#15 | |
#16 |
Drives: rusty
yeah, the your dyno operator used 4th which helps "soften the curve" and stops the low end "loop", and i i can tell that its not a 16sec pull like the purple one posted, more like a 9-10sec, the hump at 5k is a tell tale.
The lower the power on a long pull (higher gears) the larger the peaks and troughs. That dyno is also in an odd mode looking at the results, std cars pull 140 to 145hp all day everyday on all dynos regardless of brand here. The sheet you posted at 165hp is quite a way off what we see here std. this perrin one looks to be in the same mode (it is very old firmware by the looks too) Last edited by CHEQUERED; 05-03-2016 at 03:21 AM. |
#17 | |
#18 |
I think there is some kind of Aussie dyno coefficient that reads 15-20% lower than US dynos, even for the same make/model of dyno. It's the same story with WRX/STis as well, their dynos almost always read lower than ours.
#19 |
Drives: FT86
yep queensland dynos
autos about 5 kw less than manuals stock car about 105-110kw headers tune exhaust on petrol arround 120-125kw headers tune exhaust on E85 arround 135-140kw bigger jump between our petrol and e85 as our 98 ron is not as good as usa 93 aki for some reason some new south wales dynos seem to be calibrated higher by 10% or so |
#20 |
Drives: Toyota 86 2013, Pegasus White
I had my CS400 installed and tuned last night by IXA Battle Garage in Sydney. Other mods include Greedy intake snorkel, drop in filter , HKS dual Res front pipe and Fujitsubo Authorise R Cat back. I am very impressed so far, it puts a smile on your face.
My initial thoughts: The pull down low starts around 3k and picks up after 4 pulling hard to around 6-6.5. The power definitely plateaus after 6 as expected from these headers. The headers and tune make a huge difference to the torque delivery and it now breaks traction where it once would not. Comparing this to the tuners BRZ with an Ace 250B (and other supporting mods) you really notice the difference in torque and the spread of power. The 250B just keeps on pulling up high where the CS400 drops off. Thanks to the Guys at IXA Battle Garage, Hawk77FT and Ace. Look forward to getting out for more of a drive and a dyno run to compare to other setups. |
| The Following 5 Users Say Thank You to michiale For This Useful Post: | AceHeader-MT (05-04-2016), Cop (05-05-2016), CSG Mike (05-04-2016), DAEMANO (05-05-2016), Trust86 (05-04-2016) |
#21 | |
Drives: rusty
| The Following User Says Thank You to CHEQUERED For This Useful Post: | DAEMANO (05-05-2016) |
#22 | |
Drives: rusty
My new engine lost 80 or more on the flight over... im trying to win them back with our cnc itbs. Last edited by CHEQUERED; 05-05-2016 at 01:57 AM. |
#23 |
Drives: runs&drives
haha shots fired
good info |
#24 |
Drives: 2013 satin white brz limited
Thanks for chiming in and clearing things up
#25 |
Drives: 2013 Black FR-S
| OTS vs. custom tune | unsurety | Software Tuning | 10 | 06-25-2015 08:44 PM |
| - 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune | aaronsadventures | Member's Car Journals | 6 | 12-04-2014 03:01 AM |
| Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 09:15 PM |
| Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 11:34 PM |
| My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 01:20 PM |
