Old 03-29-2016, 10:31 AM   #1
Zan
Drives: 2015 WRB BRZ
Benefits of a Rocket Bunny Kit?
I've been doing research on this, but have not been able to come up with a solid answer. I've been looking into the RB V1 fenders, because when they are molded to the car, it gives the car a clean look, but the things I can not seem to find and I have been wondering are the following:
Does it live up to its name as an Aero Kit, or is it simply made for show cars. Is anyone actually tracking the car with this kit for Autocross and Track time, and with all the additional pieces needed (wheels, tires, possible suspension, etc.) how does it handle?
On the same note, how does it feel for daily driving? Does it still feel like the spirited car in the mountains most of us have come to know and love, or does it feel like a behemoth in a small package, where its uncomfortable to drive in canyon roads and isnt the little sporty car we've come to know and love?
The kit doesnt seem to add that much width to it, and with the added power of a FI set up, one would think that the extra width to give it some tires without going to crazy with camber would give it some benefits, but with new pros, comes new cons.
Every thread I've seen start going somewhere and then the haters and trolls come out. I'm not interested in your opinion of the appearance of the kit, I am more interested in the kit living up to what is claimed to be an Aero Kit, and thus its versatility for high speed performance and moderate speed canyon and mountain driving.
Thanks again
Zan is offline   Reply With Quote
Old 03-29-2016, 11:03 AM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
This kit has wider rear fenders than front fenders which means in order to have a "clean" or "flush" look you will be running a crazy wide staggered setup which will increase understeer. You will find on this forum that our cars perform much better with a squared setup and most people who are tracking seriously will most likely be using a squared setup over a staggered setup. Also in order to not run spacers you are looking at getting custom wheels with crazy wide tires. If you go anywhere above 245 or 255 (people will argue about this) it will be way too much tire for the stock powerplant of this car, which will cause you to want to go FI to accommodate getting wider tires. I cannot speak for rocketbunny owners because I do not have one but I bet you that they are running 265+ tires in the rear.
It will most definitely change the driving characteristics of the car simply because of the staggered setup and the change in how wide the tires are. Also it will not feel like the tiny little sports car that you can fit into any spot, it is now wider than before. Not to mention that your tires will be spitting up dirt/grime/ whatever is on the road onto your sideskirt and door because the tires stick out from the body.
Thanks again
Some answers to your questions in RED
Instagram: trevor.parque
go_a_way1 (03-29-2016)
Old 03-29-2016, 11:09 AM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Honestly I see no point in doing it.
I also feel like it would be worse for aero
nickmerronesucks (03-29-2016)
Old 03-29-2016, 11:11 AM   #4
Cole
Not a troll
Cole's Avatar
There are people who track with it. But, it's more of a scene points kit.
AFAIK, there is no aero benefit by going with it. And, you don't really need 11" wide wheels with 285 tires to get power to the ground with FI.
Cole is offline   Reply With Quote
The Following 7 Users Say Thank You to Cole For This Useful Post:
go_a_way1 (03-29-2016), kch (03-29-2016), MisterSheep (03-29-2016), Mr.ac (03-29-2016), nickmerronesucks (03-29-2016), raven1231 (03-29-2016), Summerwolf (03-29-2016)
Old 03-29-2016, 11:20 AM   #5
jasonojordan
Drives: 2013 satin white brz limited
Im running 265 on my rear without any kit what so ever. The 265 I have though are notoriously narrow. Im running 17x9
jasonojordan is offline   Reply With Quote
Old 03-29-2016, 11:21 AM   #6
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Another thing to think about, if you plan on molding the fenders to the body it becomes a very pricey operation, Could the "Aero" benefits gained from the rocketbunny kit ever equal say a Forced Induction kit (Costing Roughly the same as a molded RB kit?) or any other mods for the same price.
Absolutely not in a million years.
its for styling
VIP BRZ is offline   Reply With Quote
The Following User Says Thank You to VIP BRZ For This Useful Post:
Old 03-29-2016, 11:32 AM   #7
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
There's not going to be an appreciable benefit to aerodynamics. These cars are fairly low drag as it is, and adding more surface area isn't going to help you.
You're going to need large, near-0 offset wheels to not look ridiculous, which adds weight and rolling resistance (via large tires). You're also increasing the scrub radius, and further lowering the roll center (which OUGHT to be corrected, but many don't).
The big advantage that I've seen is that widebody kits will allow a wide angle steering kit to fit for a drift car. I suppose if you're trying to build a 500+ HP drift car, a RB kit would not be the worst way to go.
jawn is offline   Reply With Quote
The Following 2 Users Say Thank You to jawn For This Useful Post:
MisterSheep (03-29-2016), Summerwolf (03-29-2016)
Old 03-29-2016, 03:00 PM   #8
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
The primary benefit of the RB kit is visuals. if you're looking for anything other than that, you'll be disappointed. You can fit ultra wide tires with wide body, but the car is feather light which kind of eliminates the benefits of a giant contact patch.
Since switching over, I can tell you with certainty that the car still behaves like a normal car. I'm running 295 rear/255 front. The car drives in a straight line, doesn't pull out of the lane I'm in, and turns like a normal car would. Does it understeer now? More than likely it does at the limit, but I won't be searching for that on the street.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 2 Users Say Thank You to protpibe For This Useful Post:
Old 03-29-2016, 04:03 PM   #9
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Instagram doesn't care about aero.
headlikeahole is offline   Reply With Quote
The Following 6 Users Say Thank You to headlikeahole For This Useful Post:
Autocon (03-29-2016), Bach415 (03-29-2016), go_a_way1 (03-29-2016), Josue Cafe FR-S (06-21-2016), kch (03-30-2016), Mr.ac (03-29-2016)
Old 03-29-2016, 04:21 PM   #10
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Best answer I've seen so far
Bach415 is offline   Reply With Quote
The Following 2 Users Say Thank You to Bach415 For This Useful Post:
go_a_way1 (03-29-2016), headlikeahole (03-29-2016)
Old 03-29-2016, 04:22 PM   #11
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Agree!
Old 03-29-2016, 04:27 PM   #12
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
rocket bunny kits stop the cricket sound, fyi
The Following User Says Thank You to continuecrushing For This Useful Post:
Old 03-30-2016, 09:09 AM   #13
Ashikabi
Ashikabi's Avatar
Wide body doesn't provide Aero. It actually hurts aero but... it allows crazy wide wheels and other parts that may or may not be desirable for how you drive(ie drifting, track, etc). I could see it being very useful for autocross because aero is practically useless at those speeds but having super wide tires is pretty helpful. So as an "aero" kit, no, its useless. As a utility modification, yes, very helpful. As a show piece, imo yes, they look great. Be aware it will be costly and FI will give you more bang for the buck by a lot. In fact it wouldn't be hard to argue that you need FI to garner any benefit from widebody
rocket bunny v1 brz Kendallkab BRZ First-Gen (2012+) — General Topics 8 02-07-2016 11:47 AM
Rocket bunny Epic_integra Want-To-Buy Requests 1 06-22-2015 12:55 PM
Rocket bunny style DRL without the rocket bunny kit. ducky369 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-22-2014 06:38 PM
Vis rocket bunny kit FrsT86-671 Cosmetic Modification (Interior/Exterior/Lighting) 3 04-27-2014 09:33 AM
Oh hey, another Rocket Bunny! CanibeatNoel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 47 07-12-2013 11:08 AM
