Old 04-08-2016, 01:25 PM   #1
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Heel Toe - detailed video (pretty good)
http://www.autoblog.com/2016/04/07/h...utorial-video/
Only thing I disagree with is braking before clutching. I always clutch let the car come down and if it can't come down fast enough I'll tap the breaks to enter my next gear speed. I have never and probably will never brake then clutch
Do you brake clutch or clutch brake?
Researching this, looks like half brake, half clutch
This guy explained the transmission inner workings pretty well
To this point, I don't heel toe, but maybe I'll work on it
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 04-08-2016, 03:03 PM   #2
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
As I'm sitting here at work,I'm having a hard time thinking of how exactly I clutch on a regular basis,mainly because I've been driving stick for so long,it's almost like second nature.
The only thing that I do know it that sometimes I get lazy and don't bother downshifting.It's usually only in light traffic when I do that though.
One thing I will say about the FR-S. Coming from a little 98 Nissan 200SX,I found it to be a big adjustment getting use to the FR-S' high clutch.
Th3rdSun is offline   Reply With Quote
The Following 3 Users Say Thank You to Th3rdSun For This Useful Post:
jcw99 (04-08-2016), Summerwolf (04-08-2016), Tcoat (04-08-2016)
Old 04-08-2016, 03:07 PM   #3
Clutch downshift, clutch downshift, clutch downshift. Brake. Clutch.
strat61caster (04-08-2016), Summerwolf (04-08-2016)
Old 04-08-2016, 03:12 PM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Normal, everyday driving.... is not complicated, and it gets muddied with every thread here.
Old 04-08-2016, 03:15 PM   #5
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Don't overthink it. Heel-toe before the corner, Scandinavian flick, power oversteer. When you get to your destination, pop bottles of champagne on the podium. Rinse, repeat. It's important to keep a cooler of champagne in the trunk.
jawn is offline   Reply With Quote
The Following 3 Users Say Thank You to jawn For This Useful Post:
rastapete (04-08-2016), Toyarzee (04-08-2016), Ultramaroon (04-08-2016)
Old 04-08-2016, 03:18 PM   #6
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Good thing this subject isn't getting analyzed to death lately.
If only everyone had chosen the clearly superior transmission option where computers do everything for you, and faster too, we wouldn't have these problems
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
The Following User Says Thank You to Tectoniic For This Useful Post:
Tcoat (04-08-2016)
Old 04-08-2016, 03:23 PM   #7
CokeSlap
Drives: 2014 Monogram FRS Whiteout
Coming from an older Honda I find it a bit more difficult to heel toe in the FRS. The integra I blip the throttle and it was exactly where it needed to be. In the FRS I have to stomp the throttle and sometimes I feel like I need to let it stay for a fraction of a second in order to get a smooth heel toe.
Previous Ride
1992 Acura Integra GSR in Aztec Green Pearl
CokeSlap is offline   Reply With Quote
Old 04-08-2016, 03:23 PM   #8
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
What @Tcoat said, on the street: downshift downshift downshift (basically 'engine braking' or 'coasting in gear' to slow down for the anticipated change in speed, stop light/sign, child, etc.) then brake, then clutch when engine rpm drops to ~1500 (could also heel-toe the downshifts to have constant deceleration while keeping revs in the useful range). Saves fuel, easier to accelerate if the light turns green, ball rolls out of the way, traffic clears etc.
Emergency stop? Crossed the finish line at autox and don't want to run over the person with the sticky notes? Brake hard then clutch. If you clutch first your engine will be hanging up at 3k, 4k, 7k while you apply the brakes. The car will be ok if it stalls, it won't be if you hit something.
Dat throttle by wire yo.
I hate it, I could describe my old POS pickup truck the same way vs. the 86 but you eventually get a feel for blipping hard to 50% throttle to get the revs to come up.
ineedyourdiddly
Tcoat (04-08-2016)
Old 04-08-2016, 03:30 PM   #9
CokeSlap
I hate it, I could describe my old POS pickup truck the same way vs. the 86 but you eventually get a feel for blipping hard to 50% throttle to get the revs to come up.[/QUOTE]
It does drive me nuts some times. I need to take out the clutch pedal spring to see if that will help in my endeavors. I get the feeling I need to be more methodical with the FRS where the integra it was more a matter of being quick in order to not upset the car.
Previous Ride
Old 04-08-2016, 03:32 PM   #10
c4lvinnn
Drives: Toyobaruion
It's fairly difficult to get the stock clutch to engage at the correct time unless you removed the clutch spring. It's so much easier to heel-toe after you do that, even when the throttle is being dumb because throttle by wire.
c4lvinnn is offline   Reply With Quote
The Following User Says Thank You to c4lvinnn For This Useful Post:
CokeSlap (04-08-2016)
Old 04-08-2016, 03:38 PM   #11
CokeSlap
Exactly what I was hoping for. I do miss the cable clutch and throttle in my old car.
Previous Ride
Old 04-08-2016, 03:44 PM   #12
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Old guys who drove old cars learned to double clutch as well because after 20k their synchros didn't work worth a damn.
My dad racing my car: It wasn't until I put a camera in it did I realize he was heal-toe-double-clutching the whole time. Go dad!
[ame]http://vimeo.com/70975448[/ame]
SCCA T4 - FRS
The Following 8 Users Say Thank You to rice_classic For This Useful Post:
Braces (04-09-2016), Frost (04-08-2016), Quentin (04-08-2016), rookie (04-08-2016), strat61caster (04-08-2016), Tcoat (04-08-2016), Toyarzee (04-08-2016), Ultramaroon (04-08-2016)
Old 04-08-2016, 03:51 PM   #13
Or didn't even have them!
Old 04-08-2016, 03:51 PM   #14
strat61caster
I've only driven one classic Mustang in my life, but doing the double throttle blip like I was Steve McQueen and hearing the V8 bark was the best part of it.
Edit: for clarity on the relevance, old cars kinda suck.
[ame="https://www.youtube.com/watch?v=31JgMAHVeg0"]Bullitt - The Chase (part 1) - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=wk9SZbrh_Tg&nohtml5=False"]Bullitt - The Chase (Part 2) - YouTube[/ame]
ineedyourdiddly
I think I found a pretty good way of explaining why I got this car.... Wired86 BRZ First-Gen (2012+) — General Topics 64 04-06-2016 08:37 PM
Scraped my rear bumper pretty good mannie Northwest 11 06-14-2015 05:54 AM
17x9 e30n Rota Torques.... fit pretty good actually Spaztastik Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-05-2013 02:12 AM
Good place to practice heel/toe braking in N. Seattle? kludger Northwest 4 04-04-2013 07:27 PM
A pretty good deal on now. zoomzoomers BRZ First-Gen (2012+) — General Topics 7 03-29-2013 04:57 PM
