Old 04-01-2016, 04:21 PM   #29
steve99
Drives: FT86
Originally Posted by choiboie View Post
so before I hooked it up to my car.i made sure to update the oft from my laptop.after that.i did the normal install..plug in oft.turn ignition to on. Pick gt86. Then read..it'll keep getting this error
Sent from my SM-G920V using Tapatalk
With oft disconnected from car, remove battery terminal , press brake pedal, reconnect battery terminal. Reconnect of and try again
Old 04-01-2016, 04:29 PM   #30
choiboie
Drives: 2013 Fr-S UltraMarine
I did the battery reset
choiboie is offline   Reply With Quote
Old 04-01-2016, 04:29 PM   #31
choiboie
So I have to press the brake pedal?
Old 04-01-2016, 04:32 PM   #32
steve99
Drives: FT86
pressing brake just bleeds off any residual power
Old 04-01-2016, 04:38 PM   #33
choiboie
K
Old 04-01-2016, 04:38 PM   #34
eggncheese
Drives: 2013 Ultramarine Scion FRS MT
@choiboie: Did you fully turn the ignition to the ON position and not just ACC mode?
eggncheese is offline   Reply With Quote
Old 04-01-2016, 04:39 PM   #35
choiboie
Yes sir full on
Old 04-01-2016, 04:50 PM   #36
eggncheese
Any luck?
Old 04-01-2016, 04:50 PM   #37
choiboie
Still getting same error
Old 04-01-2016, 04:51 PM   #38
choiboie
Off guys told me to take it dealer and check ecu..I bought the car used with 32k
Old 04-01-2016, 04:51 PM   #39
choiboie
Gotta wait till tuesday
Old 04-01-2016, 05:17 PM   #40
choiboie
wish i had a new car. i dont think i would be running into this problem. possible this car was already tuned. ecutek?
Old 04-01-2016, 06:00 PM   #41
choiboie
i realized i only disconnected the battery for like 30 seconds. i'm going to try and leave it off for like 5 mins or more than try again and i'll report crossing my fingers!!!
Old 04-01-2016, 06:07 PM   #42
steve99
Drives: FT86
Is it possible car has a previous BRZEdit or Ecutek tune ? as both those systems lock ecu.
but you should be able to read diagnostics or ecu info, the lock should only effect read/write of a tune file.
if it wont read diagnostic or ecu info then might be problem with obd port, check if any pins pushed back in obd socket in car.
if you have another obd device like android torque or obd reader does that work ?
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
R/T Tuning & R/T Tuning Speed Shop Review Thread R/T Tuning User/Vendor/Sponsor Reviews, Feedback, Comments 37 10-03-2014 02:23 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
