Old 04-08-2016, 12:33 PM   #1
Jovontea
Jovontea's Avatar
Drives: 2016 Asphalt FRS
Bumper Question
Hey guys! Dumb question, but I seem to have a difficult time removing that bolt connected to the rubber/plastic, everytime I put pressure on it, it seems like the plastic thing will rip off as well. Any suggestions? Thank you. Even when I put on the Spec D headlights I only had it half way because the bolt. I am now planning on putting a splitter on so I need to take it off.
Jovontea is offline   Reply With Quote
Old 04-08-2016, 12:54 PM   #2
8R6
8R6's Avatar
Drives: FRS
is that the bolt from under the bumper, and off to the side a bit? not sure why you would need to apply any "pressure" to it whether removing or installing. the only hard/annoying part for that bolt was it doesnt stay still because the plastic its holding is flimsy. you shouldnt have to be torquing that thing down much.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
FRSBRZGT86FAN (04-10-2016)
Old 04-08-2016, 08:57 PM   #3
You might try placing a flat head screwdriver under the washer and prying up as you unscrew the screw ......
Old 04-09-2016, 02:54 PM   #4
Jovontea
Jovontea's Avatar
Thanks, i'll give it a try ;-) I think it's just dead tight when it was assembled because the screw won't move, it's like the whole thing along with the rubber/plastic is going to rip off haha
Old 04-09-2016, 02:54 PM   #5
Jovontea
Jovontea's Avatar
@humfrz
Old 04-09-2016, 10:58 PM   #6
Well now......back in the day .......I would have suggested that you place the screwdriver on the screw and give it a good rap with a hammer.
However, today that would bust up the plastic piece.
Old 04-09-2016, 11:25 PM   #7
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
your picture is too big man XD
FR-Sky is offline   Reply With Quote
Old 04-10-2016, 10:36 PM   #8
@Jovontea ...... you have tried squirting it with PB Blaster or WD-40 or something like that ..... haven't you .....??
Old 04-10-2016, 10:42 PM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Jovontea View Post
After having to take off the bumper at least 3-4 times so far in only 5000 miles of owning the car I can tell you the clips suck and those two bolts are the only good part
Old 04-10-2016, 11:22 PM   #10
So, @FRSBRZGT86FAN what's the secret to getting those screw/bolts lose .... ??
@Jovontea ...... here is a handy tool for your tool box to loosen up tight screws. It will either break them lose or bugger up the head so as to leave the only option being to drill it out.
http://www.homedepot.com/p/TEKTON-3-...B&gclsrc=aw.ds
Old 04-10-2016, 11:25 PM   #11
FRSBRZGT86FAN
The way you suggested, the same method used for stubborn computer screws, you unscrew it left while pulling down, alternatively you can attempt to reach it through the wheel fender liner because you have to undo those clips anyway to get the bumper off.
Interesting, when putting that back as well it doesn't feel like it's actually screwing in it more or less pushes in.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
humfrz (04-11-2016)
Old 04-11-2016, 12:06 PM   #12
Jovontea
Jovontea's Avatar
@humfrz @FRSBRZGT86FAN Thanks for the tip guys, i'll def give it a try. I think at this point the screw mount or just screw in general is so tight it'll rip the plastic/rubber whatever material it is off lmao. If I unscrew it, one side is already ripped off haha. It sucks because I don't think anyone has a problem with this but me? :-(
@FR-Sky haha dang, just joined a week ago not sure how to work it, just cropped to 135 x 135 hahahah
Old 04-11-2016, 12:09 PM   #13
Jovontea
Jovontea's Avatar
@humfrz I can give WD-40 a try but I only have around 4k miles on it so I'm thinking it was assembled dead tight?
Old 04-11-2016, 12:34 PM   #14
Well, now, @Jovontea , I just went out and looked on my car.
If it is the bolt on the underside, I suggest you use a 10 mm socket ...... and unscrew it.
lefty loosie to unscrew ...... but it is upside down so ...... loosie is ..... but wait....... are in in the down under ........ in England ....... I'm all
BRZ Front bumper question E13MentX BRZ First-Gen (2012+) — General Topics 37 09-07-2020 08:42 PM
TRD rear bumper question ciotime Cosmetic Modification (Interior/Exterior/Lighting) 18 10-28-2018 11:59 PM
Question about BRZ front bumper Futaba Cosmetic Modification (Interior/Exterior/Lighting) 3 11-25-2014 08:03 PM
Between Hood and Front Bumper Question FastOnFastOff Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-26-2013 02:26 AM
Question for for someone who has had the front bumper off 10Tim Cosmetic Modification (Interior/Exterior/Lighting) 5 09-30-2013 05:34 PM
