Southern California SoCal
Old 04-08-2016, 04:10 PM   #15
iLoveMySubi93
Drives: BRZ SOLD, 2017 sti, 2003 tacoma TRD
Does perrin use grub screws instead?
it specifically says to reuse the oem pin. idk maybe its a manufacturer defect or something. because its seriously weird the pin slides into the oem one and locks but it wont even go in on the perrin one
iLoveMySubi93 is offline   Reply With Quote
Old 04-08-2016, 04:16 PM   #16
Ashikabi
Ashikabi's Avatar
Try squeezing it with pliers to get it started. DIY I just read said you have to tap it in with a hammer. My lockout was the same way but it's not Perrin
The Following User Says Thank You to Ashikabi For This Useful Post:
iLoveMySubi93 (04-08-2016)
Old 04-09-2016, 12:15 PM   #17
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
sorry - i thought i had two but only one
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 04-09-2016, 07:32 PM   #18
tracerit
Drives: '13 SSM BRZ Limited 6MT
where did you get your spare pins from?
tracerit is offline   Reply With Quote
Old 04-09-2016, 09:44 PM   #19
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
i work for a dealer
Flex Fuel Turbo BRZ
Old 04-10-2016, 11:47 AM   #20
iLoveMySubi93
i just ordered a few of them. so if it works out im more than happy to give you one or two.
Old 04-10-2016, 12:37 PM   #21
tracerit
Which ones did you order? If they work let me know, I'm up for picking one or two from you :p
Old 04-10-2016, 12:38 PM   #22
tracerit
i work for a dealer
So there is a part number for thr pins? Or is it more a generic part that fits? I wasn't able to find the part on subaruparts
Old 04-10-2016, 01:00 PM   #23
Norville Rogers
Drives: Subaru BRZ
I'm lost on this one.
Is the reverse lock out the small piece of plastic that stops the less able selecting reverse when they didn't mean to?
Does changing out mean replacing?
Help.
Norville Rogers is offline   Reply With Quote
Old 04-10-2016, 02:04 PM   #24
tracerit
Help.
yup, it's that plastic part. You don't need to replace the metal pin all the time. I know the Raceseng reverse lockout provides a quality threaded pin to use. Not sure about the Perrin lockout. My aliexpress lockout requires reuse of the stock pin.
Old 04-10-2016, 02:15 PM   #25
Ashikabi
Ashikabi's Avatar
Perrin reuses the stock pin apparently. I got my reverse lockout on eBay for $15 from Taiwan. Works fine, looks great. No reason to spend $80 on Perrin/Grimmspeed/Raceseng/etc unless you want a specific color or the name/logo on it. This part doesn't really break, people just do it for looks or feel
Old 04-10-2016, 02:25 PM   #26
tracerit
I thought this to and to a certain degree, those ones are a lot more expensive. The Raceseng one has an O-ring inside that really keeps the lockout solid, there's no play in it. Just wish it didn't have such a standout logo on it (had the silver to minimize it) and that the diameter wasn't larger up top (limited some shift knobs I tried using as it wouldn't fit in).
Old 04-10-2016, 02:29 PM   #27
Ashikabi
Ashikabi's Avatar
Mine is polished aluminum with no logos at all
Old 04-11-2016, 01:59 PM   #28
Norville Rogers
Drives: Subaru BRZ
I was tempted by the eBay one to go with my team voodoo shifter. 10 minute job to fit I guess
Perrin WRX STI reverse lock out..NEW no box BRZeer Miscellaneous 2 12-18-2014 03:43 PM
Question for those who have changed the reverse lockout AllStar0419 Cosmetic Modification (Interior/Exterior/Lighting) 5 11-04-2014 11:25 PM
Reverse lock out adjustment nfaj Engine, Exhaust, Transmission 10 10-03-2014 10:46 AM
Perrin Reverse Lock BRZ615 Interior Parts (Incl. Lighting) 3 08-07-2014 02:02 AM
Reverse lock out diameter? Moddiction BRZ First-Gen (2012+) — General Topics 6 09-01-2012 12:04 PM
