| Southern California SoCal |
Drives: BRZ SOLD, 2017 sti, 2003 tacoma TRD
Reverse lock out changed out
Hey guys. Has anyone been able to find a replacement pin for the reverse lock out. I believe the dimensions we need is 3/32 and inch in length. I can find the correct size but not length. Any help would be appreciated!
#2 |
Drives: '13 SSM BRZ Limited 6MT
I thought it was a different diameter but I don't have an accurate way to measure.
But if it is 3/32" them this place has it. https://www.fastenal.com/products/fasteners/pins/dowel-pins?r=~|categoryl1:"600000%20Fasteners"|~%20~|cat egoryl2:"600108%20Pins"|~%20~|categoryl3:"600111%2 0Dowel%20Pins"|~%20~|attrdiameter:110|~%20~|attrle ngth:1250|~ You want to be the guinea pig? Haha. Actually there's a store right next to me, I'll give them a call sometime to see if they carry it in store. |
#3 | |
#4 |
#5 |
#6 |
Why don't you just reuse the one you have? Or the dealer?
#7 |
#8 |
Turbo E85
Drives: 13 wrb brz
i might have a spare set. ill check when i get home
Flex Fuel Turbo BRZ
#9 |
update
| The Following User Says Thank You to iLoveMySubi93 For This Useful Post: | tracerit (04-08-2016) |
#10 |
You get a dowel pin or spring pin? Oem is plastic perrin is aluminum. Maybe hole has tooling marks that are catching
#11 |
re
#12 |
| The Following User Says Thank You to Ashikabi For This Useful Post: | iLoveMySubi93 (04-08-2016) |
#13 |
#14 |
Does perrin use grub screws instead?
| Perrin WRX STI reverse lock out..NEW no box | BRZeer | Miscellaneous | 2 | 12-18-2014 02:43 PM |
| Question for those who have changed the reverse lockout | AllStar0419 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 11-04-2014 10:25 PM |
| Reverse lock out adjustment | nfaj | Engine, Exhaust, Transmission | 10 | 10-03-2014 09:46 AM |
| Perrin Reverse Lock | BRZ615 | Interior Parts (Incl. Lighting) | 3 | 08-07-2014 01:02 AM |
| Reverse lock out diameter? | Moddiction | BRZ First-Gen (2012+) — General Topics | 6 | 09-01-2012 11:04 AM |
