Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 05-05-2016, 03:14 AM   #561
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Phew, thanks for your kind words.
I thought Sunday was anything but smooth.
I tried with nannies off, in sport mode, with nannies fully on, I tried aggressive, I tried gentle and smooth and all of that amounted to was a negligable 0.1 sec diff
I've actually got video of powersliding T5 (the 180° hairpin) with the nannies fully on. I had so little grip that even with the power stifled by the nannies, there was still enough to powerslide - LOL.
What did work well was using higher gears to reduce power and torque, and make throttle inputs less sensitive - like using 3rd thru the chicane and the central section.
Originally Posted by FT_86_SM_GP View Post
What do you intend on doing to get more negative camber at the front?
(Coilovers ? just trying to figure out what one could do while keeping suspension relatively stock)
No coilovers. It's a fun car and a daily (sometimes) for Lindy and I who enjoy just driving it, and harder suspension would spoil that. I'm going to have the struts slightly slotted. Discussed the plan with my sponsor yesterday, and they'll do it for me before the Pets event which will be a good test building up to Mich Cup at RSR.
I use Toyo R888's,
I chose them because they were affordable Approx R1200 each for 16inch, and they are legal road tyres.
I'm going to experiment with a variety of road-legal semis, and R888 is one that's on my list. My sponsor has also located a set of Yoko AD08's in 235/40R17 which I'm going to test too.
Fish Eagle is offline   Reply With Quote
Old 05-05-2016, 04:09 AM   #562
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Coilovers doesn't necessarily mean harder, that would be a function of the spring rates(which you can specify, with valving to suit). It would give you much more adjustability in terms of camber, ride height and damping.
Else simply get camber plates.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
The Following User Says Thank You to sav For This Useful Post:
Fish Eagle (05-05-2016)
Old 05-05-2016, 04:28 AM   #563
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Thanks.
What do camber plates cost nowdays?
Old 05-05-2016, 04:52 AM   #564
sav
sav's Avatar
Originally Posted by Fish Eagle View Post
Thanks.
http://www.ebay.com/itm/MK1-Adjustab...VSAeK3&vxp=mtr
Maybe Ryan can organize cheaper?
95RON SAV Tuned
Old 05-05-2016, 05:34 AM   #565
steve99
Drives: FT86
Thanks.
or if your still on stock struts you can get about -1.5 with these
http://m.ebay.com.au/itm/SALE-WHITEL...638?nav=SEARCH
Old 05-05-2016, 05:42 AM   #566
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Thanks, I've already got -1.5° with OEM crash bolts.
I need to go to -2.5°
Old 05-05-2016, 07:09 AM   #567
sav
sav's Avatar
That's what I'm running - can get a bit more than with the Toyota crush bolts but not worth the price considering Toyota wants about AU$4 each for them.
I've bought them because Toyota didn't have stock at the time.
95RON SAV Tuned
Old 05-21-2016, 06:21 AM   #568
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Well, after 3+ years, 75000 kms, and 30 track days, I've had my second failure - clutch thrust bearing seized. (First failure was a cracked header, which I had welded up 6 mths ago, and it's still OK)
I have no idea why the thrust bearing failed, but I'd resigned myself to probably also replacing clutch plate and pressure plate while it was out. The good news is that my clutch plate and pressure plate look great, and they're going back as is. Recently someone said that you have to upgrade clutch if you go FI - this is proof that you don't. I believe that the real clutch killers are drag racing and gymkhanas - which I don't do.
Old 05-21-2016, 06:32 AM   #569
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Regarding buying parts...
The thrust bearing is the second example I've had where I've compared prices between Toyota and Subaru, and again Subaru came out tops, by far.
Imperial Toyoya Nelspruit quoted Toyota list price.
NTT Toyota Barberton (my dealer) quoted Toyota list -20%
Subaru Nelspruit came out at 17.5% less than NTT Bton
We're lucky to have the choice of supply channel, and the price differences are substantial, so always get a quote from both.
Old 05-21-2016, 12:16 PM   #570
sav
sav's Avatar
Cool, yeah mine also recently failed. bearing and clutch replaced under warranty. Plate was also still looking good but they said they've replaced it anyway while the box was out because the springs were a little bit rattly.
95RON SAV Tuned
Fish Eagle (05-21-2016)
Old 05-22-2016, 04:33 AM   #571
LostSalad
Drives: Toyota 86 - Charcoal Grey
@Fish Eagle what were the symptoms of the failure? Was it gradual or sudden?
LostSalad is offline   Reply With Quote
Old 05-22-2016, 05:11 AM   #572
Fish Eagle
Platinum Member
Fish Eagle's Avatar
It was quick. One day I could just make out a very faint noise, the next day it was screeching terribly. But it did get me home (40kms) and to the workshop (another 10kms) without total failure, and with hardly any damage to the fingers of the pressure plate. After it seized, it was sliding against the PP fingers.
I don't think that FI or racing contributed to failure. Normally thrust bearing failure come from lightly resting one's foot on the clutch a lot, which I don't. So I dunno, but I'm not hassled either way.
Old 05-22-2016, 04:20 PM   #573
FT_86_SM_GP
FT_86_SM_GP's Avatar
Drives: Lawn moweR
Thank you for the detail and pics @Fish Eagle,
I have been noticing loud clutch noises for 2 months now,
Took it to Toyota and they greased a few parts (I think one of them was a spring).
Toyota didn't know what else to do, the noise came back in 2 days of driving.
I hope it does not lead to any failures,
I read up on this thread, but there does not seem to be any solution, other than getting your clutch replaced (Or in your case, the part replaced).
http://www.ft86club.com/forums/showthread.php?t=56882
FT_86_SM_GP is offline   Reply With Quote
Old 05-23-2016, 02:49 AM   #574
Fish Eagle
Platinum Member
Fish Eagle's Avatar
The sound in those videos says linkage to me. It's not relative to rotation of the clutch, so I'd rule out clutch plate, pressure plate and thrust bearing.
Very different to the noises mine made.
If I had that noise, I'd lube everything to do with the pedal and linkages with Q20 or Tool-in-a-Can, but that's guesswork.
Anyone know a good detailer in south florida? Red FRS Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 08-27-2013 08:12 AM
Good service advisor in LA area (South Bay)? 96z2 Southern California 0 08-30-2012 12:58 AM
FRS / BRZ in Seatle to show to South African Enthusiast? RudiG Northwest 9 06-22-2012 04:59 AM
Looking for a good Dealership in the South Bay! MrWyatt Southern California 2 05-08-2012 07:25 AM
