Old 04-28-2016, 01:10 PM   #1
Chad_W
Drives: 2013 BRZ DGM
Tweeter Aiming Advice Needed
As per the pic, I'm trying to determine if it makes more sense to have my tweeter laying back somewhat or closer to vertical. I'm running a set of Pioneer components with the 6.5 in the doors and the tweeter near the A-pillars pointing across to the opposite seats.
If I lay the tweeter back at approximately 30 degrees, it will be easier to make the install look clean (no extra bracketing) and it will avoid directing too much of the sound into gauge cluster cowl. The disadvantage is that tweeter will be off axis from my ears and there may be some reflections from the windshield
If I stand the tweeter up near vertical, I will be able to pretty much on axis and avoid windshield reflections, but be pointing into the cowl and have a more complicated, less clean install.
Any thoughts on what the best choice is?
Chad_W is offline   Reply With Quote
Old 04-28-2016, 03:15 PM   #2
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
It depends on your priority for installation. Are you more concerned with how they look installed or how they sound installed (imaging, soundstage, etc...)? IMHO, if you're going to the trouble of custom installing them, then try them in different locations until you're satisfied with the sound. FWIW, I have mine in custom A-pillars.
kmbkk is offline   Reply With Quote
Old 04-28-2016, 03:44 PM   #3
Chad_W
I'm looking to balance out the amount of work and cost it will take with the benefit. I'm not going to do the custom A-pillar route, unless there is someone who makes a prefab (have you come across any?)
My original thought was surface mount on the A-Pillar, but I'm leaning towards grill top, because I feel like will be similar in performance, but more secure and no more obtrusive.
You're right though, I should wire everything up and play around with some double-sided tape until I figure out what I want
Old 04-29-2016, 01:24 AM   #4
TOOSTUBBORN2FAIL
Drives: Specialized Hardrock
There will be reflections down to about 13khz no matter what, as the tweeter will be omnidirectional until above that. Your doing the right thing shoving it as far into the dash as possible. Keep in mind, it will also make the tweeter more efficient.
TOOSTUBBORN2FAIL is offline   Reply With Quote
The Following User Says Thank You to TOOSTUBBORN2FAIL For This Useful Post:
Leonardo (04-29-2016)
Old 04-29-2016, 02:11 PM   #5
Chad_W
I played around a little bit and decided on an a-pillar position I like.
Now how do I get those friggin green tethers off without breaking them?
Old 04-16-2021, 02:25 PM   #6
asnatlas
Drives: 2013 - BRZ - SWP
Any updates ?
asnatlas is offline   Reply With Quote
Brake Upgrade, Advice needed! UNREAL Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 12-09-2015 06:46 PM
tire size advice needed marcom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-08-2015 04:45 PM
FA20CLUB turbo kit advice needed joedaniali Forced Induction 26 02-24-2014 02:25 PM
A little strategy & rubber advice needed ultra Tracking / Autocross / HPDE / Drifting 19 01-31-2014 03:36 PM
What to do.. Advice needed fuddbutter AUSTRALIA 44 01-29-2013 08:02 AM
