Drives: 2013 Pearl White 6MT
Heel Toe - detailed video (pretty good)
http://www.autoblog.com/2016/04/07/h...utorial-video/
Only thing I disagree with is braking before clutching. I always clutch let the car come down and if it can't come down fast enough I'll tap the breaks to enter my next gear speed. I have never and probably will never brake then clutch Do you brake clutch or clutch brake? Researching this, looks like half brake, half clutch This guy explained the transmission inner workings pretty well To this point, I don't heel toe, but maybe I'll work on it
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I
at night and ate at sun rise |
#2 |
Drives: 2013 FR-S MT Hot Lava
As I'm sitting here at work,I'm having a hard time thinking of how exactly I clutch on a regular basis,mainly because I've been driving stick for so long,it's almost like second nature.
The only thing that I do know it that sometimes I get lazy and don't bother downshifting.It's usually only in light traffic when I do that though. One thing I will say about the FR-S. Coming from a little 98 Nissan 200SX,I found it to be a big adjustment getting use to the FR-S' high clutch. |
| The Following 3 Users Say Thank You to Th3rdSun For This Useful Post: |
#3 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | strat61caster (04-08-2016), Summerwolf (04-08-2016) |
#4 |
Panda Trueno
Drives: No twin now.
Normal, everyday driving.... is not complicated, and it gets muddied with every thread here.
#5 |
Drives: 2015 CWP BRZ Limited
Don't overthink it. Heel-toe before the corner, Scandinavian flick, power oversteer. When you get to your destination, pop bottles of champagne on the podium. Rinse, repeat. It's important to keep a cooler of champagne in the trunk.
| The Following 3 Users Say Thank You to jawn For This Useful Post: |
#6 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
Good thing this subject isn't getting analyzed to death lately.
If only everyone had chosen the clearly superior transmission option where computers do everything for you, and faster too, we wouldn't have these problems
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
| The Following User Says Thank You to Tectoniic For This Useful Post: | Tcoat (04-08-2016) |
#7 |
Drives: 2014 Monogram FRS Whiteout
Coming from an older Honda I find it a bit more difficult to heel toe in the FRS. The integra I blip the throttle and it was exactly where it needed to be. In the FRS I have to stomp the throttle and sometimes I feel like I need to let it stay for a fraction of a second in order to get a smooth heel toe.
Previous Ride
1992 Acura Integra GSR in Aztec Green Pearl |
#8 | |
Drives: '13 FRS - STX
What @Tcoat said, on the street: downshift downshift downshift (basically 'engine braking' or 'coasting in gear' to slow down for the anticipated change in speed, stop light/sign, child, etc.) then brake, then clutch when engine rpm drops to ~1500 (could also heel-toe the downshifts to have constant deceleration while keeping revs in the useful range). Saves fuel, easier to accelerate if the light turns green, ball rolls out of the way, traffic clears etc.
Emergency stop? Crossed the finish line at autox and don't want to run over the person with the sticky notes? Brake hard then clutch. If you clutch first your engine will be hanging up at 3k, 4k, 7k while you apply the brakes. The car will be ok if it stalls, it won't be if you hit something. Quote:
I hate it, I could describe my old POS pickup truck the same way vs. the 86 but you eventually get a feel for blipping hard to 50% throttle to get the revs to come up. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Tcoat (04-08-2016) |
#9 |
Dat throttle by wire yo.
I hate it, I could describe my old POS pickup truck the same way vs. the 86 but you eventually get a feel for blipping hard to 50% throttle to get the revs to come up.[/QUOTE] It does drive me nuts some times. I need to take out the clutch pedal spring to see if that will help in my endeavors. I get the feeling I need to be more methodical with the FRS where the integra it was more a matter of being quick in order to not upset the car.
Previous Ride
#10 |
Drives: Toyobaruion
It's fairly difficult to get the stock clutch to engage at the correct time unless you removed the clutch spring. It's so much easier to heel-toe after you do that, even when the throttle is being dumb because throttle by wire.
| The Following User Says Thank You to c4lvinnn For This Useful Post: | CokeSlap (04-08-2016) |
#11 |
Exactly what I was hoping for. I do miss the cable clutch and throttle in my old car.
Previous Ride
#12 |
Drives: Nevermorange FRS
Old guys who drove old cars learned to double clutch as well because after 20k their synchros didn't work worth a damn.
My dad racing my car: It wasn't until I put a camera in it did I realize he was heal-toe-double-clutching the whole time. Go dad! [ame]http://vimeo.com/70975448[/ame]
SCCA T4 - FRS
| The Following 8 Users Say Thank You to rice_classic For This Useful Post: | Braces (04-09-2016), Frost (04-08-2016), Quentin (04-08-2016), rookie (04-08-2016), strat61caster (04-08-2016), Tcoat (04-08-2016), Toyarzee (04-08-2016), Ultramaroon (04-08-2016) |
#13 |
Or didn't even have them!
#14 | |
Edit: for clarity on the relevance, old cars kinda suck. [ame="https://www.youtube.com/watch?v=31JgMAHVeg0"]Bullitt - The Chase (part 1) - YouTube[/ame] [ame="https://www.youtube.com/watch?v=wk9SZbrh_Tg&nohtml5=False"]Bullitt - The Chase (Part 2) - YouTube[/ame] |
| The Following User Says Thank You to strat61caster For This Useful Post: | Toyarzee (04-08-2016) |
| I think I found a pretty good way of explaining why I got this car.... | Wired86 | BRZ First-Gen (2012+) — General Topics | 64 | 04-06-2016 08:37 PM |
| Scraped my rear bumper pretty good | mannie | Northwest | 11 | 06-14-2015 05:54 AM |
| 17x9 e30n Rota Torques.... fit pretty good actually | Spaztastik | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-05-2013 02:12 AM |
| Good place to practice heel/toe braking in N. Seattle? | kludger | Northwest | 4 | 04-04-2013 07:27 PM |
| A pretty good deal on now. | zoomzoomers | BRZ First-Gen (2012+) — General Topics | 7 | 03-29-2013 04:57 PM |
