Old 04-30-2016, 10:49 AM   #15
axelo
Drives: Whiteout frs
My panasonic battery lasted exactly 3 years...do what tcoat suggested
axelo is offline   Reply With Quote
Old 04-30-2016, 12:49 PM   #16
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
You guys know that you need to regularly add distilled water into our battery right?
Muaddib is offline   Reply With Quote
The Following 2 Users Say Thank You to Muaddib For This Useful Post:
FRSBRZGT86FAN (04-30-2016), Tcoat (04-30-2016)
Old 04-30-2016, 03:17 PM   #17
Where did @sftateofmind run off to ....... to buy a starter......
@sftateofmind just check your car's battery. Here's how:
http://www.aa1car.com/library/battery_runs_down.htm
OR
take it into a shop for them to check.
So, we can put this thread out of it's misery ......
sftateofmind (01-06-2023)
Old 04-30-2016, 05:41 PM   #18
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by BRZnut View Post
Not to hijack the thread but since we are on a battery discussion I'm looking to replace my original 2013 Panasonic before the next winter. Any good suggestions? I use to go to Red Tops but that was years ago.
Optima red tops are still the way to go, don't have to worry about distilled water or anything and its a truly maintenance free battery. Also the CCA are almost double the stock panasonic battery so you won't have excessive drains and such.
Old 05-01-2016, 12:25 AM   #19
BRZnut
Drives: BRZ DGM Limited
Thanks...I have had great luck with them in the past and they seen to last for years. Will likely go that route again.
Old 05-01-2016, 10:21 AM   #20
momoPike
Drives: Toyota 86 High 6MT - Pearl White
My car was doing the same. It's the battery.
Bought one today. Fixed.
momoPike is offline   Reply With Quote
Old 05-01-2016, 11:13 AM   #21
BRZnut
Originally Posted by sftateofmind View Post
Hello. I've been unable to drive my baby due to my issue detailed here. I believe that I may need a new starter. Wanted to know if anyone had the correct part/location for me to order.
Still open to figuring out what the hell is going on with my car. Coils were another option for what may be causing it not to start.
Here is what I would do..make sure your OEM battery is not low on distilled water. If so, add it to the bottom of the filler plugs. Then get a jump but after connecting the jumper cables, let the other car run for 3-4 min while connected. Then try to start your car.
The only thing that worries be about your story is the knock you heard when it died. Hopefully not a major engine issues.
Old 05-02-2016, 07:19 PM   #22
FRSBRZGT86FAN
Important note if you are going to fill the batteries and not replace them with maintenance free AGM batteries, you should really only use distilled water if you want the battery to last that much longer
Old 07-20-2016, 10:52 PM   #23
sftateofmind
Evening Primrose
sftateofmind's Avatar
Engine actually died. Should be getting a replacement soon.
sftateofmind is offline   Reply With Quote
Old 07-20-2016, 11:39 PM   #24
BRZnut
Thanks for posting a follow up but would love to hear more details!
How did you come to that conclusion? What exactly is the issue? Are you stock or modified?? (ie boosted?) Is this another case of oil starvation failure? Dealer picking up the cost??
Old 07-21-2016, 05:55 PM   #25
sftateofmind
Evening Primrose
Took it into a shop around here and the guy ran some test. There is a terrible knock from inside the engine and he believes it is dead. I'm considering sending it some where else to have a look as well but that was the diagnoses. He thinks something inside has gone astray.
I'm stock by the way. Could be an oil starvation issue, but I was within milage for my next oil change and none of my lights came on.
Old 07-21-2016, 11:12 PM   #26
BRZnut
Sorry to hear. From what I understand the oil starvation issue and subsequent engine death can happen even with normal oil levels. Some have suspected it is from too much sealant in the engine from the factory blocking proper oil flow.
If you ever get an engine tear down/ rebuild, let us know what they find inside.
Good luck!
Replacement Part assistance! Crackseed Hawaii 6 12-31-2014 04:49 PM
Part number for the starter button surround Surok Cosmetic Modification (Interior/Exterior/Lighting) 6 12-13-2014 09:38 AM
Lost a Taillight Nut; Part Number/Replacement? titleistforged Cosmetic Modification (Interior/Exterior/Lighting) 3 10-30-2014 06:55 PM
FRS 2014 not 2013 Same Bypass for Starter? Mikeez Electronics | Audio | NAV | Infotainment 0 04-10-2014 11:59 AM
Do these look correct for our car? 9005 Replacement BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 1 06-24-2013 12:15 PM
