Because compromise ®
Drives: Red Herring
Corner Weight Question
I am wishing to find out the weight distribution of my car.
I do not want spring height adjustments to influence the corner weight reading. How can I measure the "true" corner weights?
#2 |
Thanks
Take it to a race shop.
Height adjustment will affect the corner weights. That's the point.
#3 |
Drives: Red Herring
I am contemplating buying some made to measure dampers. The software the manufacture uses requests corner weights. How can I supply accurate corner weights when the the height adjustment of my existing dampers affects the weights?
#4 | |
Thanks
Let me look for it. What did they recommend for supplying the weights? here is the post http://www.vorshlag.com/forums/showthread.php?t=8145 this is the image
#5 | |
Drives: Red Herring
Sorry but I don't understand your question "What did they recommend for supplying the weights?"
#6 |
Thanks
Did you tell them your situation with aftermarket suspension? What do they recommend. If you had your car already corner weighted and ride height set how you like can't you just use those weights?
#7 | |
Drives: Red Herring
The dampers I am thinking of are made to measure. I could, if I the experience, know how and money specify the damping curve I wanted.Their through shaft dampers start at $12k AUD a set. And no, through shaft dampers are not on the shopping list. As it is my proposed budget only allows for low speed compression damping adjustment which is why the more information I can supply the more accurately the dampers can be tailored for me/my car. I would be relying their expertise to fill in the blanks.
#9 |
Drives: Velocity Orange 86 GT
Just a question but why not just use MCA's. They will customise things to your needs and as we've seen with all our track guys. Nobody uses anything else. Things like KW's, Teins, Ohlins etc all get removed off peoples cars to be replaced with them. In World Time Attack I think it was something like 5 out of the top 6 cars had MCA's. In the Bathurst Enduro race recently, most of the top end of the field used them. Why reinvent the wheel when the hard work has been done for you. Josh is out with his 86 at the track every few weeks testing his suspension and custom suspension stuff to help make the 86 track performance better, including some work towards helping put power down better on corner exits. Also he'll be entering it into WTAC this year alongside the Hammerhead S13. (different classes of course) Should be a hell of a car.
Just wondering really. Last edited by Northwest86; 04-29-2016 at 11:15 AM. |
| The Following User Says Thank You to Northwest86 For This Useful Post: | ZionsWrath (04-29-2016) |
#10 |
The Stig's German cousin
Weigh the car on corner scales.
Average the fronts. Report left front and right front the same. Average the rears. Report left rear and right rear the same. I can perform the averages for you if you paypal me $42. |
#11 | |
Drives: Subaru BRZ Limited
Can't agree more with this. You've no idea how lucky you are to live in Australia when it comes to track suspension! I recently moved from Aus to USA for three years and have a BRZ over here. It is currently a daily driver and weekend track car, and almost all of the hardware going on it will come home with me in three years time for the purchase of another 86/BRZ, which will be weekends/track only. If I was in Australia my coilover choice would be MCA all the way. The performance of the Blues and Reds at their pricepoint is simply off the charts. As I am over here and my car is still a daily, I have gone for the cheaper and softer option of STs, with the intent of selling them when I leave and putting MCA Reds on my car when I get home. MCA supplies the control suspension parts for the Pro-Am 86 racecar series, which I believe is a tailored MCA Red package costing less than $3k. I've read this has had a tonne of development put into it from Josh and none other than Neil Bates. Bates has done a 1.08.7 around Wakefield in the 178kw/1170kg prototype race car on the MCAs and non R-compound Dunlop Direzza Z2s (Treadwear 200). It'd be even quicker on RE-71Rs! That is a stupidly fast time for a car of that power/weight/cost and on those tyres. "I'll have what he's having!" Last edited by Traktor; 04-29-2016 at 11:37 AM. Reason: spelling |
| The Following User Says Thank You to Traktor For This Useful Post: | CSG Mike (04-29-2016) |
#12 |
Drives: '13 FRS - STX
I know I'm taking this too seriously, but this is bad, left side will always weigh more than right and when getting detailed ignoring that is giving up performance.
#13 | |
And mind you the S13 Hammerhead runs Red suspension. They don't even use custom Gold series stuff. For around that 3k mark you can literally buy the suspension used on a Proper Pro Time attack car. There wouldn't be many suspension companies that not only track test their suspension before release, but continue development. In Australia there really is no reason to buy anything else. I do wish though that the top track guys in the USA could try them out. I'd be very interested to hear what they think of them if they could try them. CSG start being a US MCA dealer. I'd love to see Australian products being sold worldwide. |
#14 |
Drives: Red Herring
I'm using MCAs Reds atm.
I had AST 5200 but I didn't like the lack of local support. I want to keep it local.
| Question About Negative Camber: More Negative Camber == More Grip at Corner? | Figo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 03-10-2019 03:08 PM |
| Question - Black OEM Shift Knob Weight | h8meh8ers | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-22-2015 01:41 PM |
| Turn Signal / Corner Light DRL Question | J_McElwee | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-18-2015 12:25 PM |
| Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 12:38 PM |
| A serious wheel question that goes beyond weight and appearance... | boredom.is.me | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 06-28-2012 11:41 AM |
