Old 03-26-2016, 12:07 AM   #1
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Weird noise over 3500 rpm
I dont know if anyone has experience this...
when i accelerate over 3500 rpm,,i start hearing a noise like
a louder version of HPFP sound, or a very small loosing metal moving so fast. It is noticable from the steer wheel/dash area. It is not the high pitch sound.
When I let go my gas,,the sound stop. When i press the gas over 3500rpm,,it happens again. I just had my service 3 weeks ago, and everything is fine.
Does any one experience this? Is it a big problem? Because i have a invidia N1 exhaust and i still hear it.
I am sorry if i post on a wrong section. I dont know where i can post this.
FR-Sky is offline   Reply With Quote
Old 03-26-2016, 12:12 AM   #2
I bet it's the clutch return spring inside the master cylinder. I could not figure out the noise, sounded like engine to me and actually had me pretty worried until I stumbled onto an old thread.
Next time while it's doing it, tap the clutch pedal a little. Should just quit -poof-
humfrz (03-26-2016)
Old 03-26-2016, 12:16 AM   #3
FR-Sky
FR-Sky's Avatar
so you mean next time when i gas over 3500rpm,,tap the clutch pedal and its over?!
Old 03-26-2016, 12:17 AM   #4
If that's what it is, yup. I yelled out "sonofabitch!" when I discovered it for myself.
FR-Sky (03-26-2016)
Old 03-26-2016, 12:23 AM   #5
FR-Sky
FR-Sky's Avatar
I will try to do it now. I hope it will fit like that....because it only happens occasionally....
Do i hold the gas over 3500 and tap the clutch, or gas over 4500, let go of the gas and do it??@@
Noted: but it doesnt have the sound before 3500 rpm
many thanks.
Old 03-26-2016, 12:27 AM   #6
many thanks.
I'm more confident now that you say it happens only occasionally. It's about the right frequency too - 3500-4000 RPM.
Just tap the clutch pedal a little while it's loudest. If that's what it is, it will be obvious. It's like finding any old rattle, touch it and it disappears.
FR-Sky (03-26-2016)
Old 03-26-2016, 12:32 AM   #7
fitcious
Are you sure it ain't the turbo spooling up? Or possibly VTEC?
fitcious is offline   Reply With Quote
Old 03-27-2016, 07:57 PM   #8
FR-Sky
FR-Sky's Avatar
Update: well seems like its happens occasionally again,and i tried to tap the clutch and it doesnt fix right away =/.
it only happens on 2nd and 3rd gear,,3500-4000rpm =[
The Following User Says Thank You to FR-Sky For This Useful Post:
Ultramaroon (03-27-2016)
Old 03-27-2016, 08:09 PM   #9
stevesnj
stevesnj's Avatar
when i accelerate over 3500 rpm,,i start hearing a noise....
It's called...
My 2016 Build thread
Old 03-27-2016, 08:19 PM   #10
FR-Sky
FR-Sky's Avatar
Originally Posted by stevesnj View Post
It's called...
lol....i wish
i have an invidia n1,,and i still can hear the noise...
stevesnj (03-27-2016)
Old 03-27-2016, 08:22 PM   #11
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
It's probably a metal piece vibrating. Have the car on the lifter and see if something's not fasten properly. What was serviced 3 weeks ago?
krayzie is offline   Reply With Quote
Old 03-27-2016, 08:31 PM   #12
Damn, well, it was a shot. Can you record a clip?
Old 03-27-2016, 08:47 PM   #13
ajaxthebetter
Drives: 2014 Subaru BRZ LTD 6MT
I have a creak like noise in that rpm range. Generally 2nd and 3rd gear. Maybe present in higher gears as well, though everything gets pretty loud. I first noticed it last summer, driving with the windows down. IE, I bought the car new (150 miles) in February.
It only happens when I dip into the throttle. Just a creak/squeak sound. It can also be with a rev match downshift in that range with the clutch fully depressed. It happens every time. I kind of just figured it was something mechanical in the engine. I reckon I ought to set up an appointment at some time or another. The nearest Subaru dealer is like an hour away, thus me putting it off.
ajaxthebetter is offline   Reply With Quote
The Following User Says Thank You to ajaxthebetter For This Useful Post:
FR-Sky (03-27-2016)
Old 03-27-2016, 08:50 PM   #14
FR-Sky
FR-Sky's Avatar
i will try to find a empty place and record...i cant do it around the neighborhood with N1 noise....
you are not along bro,,keep me update after u visit subaru.
for my case,,it doesnt happen on high gear tho,,
only 2nd/3rd 3500rpm +
Weird Chain Noise? megamarines Engine, Exhaust, Transmission 9 08-28-2015 03:53 AM
help!! weird humming noise?? sid94 Issues | Warranty | Recalls / TSB 3 05-17-2014 01:16 PM
Weird Noise FloridaBRZ BRZ First-Gen (2012+) — General Topics 7 04-25-2014 09:35 PM
Weird Noise??? caradd Issues | Warranty | Recalls / TSB 3 11-02-2013 12:42 AM
Weird noise Touge_ninja Scion FR-S / Toyota 86 GT86 General Forum 3 08-28-2012 02:46 AM
