Old 04-21-2016, 02:09 PM   #29
etc
Drives: '13 FRS
Originally Posted by PandaSPUR View Post
Ah my bad, completely missed that last sentence with the link.
Hmm this seems fairly DIY-able too.. even for a guy like me who has no garage or driveway.
Ya it really isn't bad, the painting takes the most time. I updated the second post with painting instructions.
etc is offline   Reply With Quote
Old 04-21-2016, 02:20 PM   #30
Speck
Drives: '13 FR-S
in
Speck is offline   Reply With Quote
Old 04-21-2016, 07:59 PM   #31
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
Nice find.
Sideways is offline   Reply With Quote
Old 04-26-2016, 05:48 AM   #32
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Originally Posted by etc View Post
Added a couple more photos to the top post, with the wheel on and one of the back and the mounting bracket.
The request for more photos has forced me to expose my dirty car to the world
Would it be possible for you to test fit the OEM or 17" wheels clear the brakes?
Thanks for the tread.
andrewFT86 is offline   Reply With Quote
Old 04-28-2016, 01:22 AM   #33
Trac Toy
Trac Toy's Avatar
Would jump on these immediately if i knew they would fit under a 17x9 35 RPF1
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 04-29-2016, 08:05 AM   #34
Trac Toy
Trac Toy's Avatar
Wondering what is sticking out of the front of the caliper towards the inside of your wheel. Looks round... Can you take some better up close pics of the fitment of the caliper inside your wheel? Also what offset is the wheel you are using? @etc
.o0+Eric+0o.
2013 FRS 6MT
Old 04-29-2016, 06:16 PM   #35
Brzerrk
Drives: '13 Turbo BRZ-L 6MT
Thanks for the write-up! About to purchase this setup myself. +1 for wondering the offset needed...Currently on stock wheels but that will change soon. I'm nearly positive they won't clear them.
Brzerrk is offline   Reply With Quote
Old 04-29-2016, 06:17 PM   #36
Brzerrk
Looks like about $750 with drilled/slotted rotors, stock pads, and stainless lines. Soooooo cheap. Very happy to find this
Old 04-30-2016, 03:45 AM   #37
Trac Toy
Trac Toy's Avatar
So after doing some searching and reading, the round thing I'm seeing in the original posters pictures is something that GM added to their pads for NVH. I guess the early caliper and pad setups made a bit of noise and well.... You can't have that on a Cadillac...
So they added some small amount of weight to the pads.
Aftermarket pads like Hawks and such do not have these weights.
My concern with these originally was that I am going to try these under a 17" wheel so space is of a concern. The OP is running 18" wheels and space is less of a concern.
.o0+Eric+0o.
2013 FRS 6MT
Old 05-05-2016, 12:19 AM   #38
asnatlas
Drives: 2013 - BRZ - SWP
Red Anodized Metalcast ?
http://duplicolor.com/product/metalc...tomotive-paint
Any way that I could use this paint on these or any calipers ? Would I be able to paint them with a high temp primer or even use high temp paint, then spray the Anodized Metalcast over the high temp paint then add a few layers of clear ?
asnatlas is offline   Reply With Quote
Old 05-05-2016, 06:11 PM   #39
etc
Drives: '13 FRS
Sorry I have neglected the thread for a bit. That is correct, those are these odd wheel weights GM put on camaro SS pads. I happened to have the camaro SS pads so I am using them until my track pads come in.
Don't worry about them the stock ATS pads don't have them and none of the aftermarket ones will.
I haven't had the stock wheels in years unfortunately so I can't test fit. I will try to measure from the center point to the edge of the caliper though next time I have the wheels off (should be next week to put new pads on).
The Following 3 Users Say Thank You to etc For This Useful Post:
andrewFT86 (05-08-2016), Thorpedo (05-05-2016), Trac Toy (05-05-2016)
Old 05-05-2016, 06:21 PM   #40
etc
Drives: '13 FRS
Don't really know, it says good to 500f, unless you track your car that should be plenty. Even if you do track it that may be sufficient.
Old 05-05-2016, 08:50 PM   #41
turbocat
turbocat's Avatar
Drives: 13 BRZ SSM
Only thing I'm not cool with is having to drill out and tap the oem spindles. Basically you ruin any chance of using these spindles for stock parts again.
turbocat is offline   Reply With Quote
The Following User Says Thank You to turbocat For This Useful Post:
NyC Zn6 (06-02-2016)
Old 05-10-2016, 04:56 PM   #42
Chillemall
Drives: Raven FRS
Hey guys, just wanted to let you know that i will be track testing these rotors at Gingerman Raceway on Friday 5/13.
I am friends with the owner of ctsvbrakeswap.com. He has offered up a sponsership for me to run them. I run in the HPDE+ Class for GRIDlife Time Attack. My previous track record was 1:46.5xx on Pump gas with a tune, RS-3's and Stance USA Coilovers.
I will be running this kit with EBC Yellow pads (same pads i had in oem calipers) I have Stainless brake lines and Stoptech fluid.
We are hoping for positive results. These are momentum cars on the track. I am a veeerrrrrry late braker, and I will not be holding back during testing.
THIS KIT WILL GET A WORKOUT.
Stay tuned.
Strictly Performance Motorsports |Team PARTYCRASHERS| IG _Trainwreck
Chillemall is offline   Reply With Quote
The Following 5 Users Say Thank You to Chillemall For This Useful Post:
8686 (05-11-2016), DAEMANO (05-10-2016), sroby (08-18-2019), TouchMyHonda (05-20-2016), Trac Toy (05-10-2016)
ats, brakes, brembo
STi Brembos, rotors, and brake lines jwbrocloud Brakes, Suspension, Chassis 5 01-09-2015 10:55 PM
04 STI Brembos, Hawk pads, 5x100 front rotors Philly758 Brakes, Suspension, Chassis 7 12-06-2013 08:55 AM
FS: 2004 STi Gold Brembos(5x100) w/Hawk Pads, Rotors, lines!~~MINTTT~~ nemesisdrift Brakes, Suspension, Chassis 25 11-22-2013 01:25 AM
2005 STI Brembos Powder Coated, Hawk HPS Pads, Stoptech Rotors and Braided Brake Line Jamifra Brakes, Suspension, Chassis 10 10-29-2013 11:31 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
