Old 06-12-2012, 02:11 PM   #85
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
NICE! now someone start tuning! lol
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline
Old 06-12-2012, 04:19 PM   #86
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Originally Posted by arghx7 View Post
Ok, time for substantive questions. I see the torque calculation map, which is fine, but it's rather minor. Assuming EcuTek reverse engineered it correctly and the load axis is really grams/rev like a Subaru, somebody explain a few things.
1) What is the timing and knock control logic? Does it use a dynamic advance multiplier like the older Subarus? Does it use a calculated octane value (in RON)? Or does it use a basic "high octane" and "low octane" map with interpolation? Does it have an MBT calculation and a borderline knock timing calculation?
2) Have you found the injection timing maps? For both port and direct injection, does the logic go by start-of-injection or end-of-injection? Is there some kind of wall film compensation model for tip-in fuel?
3) There must be some kind of commanded air fuel ratio. Does it use open & closed loop areas, or closed loop through the entire operation? Is there an enrichment/closed-loop delay timer logic?
3) Have you found the MAF sensor scaling?
4) Have you found the cam phasing maps?
5) Can you turn on or off the diagnostic monitors and diagnostic trouble codes (check engine light)?
Please provide more information on what you guys have control over. The Japanese control systems (Denso, Hitachi) don't use full torque-based control like Bosch, Siemens, or Delphi do. So finding that map has limited usefulness.
I actually suspect this vehicle may have a non traditional control strategy compared to other Japanese systems. It is continually varying the duration of the port injectors, the duration AND timing of the direct injectors, AND the pressure from the high pressure fuel pump to achieve proper fueling. Also remember that the direct injectors and pump are actually controlled by another module, which will be running off commands from the main PCM.
This thing is not working off a simple injector basemap.
Boosted2.0 is offline
Old 06-17-2012, 01:34 PM   #87
Visconti
Drives: 05 STi
So things are moving forward quickly.
Lachute Performance has a BRZ and is the first to be working the new EcuTek ProECU tools.
If all goes as planned expect major updates in the next days to come!
-John
Visconti is offline
Old 06-17-2012, 03:18 PM   #88
Ess Vee
Ess Vee's Avatar
Drives: White 2011 Camaro 2SS 6MT
I skimmed the thread and didn't see a price. Do we have an idea of how much the software/cable will cost?
Also, will the software run on Linux (Arch Linux or Debian in particular)?
Thanks!
Project: Cleaning up the C5 engine bay
^Check it out^ *link fixed*
Ess Vee is offline
Old 06-17-2012, 05:08 PM   #89
TwinscrollGT35R
Drives: 2006 Subaru
Originally Posted by octagon View Post
This is the question people that really needs to be answered. In the past, when ecutek was installed on certain subaru ecu's it could not be completely removed. As a result an owner could NOT install another tuning software such as Cobb AP or OS on that ecu. The ONLY solution I'm aware of involves getting a new ecu. I had an Ecutek license for my 04 WRX and fortunately Crawford was able to swap ecu's for me when I wanted to switch to Cobb AP.
I guess since Ecutek will be the first to release their product (as they were with the WRX) they won't know if it any other tuning software can be used on an ecu after a Ecutek tune is "removed". I personally will wait until other tuning options are available to find out if there are any other compatibility issues.
Looks like its going to be a sales grab. A attempt to take market share before the sheep wise up. And they find out they are locked out and its to late.
As I still see no one has given a answer to the question.
TwinscrollGT35R is offline
Old 06-18-2012, 07:29 AM   #90
Visconti
Drives: 05 STi
Read the thread , it's all in there.
Visconti is offline
Old 06-18-2012, 07:33 AM   #91
Visconti
Drives: 05 STi
Thanks!
EcuTek's cable costs $350
EcuTek's license is $250
I plan on selling cables with a staged tune.
John
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
Ess Vee (06-18-2012)
Old 06-18-2012, 07:58 AM   #92
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
so if someone spends the $600 on a cable and license, they still can't modify their own maps to make a custom tune?
JP is offline
Old 06-18-2012, 08:01 AM   #93
Visconti
Drives: 05 STi
Yup!
Your going to spend $600 and not be able to make custom changes yourself.
Only ProTuners will be able to.
They're plans to release a copy of the software that will let you makes changes yourself but not during the initial release
Btw this is not a uncommon thing
John
Visconti is offline
Old 06-18-2012, 09:29 AM   #94
Cotnoir
Cotnoir's Avatar
Drives: 2013 BRZ "Sport-Tech"
-John
Yes absolutely.
details of the development coming soon
for info:
ben@lachuteperformance.com
1-450-562-0344
Cotnoir is offline
The Following User Says Thank You to Cotnoir For This Useful Post:
Exhaust (06-18-2012)
Old 06-18-2012, 09:33 AM   #95
Visconti
Drives: 05 STi
Originally Posted by Cotnoir View Post
Yes absolutely.
for info:
1-450-562-0344
Details and video
Visconti is offline
Old 06-18-2012, 09:59 AM   #96
JiB
JiB's Avatar
Drives: GT86
a staged tune, would be like a tune for people that have upgraded exhaust & intake? is it possible to revert back to factory settings?
JiB is offline
Old 06-18-2012, 10:04 AM   #97
Visconti
Drives: 05 STi
Each Vendor will be offering different things - I will be offering Staged Tunes with the cable - for intake and exhaust.
The more expensive option would be getting a custom tune in person or via email.
The less expensive option would be getting a EcuTek tune with-out purchasing their cable. It's cheaper but will leave you unable to flash back to stock and with out the ability to datalog.
Let me know if you have anymore questions
Thanks
John
Visconti is offline
JiB (06-18-2012)
Old 06-18-2012, 10:35 AM   #98
JiB
JiB's Avatar
Drives: GT86
Thanks
John
So the staged tune with cable that you plan to sell, can be taken back to stock? DIY type thing?
JiB is offline
FS: BRZ & 86/FR-S pre-release memorabilia bambbrose Miscellaneous 16 11-19-2012 02:38 PM
SOA and BRZ Release lies SkullWorks BRZ First-Gen (2012+) — General Topics 62 05-02-2012 09:49 AM
Release Series rL-gT Scion FR-S / Toyota 86 GT86 General Forum 55 01-18-2012 03:02 PM
Cellphones, Software, Transportation Toyota introduces Touch Life smartphone mirrorin quik1987 Other Vehicles & General Automotive Discussions 0 10-27-2011 04:27 AM
