#15 |
Drives: 2015 CWP BRZ Limited
| The Following 2 Users Say Thank You to jawn For This Useful Post: | Rifle (03-25-2016), Ultramaroon (03-25-2016) |
#16 |
EX-86 Supercharged God
Drives: '16 Series.HyperBlue BRZ
Are we friends on Facebook? Let me send you the video of the axle issue. I am not good with who is who in the forums.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ |
#17 | |
Drives: 10 Series FR-S #207
He has a supercharger, I'd love to see a dealership warranty that.....they won't if they want to keep their franchise. |
| The Following 2 Users Say Thank You to tCsonfrs For This Useful Post: | FRSBRZGT86FAN (03-29-2016), Tcoat (03-26-2016) |
#18 |
295WHP/220TQ |
#19 |
Axle? Doubt it. If there is nothing then you are not getting power to the diff. Does it change tones when you shift and just not move? If an axle the diff should scream like a banshee if it is being powered. Besides the odds against having both axles go at the precisely the same moment are incredible.
#20 | |
295WHP/220TQ |
#21 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
Late night guess...Quite possibly wrong....but the inner cv joint could easily break on just one axle. The inner cv joint most always being the weaker of the cv joints.
Edit: 11:48pm PDT....after reading this about helical and Torsen differentials: "Locking on throttle but requires both wheels to be on the ground"... from here: http://www.trak-life.com/basic-intro...erentials-lsd/ So if one axle or cv joint is broken, it's as if the wheel/tire on that side of the car is 'off the ground' And if the inner cv joint broke, chances are real good... it also tore open that axle boot (rubber). Last edited by ToySub1946; 03-26-2016 at 03:03 AM. |
#22 |
That was my thought. And per several different shops in the area and friends who broke axles, if one breaks the car is dead to the water. I'll check it in the morning.
295WHP/220TQ |
#23 |
"Thinking it might be axle.
Anyone have a guide to replace them/tips/plan of attack?" Best to check with others in the suspension section of this forum... if axle needs replacement. Not sure, me, what minimal parts of rear suspension need to come off to get outer end of an axle out. Surely most anyone would need at least a 1/2" air impact wrench with proper socket to easily get the axle nut off end of axle. The inner cv joint would surely just pop out of diff with a pry bar. It's typically held in with an exterior snap ring. Inner cv joint may be available separately, as a part, rather than purchasing entire axle assembly ?? Pics of rear end suspension >within< this older online section of Edmunds: http://www.edmunds.com/car-reviews/t...alkaround.html Last edited by ToySub1946; 03-26-2016 at 03:48 AM. |
#24 |
Turns out it was the axle. Driver side. Just picked up a new one from @Pure Automotive and will be putting it back on shortly!
Thanks to everyone who helped!
295WHP/220TQ |
| The Following User Says Thank You to Rifle For This Useful Post: | humfrz (03-26-2016) |
#25 |
Persona Non Grata
Drives: '15 BRZ (WRB)
If you can't get the car in the air, arrange a mirror that let's you see the drive shaft. Put it in 5th start the engine and release the clutch. If the drive shaft spins and the wheels don't it's in the rear end. If the DS doesn't spin it's the clutch.
Slow is smooth, and smooth is fast
#26 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Capt Spaulding (03-29-2016) |
#27 |
Boost Creep
Drives: 2016 HyperBlue BRZ
How dafuq you already break an axle?
Ugh I'm probably next. As a side note, I hope they didn't cut corners for 2016's axles... I mean I know they're shitty in the first place but that was stupid fast dude.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
#28 | ||
Thats exactly how it's removed it literally can be pryed off and on the rear diff Quote:
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | Rifle (03-29-2016) |
| Stiff to engage 1st/reverse from a stop after clutch install | mhiscott | Engine, Exhaust, Transmission | 94 | 07-19-2020 07:11 PM |
| Automatic transmission hard parking engage and disengage | nos145 | Issues | Warranty | Recalls / TSB | 21 | 09-18-2015 07:30 PM |
| Automatic Transmission Kick/Choke when shifting gears | Tech Gremlin | Engine, Exhaust, Transmission | 13 | 06-16-2015 01:54 AM |
| clutch won't fully engage/8000 miles small dent | stockscionfrs | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 10-14-2014 11:06 AM |
| Anybody change rear gears or trans gears yet? | ramosryan | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-13-2014 12:48 AM |
