| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 | |
I'm on 9.5 +34, lowered, don't rub, and it looks fine. It does poke, but not that much, and I have 2.9 camber so it looks fine. Please don't give misinformation. 8-10mm spacers on +45 would make it +35/+37ish which MOST people running 9.5 widths are running. So yeah they fit with minor poke depending on camber. With that said, you probably need coil overs if you want to run 9.5 widths and want little to no poke. |
#30 | |
The fact is that the wheels will poke out of the fenders. Whether it looks acceptable is subjective... Unless if you keep the ride height very high, the spring/strut travel up/down over bumps will cause the tire to hit the fender. Most people wouldn't want to run -2.9 camber on a street car... |
#31 |
Drives: Lightning Red
#32 |
Drives: ft86
#33 |
#34 |
Wheel Color
#35 |
#36 |
#38 |
Glorious BRZ Master Race
Drives: Subaru Libird
@x18999 @DCStorm @loogs @Scaldy @Drue
For the guys who haven't adjusted caster (no front LCAs nor top hats), do you experience faint rubbing when you turn full lock (and worse when full lock on uneven ground)? I'm on ST coilovers, -2.0 front camber with 18x9.5 +45 wheels and found signs of slight rubbing in my front wheel wells.
#39 |
Drives: 2017 series yellow BRZ
BBK fitment
Does anyone know if the raijin 18x9.5+45 will fit over the bbk's in the front and rear. I would want to get these wheels if they fit.
#40 |
Drives: 2017 subaru brz red, 93 FD RX7
anyone know if 18x9.5 +45 w/ 255/35 tires staggered with 18x8.5 +45 w/ 235/40 tires would fit the pp brembos? im looking to buy a set of wheels w/tires and want to find out before i drive out of state to pick up.
| Wheel Directory: Enkei NT-03M 18x9.5 +40 | Touge Factory | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 140 | 12-08-2021 01:15 AM |
| Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 | GuerillaRacing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 221 | 08-01-2019 11:30 AM |
| Wheel Directory: Enkei Raijin 18x8.0 +45 | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 66 | 03-30-2018 12:37 PM |
| Wheel Directory: Enkei Raijin 18x8.5 +45 | SWPBRZ415 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 62 | 11-28-2016 04:51 PM |
| Wheel Directory: Enkei Raijin 18x8.0 +40 / 18x9.5 +45 | seanmc69 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 07-08-2013 01:38 PM |
