..I have decided to let a pro do it, but will I be okay to drive with like this for a little while? Really hoping I didn't damage the bolt or endlink as well...
kev60625 is offline   Reply With Quote
Old 05-14-2016, 02:40 PM   #2
swarb
Why not tighten it and let the pro finish the job?
Old 05-14-2016, 02:41 PM   #3
kev60625
I've tried for sure. Just doesn't move now
Old 05-14-2016, 02:52 PM   #4
swarb
What do you mean by bolt? The endlinks have nuts to secure them.
You are ok to drive on it, as I have on loose endlinks. They will make clicking sounds. Handling might be compromised so be careful.
Also some heat from a torch would make it easier to loosen.
The Following User Says Thank You to swarb For This Useful Post:
kev60625 (05-14-2016)
Old 05-14-2016, 03:29 PM   #5
kev60625
Nut is what I meant. Thank you for letting me know its safe, I will def take it easy in the meantime
Old 05-14-2016, 03:57 PM   #6
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
You can safely drive with the sway bars completely disconnected.
crazyfrenchbiker is offline   Reply With Quote
Old 05-14-2016, 06:18 PM   #7
kev60625
Drove to work and there's so much clunk going on. Feels so sketchy
Old 05-15-2016, 01:56 PM   #8
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
One of my endlinks is broken so yeah, I get a lot of clunking when driving over small and medium sized bumps.
Lynxis is offline   Reply With Quote
Old 05-16-2016, 03:51 PM   #9
kev60625
So i ended up going at it again. Trick was to push the end link top part inward, towards me, while holding the Allen key in and tightening the nut. Was a little trickery without help, but I got it back on tight
Old 05-17-2016, 04:23 AM   #10
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Get it fix ASAP. The longer you drive the more can go wrong. Might even infect other parts lol....
Than the heart break wallet killer begins
turtlefeeder is offline   Reply With Quote
Is car safe to drive with low Advance Multiplier? 86fun Software Tuning 19 02-06-2016 06:17 PM
Drive Safe! anishb Mid-Atlantic 9 02-18-2015 01:31 AM
Drive Safe Everyone! iRep8OH8 Hawaii 1 03-02-2014 06:41 PM
strut brace bolt snapped-need help frs10 Issues | Warranty | Recalls / TSB 9 10-20-2013 02:29 AM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 01:19 PM
