Drives: 2015 FR-S
Turbo kit directly from Subaru
I have an FR-S.
The other day I was was at a local Subaru dealer to get a Footwell lighting kit and got to talking to one of the service managers about forced induction. He mentioned that since I have an FA20 engine and the same engine goes into the Subaru forester (FA20 + turbo) that it was possible to buy all the additional parts in order to bolt on a Subaru turbo kit to the FR-S. I've attempted to Google this and search the forums but did not find anything. In theory his idea sounds plausible. Has anyone tried this? Would additional changes be necessary such as maybe stronger pistons, etc.? He was not certain but mentioned the parts to be around $1800, which sounds a bit low. He also mentioned that they could do they work, but only for out of warranty vehicles. Thought/Comments? |
| The Following User Says Thank You to rzpld4 For This Useful Post: | MisterSheep (04-08-2016) |
#2 |
Drives: 13 BRZ SSM
Stock for stock it won't fit for many reasons. Better off buying an aftermarket turbo kit designed for the twins.
http://www.ft86club.com/forums/showthread.php?t=69032 |
| The Following User Says Thank You to turbocat For This Useful Post: | MisterSheep (04-08-2016) |
#3 | |
$1800 for what? just the turbo? I think he is missing a zero in there. Yeah sure they can do the work, but you want mechanics who work on stock cars all day to work on your modified vehicle? The guy is just pulling your leg. Ask him to make a quote for parts and labor, see how fast he disappears or makes excuses. |
| The Following User Says Thank You to swarb For This Useful Post: | Calum (04-08-2016) |
#4 |
#5 |
Junior
Drives: a car
nnnnnnnnnnnope!
#6 |
Drives: car
It's worrying when service managers start to make claims like these.
| The Following 5 Users Say Thank You to radroach For This Useful Post: | Calum (04-08-2016), go_a_way1 (04-07-2016), MisterSheep (04-08-2016), MrFisty (04-08-2016), Summerwolf (04-08-2016) |
#7 |
Drives: Late 2014 Subaru BRZ
Time to find a different dealer. The FA20 in the frs/brz is entirely different. All the way from the ecu to fuel system. Not to mention the exhaust exits to the other side of the motor. The wrx or legacy also uses a different oil pump, rods, pistons, cams and so on.
I personally started over a year ago thinkong a $6400 kit was possible and now I'm nearly 10k doing it all myself. So many supporting mods was required to make the car a daily driver it's nutz. If you don't have atleast 10k for the kit, supporting mods and tune. Quit
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#8 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
LOL I say OP takes the car and lets them do it and once they realise they are wrong he can fight them (provided he gets the quote to install a turbo on paper) and get them to make it work for $1800 at the expense of his warranty
| The Following User Says Thank You to go_a_way1 For This Useful Post: | MrFisty (04-08-2016) |
#9 |
Sarcastic SOB
The service writer doesnt know shit.
#10 |
Drives: whiteout, dark tint
I say do it, service manger sounds like he totally knows what's involved with converting a factory N/A engine to a turbocharged one. 10/10 would recommend
#11 |
Drives: BRZ + Ducati M796
People would swap the head of the 2jzgte to the block of the 2jzge. The only differences with the blocks were oil squirters for the pistons on the turbo block. This was done to save money in cases where this could be an option. Everything from the top was different. Maybe the blocks on the FA20 are the same but you would need everything else in the engine bay except the battery and fans--maybe a few other items. But what he proposed is ridiculous. There is no savings here.
#12 |
That Guy
Drives: 2013 asphalt FRS MT
I'd have a lot of fun with the service manager.
| The Following User Says Thank You to Calum For This Useful Post: | cdrazic93 (04-08-2016) |
#13 |
Drives: '15 BRZ RA
Someone in Austria did the swap. He imported a brand new fa20dit engine from Japan. Issue was that he couldn't get any certifications and the car wasn't road legal. From my point of view, it doesn't worth it.
#14 |
Panda Trueno
Drives: No twin now.
Do it, through them! They must know something everyone else doesn't.
A+ Service manager. |
| Tags |
| subaru turbo fr-s |
| Does the Mfactory 4.67 FD directly fit into stock Dif? | JiB | Engine, Exhaust, Transmission | 1 | 09-03-2013 01:47 PM |
| Slot directly in front of shifter ... | pwnisher | Scion FR-S / Toyota 86 GT86 General Forum | 67 | 07-28-2013 04:36 AM |
| EVO: Subaru BRZ vs Subaru Impreza 2000 Turbo review | Hachiroku | BRZ First-Gen (2012+) — General Topics | 79 | 03-01-2013 05:19 PM |
| Check Engine Light directly after pickup | Stu L Tissimus | BRZ First-Gen (2012+) — General Topics | 27 | 06-15-2012 06:07 PM |
| LEDs that convert heat directly into light... | serialk11r | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 03-10-2012 01:08 PM |
