Old 01-11-2016, 04:33 PM   #29
swarb
Originally Posted by x18999 View Post
Any spacers would make the wheel poke out of the fender which would cause rubbing on the fender and look terrible.
Not entirely true.
I'm on 9.5 +34, lowered, don't rub, and it looks fine.
It does poke, but not that much, and I have 2.9 camber so it looks fine.
Please don't give misinformation. 8-10mm spacers on +45 would make it +35/+37ish which MOST people running 9.5 widths are running. So yeah they fit with minor poke depending on camber.
With that said, you probably need coil overs if you want to run 9.5 widths and want little to no poke.
Old 01-11-2016, 04:46 PM   #30
x18999
Originally Posted by swarb View Post
Not entirely true.
The information I provided is NOT misinformation for this specific wheel on the vehicle.
The fact is that the wheels will poke out of the fenders. Whether it looks acceptable is subjective...
Unless if you keep the ride height very high, the spring/strut travel up/down over bumps will cause the tire to hit the fender.
Most people wouldn't want to run -2.9 camber on a street car...
x18999 is offline   Reply With Quote
Old 01-11-2016, 08:16 PM   #31
SHIFTEVO
Drives: Lightning Red
Originally Posted by PEWPEW View Post
Lol nice
SHIFTEVO is offline   Reply With Quote
Old 01-25-2016, 06:02 PM   #32
cocaine_coupe
Drives: ft86
Enkei Raijin 18x9.5 +45 with 255/35/18 Bridgestone Potenza S04 tires lowered on ST coilovers.
Any camber adjustments?
cocaine_coupe is offline   Reply With Quote
Old 02-20-2016, 05:58 PM   #33
x18999
Just the slotted hole on the strut tower. I don't have any camber plates.
Old 04-02-2016, 12:49 PM   #34
bink
Wheel Color
What color are the wheels? Gunmetal or hyper silver? Great looking car!
bink is offline   Reply With Quote
Old 04-04-2016, 10:40 AM   #35
x18999
The color is hyper silver with a light coating of brake dust.
Old 04-04-2016, 08:48 PM   #36
bink
Thanks. How do you like the ST coilovers? Would you recommend them?
Old 04-09-2016, 10:55 PM   #37
Drue
Drue's Avatar
Drives: 2013 BRZ Limited
18x9.5 all around, 255/35 Nitto Invo's, Fortunte auto coilovers, spl lca's.
Drue is offline   Reply With Quote
The Following User Says Thank You to Drue For This Useful Post:
bhbnuckle (04-14-2016)
Old 10-02-2016, 01:43 AM   #38
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
@x18999 @DCStorm @loogs @Scaldy @Drue
For the guys who haven't adjusted caster (no front LCAs nor top hats), do you experience faint rubbing when you turn full lock (and worse when full lock on uneven ground)?
I'm on ST coilovers, -2.0 front camber with 18x9.5 +45 wheels and found signs of slight rubbing in my front wheel wells.
Old 02-15-2018, 12:59 PM   #39
Greenbean
Drives: 2017 series yellow BRZ
BBK fitment
Does anyone know if the raijin 18x9.5+45 will fit over the bbk's in the front and rear. I would want to get these wheels if they fit.
Greenbean is offline   Reply With Quote
Old 04-01-2019, 10:51 PM   #40
deku
Drives: 2017 subaru brz red, 93 FD RX7
anyone know if 18x9.5 +45 w/ 255/35 tires staggered with 18x8.5 +45 w/ 235/40 tires would fit the pp brembos? im looking to buy a set of wheels w/tires and want to find out before i drive out of state to pick up.
deku is offline   Reply With Quote
Wheel Directory: Enkei NT-03M 18x9.5 +40 Touge Factory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 140 12-08-2021 01:15 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 11:30 AM
Wheel Directory: Enkei Raijin 18x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 03-30-2018 12:37 PM
Wheel Directory: Enkei Raijin 18x8.5 +45 SWPBRZ415 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 62 11-28-2016 04:51 PM
Wheel Directory: Enkei Raijin 18x8.0 +40 / 18x9.5 +45 seanmc69 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-08-2013 01:38 PM
