Southern California SoCal
Old 04-07-2016, 06:19 PM   #1
iLoveMySubi93
Drives: BRZ SOLD, 2017 sti, 2003 tacoma TRD
Reverse lock out changed out
Hey guys. Has anyone been able to find a replacement pin for the reverse lock out. I believe the dimensions we need is 3/32 and inch in length. I can find the correct size but not length. Any help would be appreciated!
iLoveMySubi93 is offline   Reply With Quote
Old 04-08-2016, 04:35 AM   #2
tracerit
Drives: '13 SSM BRZ Limited 6MT
I thought it was a different diameter but I don't have an accurate way to measure.
But if it is 3/32" them this place has it.
https://www.fastenal.com/products/fasteners/pins/dowel-pins?r=~|categoryl1:"600000%20Fasteners"|~%20~|cat egoryl2:"600108%20Pins"|~%20~|categoryl3:"600111%2 0Dowel%20Pins"|~%20~|attrdiameter:110|~%20~|attrle ngth:1250|~
You want to be the guinea pig? Haha. Actually there's a store right next to me, I'll give them a call sometime to see if they carry it in store.
tracerit is offline   Reply With Quote
Old 04-08-2016, 04:56 AM   #3
iLoveMySubi93
actually found a home depot that carries it. gonna try it out. what size did u think it was?
Old 04-08-2016, 05:24 AM   #4
tracerit
Nice, please update if it does work. That'd be awesome.
I measured it at 1/16th with a crappy ruler.
Old 04-08-2016, 06:33 AM   #5
iLoveMySubi93
well do. let you know tmmr.
Old 04-08-2016, 09:41 AM   #6
Ashikabi
Ashikabi's Avatar
Why don't you just reuse the one you have? Or the dealer?
Old 04-08-2016, 10:18 AM   #7
tracerit
I believe he mentioned in another thread that he lost it. In my case, mine is all mangled up.
Old 04-08-2016, 11:17 AM   #8
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
i might have a spare set. ill check when i get home
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 04-08-2016, 03:27 PM   #9
iLoveMySubi93
update
so i got it and 3/32 does fit the oem one. but for some damn reason it doesnt go into my perrin one as smoothly. either i am an idiot or the perrin lock out trollin me.
The Following User Says Thank You to iLoveMySubi93 For This Useful Post:
tracerit (04-08-2016)
Old 04-08-2016, 03:34 PM   #10
Ashikabi
Ashikabi's Avatar
You get a dowel pin or spring pin? Oem is plastic perrin is aluminum. Maybe hole has tooling marks that are catching
Old 04-08-2016, 03:51 PM   #11
iLoveMySubi93
re
i got a tension pin and thats what i assumed the oem one is by look/memory since i lost it. maybe ill have to check. thx for suggestion
Old 04-08-2016, 03:55 PM   #12
Ashikabi
Ashikabi's Avatar
Oem is a spring/tension pin
The Following User Says Thank You to Ashikabi For This Useful Post:
iLoveMySubi93 (04-08-2016)
Old 04-08-2016, 04:07 PM   #13
iLoveMySubi93
yeah so idk what the heck is going on because the tension pins i bought fit directly into the oem lock out. but doesnt fit into the perrin one -__-
Old 04-08-2016, 04:09 PM   #14
Ashikabi
Ashikabi's Avatar
Does perrin use grub screws instead?
Perrin WRX STI reverse lock out..NEW no box BRZeer Miscellaneous 2 12-18-2014 03:43 PM
Question for those who have changed the reverse lockout AllStar0419 Cosmetic Modification (Interior/Exterior/Lighting) 5 11-04-2014 11:25 PM
Reverse lock out adjustment nfaj Engine, Exhaust, Transmission 10 10-03-2014 10:46 AM
Perrin Reverse Lock BRZ615 Interior Parts (Incl. Lighting) 3 08-07-2014 02:02 AM
Reverse lock out diameter? Moddiction BRZ First-Gen (2012+) — General Topics 6 09-01-2012 12:04 PM
