Old 05-02-2016, 02:35 PM   #1
NOHOME
Drives: RAVEN
Fram Air Filter...Is it me or what?
Pretty easy task to change an air filter. Tried to toss in a new Fram air filter and 45 minutes later had to give up and put the old one back in.
There a trick to this? Dont buy Fram products?
NOHOME is offline   Reply With Quote
Old 05-02-2016, 02:37 PM   #2
What didn't work about it? Never tried Fram but my TRD one is about a 3 minute operation to pull and replace (after cleaning not new one)
Old 05-02-2016, 02:38 PM   #3
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
I'm not sure what the FRAM filter looks like, however the APEXi filter that I dropped in the airbox didn't just fall in as I expected it would. I did have to wrestle it a bit. It's just a tight fit, and it takes some patience. Take a break and take another crack at it.
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
The Following 2 Users Say Thank You to LOLS2K For This Useful Post:
nickmerronesucks (05-02-2016), NyC Zn6 (05-02-2016)
Old 05-02-2016, 02:39 PM   #4
Atticus808
Atticus808's Avatar
Drives: Splash Mountain
i unbolted 3 bolts and it made the job a lot easier
here's the link http://www.ft86club.com/forums/showthread.php?t=34343
Atticus808 is offline   Reply With Quote
The Following User Says Thank You to Atticus808 For This Useful Post:
NOHOME (05-02-2016)
Old 05-02-2016, 02:44 PM   #5
extrashaky
Drives: 2014 BRZ Limited
BINGO!
Fram products are cheap garbage with bad quality control. I wouldn't run anything they make in any of my vehicles. In fact, the warranty on the crate stroker in my Jeep specifically states that warranty work will be denied if I run a Fram oil filter because they are known to collapse and starve the engine of oil.
They make cheap crap for people who don't know any better and are just looking for the lowest price. Stick with a quality brand instead.
The Following User Says Thank You to extrashaky For This Useful Post:
FRSBRZGT86FAN (05-02-2016)
Old 05-02-2016, 02:52 PM   #6
Maybe you are trying to put it in upside down and/or backwards....... ??
Are you sure it's the right one .. ?? (CA9482) .. ??
Old 05-02-2016, 02:57 PM   #7
mpross
mpross's Avatar
Drives: 2015 Scion FRS
My k&n was kind of similar. It didn't take 45 minutes, but it did take a few times standing back and looking at it to figure out why I had to wrestle it in there... But +1 on the don't buy fram thing.
Sent from my SAMSUNG-SM-G928A using Tapatalk
mpross is offline   Reply With Quote
Old 05-02-2016, 03:05 PM   #8
NOHOME
Drives: RAVEN
It is kind of hard to screw up because there is a unique corner to the filter.
Sure looks different than the factory part.
Think I will just pick up a filter at Toyota. The 30 bucks of so that Canadian Tire charged me is not worth how aggravated I will be if I waste another half hour and don't get the thing in. Don't buy Fram. I knew that for oil filters.
Old 05-02-2016, 03:11 PM   #9
Spend the extra and get the TRD one (Toyotatown does not stock them though) you will not regret it.
Old 05-02-2016, 03:15 PM   #10
Cole
Not a troll
Cole's Avatar
Basically any aftermarket one. Most are nearly identical. Pick the company/colours you want and go from there. I got an HKS cause I'm too cheap to buy any of their other stuff, plus it's lime green.
Cole is offline   Reply With Quote
The Following 3 Users Say Thank You to Cole For This Useful Post:
nickmerronesucks (05-02-2016), soulreapersteve (05-02-2016), Tcoat (05-02-2016)
Old 05-02-2016, 03:16 PM   #11
Or that ^ yes!
Cole (05-02-2016)
Old 05-02-2016, 04:35 PM   #12
Riftur
Riftur's Avatar
My K&N took less than 5 mins to put in.
Riftur is offline   Reply With Quote
Old 05-02-2016, 04:39 PM   #13
Riftur
Riftur's Avatar
Didn't I read something about HKS air filters disintegrating? I am not sure if it was a certain one or what.
Old 05-02-2016, 04:40 PM   #14
Cole
Not a troll
Cole's Avatar
I don't think so
SOLD: LED lights, Stivo duckbill, clear corners, engraved plate fram CaptainSlow Exterior Parts (Aero, Lighting, Etc.) 16 12-18-2015 02:59 PM
Cusco Oil Filter or Blitz Oil Filter Mr.Impreza CANADA 6 10-11-2014 08:08 AM
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 10:28 PM
FRAM CA9482 Airfilter louder? Pake1 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 01-19-2013 08:55 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 03:40 PM
