Old 05-08-2016, 01:48 PM   #15
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Originally Posted by billwot View Post
Look at the equation...an increase in torque will result in an increase in HP at any RPM. It's a mathematical certainty.
I meant that an increase of torque does not mean that the maximum hp (which people usually refer to as it is published) will necessarily increase. In cases I mentioned it may remain the same or even decrease.
mdm is offline   Reply With Quote
The Following User Says Thank You to mdm For This Useful Post:
themadscientist (05-08-2016)
Old 05-08-2016, 01:55 PM   #16
Celica00
Celica00's Avatar
Drives: 86
So higher HP throughout the powerband but not more maximum HP necessarily?
Celica00 is offline   Reply With Quote
Old 05-08-2016, 02:14 PM   #17
mdm
not a twin owner
mdm's Avatar
Here is an example. Imagine an engine that has exactly 150 lbft from 1000 to 7000 rpm and revs up to 7000. (I know no engine is exactly like that, it's a simplified example to demonstrate the idea). The hp is 29 @ 1000 rpm, 86@3000, 143@5000 and 200@7000. Max hp is 200.
Now we increase torque to 200 lbft but only in the low rpm range. Eg. 200 lbft from 1000 to 3000, 180@4000, 160@ 5000 and 150 above that. The hp is now 38@1000, 114@3000, 152@5000 and still 200@7000. So while max torque increased to 200 lbft, max hp is still 200.
Another example: we increase torque to 170 lbft across the rpm range, but now the engine can only rev to 6000. Power is now 32hp@1000, 97@3000, 162@5000 and 194@6000. And that's the maximum hp now, 194 with 170 lbft max torque.
Lynxis (05-09-2016)
Old 05-08-2016, 03:03 PM   #18
VTEC
Drives: Scion FR-S
Originally Posted by Doubletap View Post
I'd rather have more torque. The HP on this car is fine.
Agree. I find this engine quite peppy between 4500 and 7400 RPM. But getting this car off the line quickly needs a fairly aggressive release of the clutch and traction control turned off
Instagram: @racecar_4life
VTEC is offline   Reply With Quote
The Following User Says Thank You to VTEC For This Useful Post:
Old 05-08-2016, 03:35 PM   #19
Teseo
Drives: frs
I want more "aggresive" wheels and aeoro-kit.
Old 05-08-2016, 04:46 PM   #20
Give it 50 more and you will still hear "but the XXXX sedan has 50 more" and "this car needs anther 200 to keep up with the YYYY".
What I would do with 50 more is probably nothing. I can already be above any speed limit in between 3 and 7 seconds (without bouncing off the rev limiter or even going to 7k). I do not need to trim .2 seconds off my time from stop light or the traffic in front of me.
The Following 9 Users Say Thank You to Tcoat For This Useful Post:
Cole (05-09-2016), El Guapo (05-09-2016), Hoahao (05-11-2016), humfrz (05-09-2016), JD001 (05-08-2016), mdm (05-08-2016), Mim (05-09-2016), Mr.Impreza (05-09-2016), Spacemane969 (05-10-2016)
Old 05-08-2016, 05:12 PM   #21
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
billwot is offline   Reply With Quote
The Following 2 Users Say Thank You to billwot For This Useful Post:
Lynxis (05-09-2016), mdm (05-08-2016)
Old 05-08-2016, 05:21 PM   #22
seito23
Drives: Corn Juice junkie
I would take the extra 50bhp and stick it in trunk saving it for a rainy day.
I see what you did there
seito23 is offline   Reply With Quote
The Following User Says Thank You to seito23 For This Useful Post:
JD001 (05-09-2016)
Old 05-08-2016, 09:11 PM   #23
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
250hp would be better, but as so has astutely been pointed out, low end grunt would be much more beneficial. Being able to accelerate stronger out of corners and sprint better to the next one would really hone the working edge of this car into a sharper weapon. As it sits it will do 100mph in fourth, I have no speed complaints, just acceleration ones and that's a torque problem.
I know when it lays down between 3500 and 4500 I think, "man, feel that fuel economy!"
The Following User Says Thank You to themadscientist For This Useful Post:
MarcFr-s (05-08-2016)
Old 05-08-2016, 09:56 PM   #24
airjonny
airjonny's Avatar
Drives: Nissan Murano
Fast car Fast> Slow car Fast > Fast car Slow
airjonny is offline   Reply With Quote
The Following 2 Users Say Thank You to airjonny For This Useful Post:
Tcoat (05-08-2016), themadscientist (05-08-2016)
Old 05-08-2016, 10:18 PM   #25
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
So to answer the OP, with 50% more horsepower I would use it to trash the stock components of the car that weren't design to support an output of 300hp.
krayzie is offline   Reply With Quote
Old 05-09-2016, 01:19 AM   #26
themadscientist
Hotlink Terrorist
Old 05-09-2016, 01:56 AM   #27
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
Or you could just upgrade your diff ratio, add Crawford power blocks and call it a day.
This would speed up every gear and move the entire power band down a few hundred RPM. This is assuming you are staying NA and just want to improve DD drivability. Depending on the FD ratio I'd imagine this combo would (seat of the pants wise) get you pretty damn close to the feeling of having those 50 extra ponies.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
The Following User Says Thank You to Mim For This Useful Post:
themadscientist (05-09-2016)
Old 05-09-2016, 02:25 AM   #28
themadscientist
Hotlink Terrorist
If it's destined for the twisties or autocross, this might be a great trick.
Horsepower Chase1996 Engine, Exhaust, Transmission 32 03-08-2016 11:26 PM
Who says we need more horsepower? LeeMaster Scion FR-S / Toyota 86 GT86 General Forum 36 01-11-2013 12:05 PM
Bolt on 6 horsepower for about $50. MillersOilsUS Engine, Exhaust, Bolt-Ons 29 01-10-2013 09:53 PM
6 horsepower, 4 lb-ft from an oil change MillersOilsUS Mechanical Maintenance and Tools 1 01-03-2013 12:21 PM
ft86.com has some serious horsepower! MrBRZ Off-Topic Lounge [WARNING: NO POLITICS] 2 03-22-2012 08:45 PM
