#29 |
Drives: Whiteout FRS
ST are fine for track, stiffer than most lowering springs. Plus they are linear, better feel and more predictable.
You don't need ridiculously stiff springs for the FRS/BRZ for track use. Most people who are lapping aren't experienced enough nor using sticky enough tires to run 8k+. Even from lowering springs to middle of the line coil overs showed very little improvement (minus, height adjustable, "stiffness" dampening) in lap times. Arguing the semantics between the lower end brands is just that. It's opinion based on whomever bought them before you. Just find a spring rate that you'll be happy with for 90% of your driving and get it from a well known brand (not going to knock upcoming brands, just makes life less complex to use a tried and test option). I bought ST's based on the company they are with (KW), they are valved very well, and use linear 4k/5k springs. In which in my research is more than fine for an entry level driver. Once I grow of of them and get more competitive Ill be upgrading to a higher level system along with tires, etc. Just my opinion though
#30 |
Drives: Black BRZ
I ended up going with ST. They are great in my book. Only had them on for a few days and haven't had time to dig into them yet. Great buy if anyone is still on the fence. Handling and comfort are great!
#31 | |
Drives: Black MT LMT BRZ
#32 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
The FA500s with swift springs arent bad. But for the money I much prefered my stock struts on RCE yellows for the same type of driving you will be doing
| The Following User Says Thank You to finch1750 For This Useful Post: | Racecomp Engineering (04-29-2016) |
#33 |
Drives: 14 Ultramarine FR-S
I'm on lowering springs and its fine for DD - I plan on going Koni Yellows Paired with my Springs.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#34 |
JRZ RS Pro here and they feel pretty comfortable for daily driving.
| The Following User Says Thank You to Apex-Apex For This Useful Post: | Kristjan (04-29-2016) |
#35 |
Drives: Too heavy
Tein street flex , all the way down , 4click all around from the stiffest setting , 18x9.5/10.5 w/225/40 and 235/30 stretch ....3.5' camber 0 toe all around , couldn't be happier .
#36 |
Drives: 2013 Scion FRS
I'm DD'ing with BC Racing Extreme Lows. 8k front and back. I have the rates at 8 click from softest in the front and 10 clips for the rear. Though I prefer my stiffness all the way up, this was a lot more comfortable for my girlfriend though is still stiffer than stock ride. The height adjustment is whatever the coilovers were pre-set to.
| Tow hooks on daily drivers... | zooki | Off-Topic Lounge [WARNING: NO POLITICS] | 22 | 08-29-2013 04:47 PM |
| LakOfSpeed Daily Drivers III | JohnAyySays | Northern California | 9 | 08-25-2013 01:34 PM |
| Daily drivers, do you swap street and track brake pads? | qoncept | Tracking / Autocross / HPDE / Drifting | 31 | 06-26-2013 03:50 AM |
| So first time MT drivers (or been a while). hows your daily commute experience? | chickdigger802 | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 06-22-2013 03:24 AM |
| brief comment from tsuchiya san | mokinbird87 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 16 | 01-08-2012 12:45 PM |
