Old 03-30-2016, 01:43 PM   #1
RavenFish
Drives: 2016 Raven FR-S
Eibach Sportline's or ST Coilovers
My Budget is tight seeing as I am in college working everyday to get my car where i want it to be, but i have one question for you guys. Are coilovers a better option or the springs.
RavenFish is offline   Reply With Quote
Old 03-30-2016, 01:44 PM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Depends on what you want to do with the car. If you never plan on taking it to the track then springs are the better way to go.
Instagram: trevor.parque
Old 03-30-2016, 01:48 PM   #3
RavenFish
Alright man thanks for the input!
Old 03-30-2016, 01:52 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
My suggestion get Eibach pro kit springs. Not sportlines. Or get coilovers. It is my opinion after reading through this forum, that sportlines are too low for stock shocks. You can upgrade the shocks to either Koni or Bilstein and use the sportlines, but you are only gaining .4 inch. For overall looks and driving feel, I feel money is better used buying different tires and wheels. Or just better tires and spacers.
MisterSheep (03-30-2016)
Old 03-30-2016, 01:52 PM   #5
MisterSheep
Killed Scion
If I can recommend that you should get the RCE yellow springs as they are the more comfortable spring and are highly well known to be a good spring option for this car.
Old 03-30-2016, 01:54 PM   #6
RavenFish
Does it have a larger drop?
Old 03-30-2016, 01:57 PM   #7
MisterSheep
Killed Scion
This is also a great option. Getting better performing tires that are stickier will help your car perform much better. Using the stock wheels also saves some weight as most of the aftermarket wheel option that are inexpensive are much heavier than stock.
Old 03-30-2016, 01:57 PM   #8
RavenFish
Exactly i have money for new wheels and tires but i want to drop my car before they go on and i don't know which way to go
The Following User Says Thank You to RavenFish For This Useful Post:
Old 03-30-2016, 01:59 PM   #9
MisterSheep
Killed Scion
It will not have as much of a drop as the eibach sportlines but those drop the car too much where they aren't good for the stock struts at all.
Old 03-30-2016, 02:00 PM   #10
MisterSheep
Killed Scion
I'm dropped on Tein springs with camber bolts and wheels and tires.
Old 03-30-2016, 02:02 PM   #11
RavenFish
Do you have any pictures?
Old 03-30-2016, 02:07 PM   #12
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
imo quality springs > budget coilovers on this car unless you know exactly what you're doing, the only factor that would change my opinion would be competitive autocross. I would not hesitate to track this car on any reputable aftermarket springs on street tires in OE-ish size, combine with Bilstein's or Koni's down the road and it's probably the best bang for the buck.
ST's seem to have a good reputation though, do whatever you want.
ineedyourdiddly
Old 03-30-2016, 02:13 PM   #13
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
^that
and sportlines are not quality springs
Old 03-30-2016, 02:25 PM   #14
RavenFish
^that
Alright I think I'm going to go into the coilover direction then because i really want a nice drop, what do you guys think about coilover options Tien, ST, BC
Eibach Sportline Springs Canehda Canada Classifieds 5 07-10-2015 07:09 PM
Cheap used Coilovers VS Eibach Sportline Spring SpeedR Tracking / Autocross / HPDE / Drifting 10 12-25-2013 07:44 AM
Eibach sportline ThatManAnt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-01-2013 01:20 PM
Eibach Pro-Kit vs Sportline itisthumper Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 01-03-2013 02:27 PM
