Old 03-27-2016, 08:52 PM   #1
stevesnj
stevesnj's Avatar
Who makes the DI fuel pump?
Doing some research and curious if anyone knows who makes the pump? Thanks!
My 2016 Build thread
Old 03-27-2016, 09:51 PM   #2
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
I could be wrong, but taking a shot in the dark I would guess Denso.
EDIT: well after some research my guess was spot on. The stock pump is a Denso unit.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
The Following User Says Thank You to Drakiv For This Useful Post:
CSG Mike (03-28-2016)
Old 03-27-2016, 10:08 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Yup The pumps and assembly in the left and right sides of the fuel tank are made by Denso, wasn't able to get a part number though off the Denso website search tool but the toyota part number is SU00304154 . Not sure who makes the fuel pump in the engine bay for the DI system probably also denso but it's part number is SU003-05176
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Drakiv (03-27-2016)
Old 03-27-2016, 10:32 PM   #4
stevesnj
stevesnj's Avatar
Yeh I'm looking for the Engine mounted High Pressure pump manufacturer.
Old 03-27-2016, 11:30 PM   #5
FRSBRZGT86FAN
Yup that part number is SU003-05176
and this is what it looks like:
I'm assuming that sensor on top is mostly made by denso
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
Drakiv (03-27-2016), stevesnj (03-28-2016)
Old 03-28-2016, 01:15 PM   #6
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
The D4S components, including the fuel pump, are made by a subsidiary of Hapco. Why do you ask?
Edit, wow really? Bit of a parapraxis... Denso...
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 03-28-2016, 04:25 PM   #7
stevesnj
stevesnj's Avatar
To see if they are replaceable by some of the low noise pumps out there.
Old 03-28-2016, 06:01 PM   #8
FRSBRZGT86FAN
Well, looking at those pumps price wise they run $800-$1000 (the current OEM one is in that range) I don't know if that's a value proposition to quiet the crickets down. You could attempt insulation the pump somehow with some sort of foam spray or something no one on the forum has attempted that. But also we know right now 2 things that lead to the chirp:
1) Ethanol- causing cavitation
2) Oil temps- because this pump runs off 3 camshaft lobs it is subjective to oil temperature, people found running an oil cooler stops the cricket sounds for a period of time. So if you could average temps below 205 F I guess it wouldn't appear as often.
But personally I don't think it's that big of a deal, someone like me wouldn't even worry about it and just chalk it up to a quirk if you can find a pump used on another subaru vehicle and whether or not it chirps and still is used for DI then you could probably get that if it bothers you so much.
HunterGreene (03-28-2016), stevesnj (03-28-2016)
Old 03-28-2016, 06:11 PM   #9
Aozora.BRZ
Aozora.BRZ's Avatar
Drives: '15 WRB Series.Blue
Made By:
Aozora.BRZ is offline   Reply With Quote
The Following User Says Thank You to Aozora.BRZ For This Useful Post:
Old 03-28-2016, 07:52 PM   #10
Drakiv
Project Shadow
Drakiv's Avatar
Pretty sure its actually a Denso unit and not a Kyosan unit. That's the only subsidiary that Denso and Toyota has holdings in that I can remember. And none of their pumps look like the ones our cars have. Sorry, but I'm pretty sure its a straight Denso unit dude.
614whp/421tq on E85
Instagram: Drakiv
The Following 2 Users Say Thank You to Drakiv For This Useful Post:
FRSBRZGT86FAN (03-28-2016), stevesnj (03-28-2016)
Old 03-28-2016, 08:28 PM   #11
FRSBRZGT86FAN
Where did you hear that? I literally looked through the service manual to find the part numbers and manufacturer, definitely not hapco
Old 03-28-2016, 09:40 PM   #12
Drakiv
Project Shadow
Drakiv's Avatar
OP if you are just looking for ways to rid yourself of crickets, I would suggest just trying a bottle of marvel mystery oil in with your gas to help lube the plunger in the pump. That's the stuff those rotary guru's swear by, including myself. It won't be a one and done fix but it should help for a while until you have to use it again. I know others have used the lucas fuel lubricant and have had pretty good results. But again it's something you will most likely have to use like every oil change or something.
614whp/421tq on E85
Instagram: Drakiv
Old 03-28-2016, 09:43 PM   #13
Spartarus
...Just add nauseum
Spartarus's Avatar
I actually didn't mean to type Hapco...
-Spartarus
Old 04-20-2016, 12:53 AM   #14
Sargy
Long Distance Driver
Sargy's Avatar
Although the noise dosent bother me (had it since day 1), I had a rather abnormal sound coming from it this time. Almost like a grinding deteriorating sound beyond imagination hah. Performance not affected. No videos but parts are on order. been on straight E85 for the last 30k+ miles.
http://www.trdshop.com/oe-toyota/su00306089
This replaces the previous 2 listed on their website. New part numbers everytime it seems.
Sargy is offline   Reply With Quote
Fuel pump? ScoobySubie14 Issues | Warranty | Recalls / TSB 1 03-15-2016 01:18 AM
WTB:OEM Fuel Pump willharp360 Want-To-Buy Requests 2 02-12-2016 04:00 AM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 04:52 PM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 11:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
