View Poll Results: What Exhaust set-up should the FT come with?
Single Exhaust - 1 exit 86 36.60%
Single Exhaust - 2 exits (2 mufflers) 71 30.21%
Single Exhaust - Centre 15 6.38%
Dual Exhaust 63 26.81%
Voters: 235. You may not vote on this poll
Old 02-12-2011, 10:11 PM   #71
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
That's a pretty sick looking Subie, and using a tow-hook to fill the empty exhaust cutout is a good idea.
+1
look at that camber!!
Old 02-13-2011, 05:58 PM   #72
Siriusly.Andrew
Siriusly.Andrew's Avatar
Drives: 1995 Civic DX
Originally Posted by RRnold View Post
+1
is that healthy?
I don't see how it could be "good" to have that steep of a camber angle, but there is probably something crazy and mechanical about how / why it works. If it works lol.
Originally Posted by MatadorRacing_F1 View Post
Anyway, as i was saying, "speed is expensive, how fast are you willing to spend?"
Siriusly.Andrew is offline   Reply With Quote
Old 02-13-2011, 06:35 PM   #73
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by Siriusly.Andrew View Post
is that healthy?
In this case it's mostly a wheel fitment issue I believe given the wicked stance.
The new rear suspension on the STI's has an upper wishbone with lower lateral and toe control links so it can add negative camber as the suspension compresses. Fronts are still MacStruts with don't really change their camber under compression. For a hard-running track car negative camber allows the tire to roll onto more contact patch under cornering, generating more lateral grip.
Because titanium.
Old 02-13-2011, 11:38 PM   #74
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
right, but it looks to me like that car doesn't see any track time. i would think it would rub like crazy if you really loaded a corner up with some weight transfer.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 02-14-2011, 12:33 AM   #75
RRnold
2 wheel member
RRnold's Avatar
is that healthy?
It's not healthy at all! As a matter of fact, it's pretty sick!
Clean cars can roll on the track too! Don't let camber fool ya!
btw-he has the wrong wheel spec! Look how chewed up his rear fender is in the 2nd pic.
Old 02-14-2011, 05:53 AM   #76
NESW20
2.1L 3SGTE
it's not so much the camber that makes me think it doesn't see track time, but unless there's some magic going on there, i don't see how that tire won't rub under more compression than you get sitting in a parking lot, hehe.
2008 Civic Si Sedan
Old 02-14-2011, 06:54 AM   #77
70NYD
70NYD's Avatar
Drives: RX8 S1
It does rub. The rear arches are fucked up.
I have nothing against hella flush on a parked car. BUT only when it's parked. This is why only the fly automatically/manualy adjustable suspension should be used so when your parked, great your slammed with nice camber, but when you take off the car adjusts itself to be usable. I'm not talking about just bags either
70NYD is offline   Reply With Quote
Old 02-14-2011, 04:11 PM   #78
RRnold
2 wheel member
RRnold's Avatar
I agree, IF that thing does go to the track, it wouldn't make it past T1 with that stance!
Yeah man! Seeing chewed rear fenders on a clean car is like seeing a hot chick, she smiles and her teeth are all f**ked up!
Old 02-17-2011, 12:07 AM   #79
Matador
hashiryu
Drives: Mk4 Supra
Matador is offline   Reply With Quote
Old 02-20-2011, 11:46 PM   #80
Allch Chcar
Drives: N/A
That'll do.
Allch Chcar is offline   Reply With Quote
Old 02-28-2011, 07:20 PM   #81
korytirk
Drives: 2003 ford ranger
How many on here have the same axle back? I own a gibson-------------------------------flowmaster muffler
korytirk is offline   Reply With Quote
Old 02-28-2011, 07:44 PM   #82
ryun84
ryun84's Avatar
Drives: 04 PSM WRX Wagon
http://www.ft86club.com/forums/showthread.php?t=983
This has all been mentioned with the new pics, but the photos of the FT-86 MkII concept under the sheets looks to have 2 exhaust exits. But as many people have mentioned, this is still a concept and the production version could still be different from what we see.
ryun84 is offline   Reply With Quote
Old 02-28-2011, 07:48 PM   #83
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
^or could do like some of the after market S2k exhaust make it into single... just an option
Old 02-28-2011, 07:52 PM   #84
ryun84
ryun84's Avatar
Yeah! It's probably safe to say that if the production model is a single exhaust/dual exit, then companies would definitely make an aftermarket single exit exhaust. If they're anything like the single exit S2000 exhausts, they'll be loud as hell! LOL!
ft 86 exhaust dalli Scion FR-S / Toyota 86 GT86 General Forum 11 09-08-2010 11:16 PM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 12:33 PM
