Drives: 2013 FR-S 10 series [755]
Weird noise over 3500 rpm
I dont know if anyone has experience this...
when i accelerate over 3500 rpm,,i start hearing a noise like a louder version of HPFP sound, or a very small loosing metal moving so fast. It is noticable from the steer wheel/dash area. It is not the high pitch sound. When I let go my gas,,the sound stop. When i press the gas over 3500rpm,,it happens again. I just had my service 3 weeks ago, and everything is fine. Does any one experience this? Is it a big problem? Because i have a invidia N1 exhaust and i still hear it. I am sorry if i post on a wrong section. I dont know where i can post this. |
#2 |
I bet it's the clutch return spring inside the master cylinder. I could not figure out the noise, sounded like engine to me and actually had me pretty worried until I stumbled onto an old thread.
Next time while it's doing it, tap the clutch pedal a little. Should just quit -poof-
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (03-26-2016) |
#3 | |
#4 |
If that's what it is, yup. I yelled out "sonofabitch!" when I discovered it for myself.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | FR-Sky (03-26-2016) |
#5 | |
Do i hold the gas over 3500 and tap the clutch, or gas over 4500, let go of the gas and do it??@@ Noted: but it doesnt have the sound before 3500 rpm many thanks. |
#6 | |
Just tap the clutch pedal a little while it's loudest. If that's what it is, it will be obvious. It's like finding any old rattle, touch it and it disappears.
#7 |
Are you sure it ain't the turbo spooling up? Or possibly VTEC?
#8 | |
it only happens on 2nd and 3rd gear,,3500-4000rpm =[ |
| The Following User Says Thank You to FR-Sky For This Useful Post: | Ultramaroon (03-27-2016) |
#9 |
It's called...
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#10 |
| The Following User Says Thank You to FR-Sky For This Useful Post: | stevesnj (03-27-2016) |
#11 |
Drive From Home
Drives: BRZ STI Performance
It's probably a metal piece vibrating. Have the car on the lifter and see if something's not fasten properly. What was serviced 3 weeks ago?
#12 |
Damn, well, it was a shot. Can you record a clip?
#13 |
Drives: 2014 Subaru BRZ LTD 6MT
I have a creak like noise in that rpm range. Generally 2nd and 3rd gear. Maybe present in higher gears as well, though everything gets pretty loud. I first noticed it last summer, driving with the windows down. IE, I bought the car new (150 miles) in February.
It only happens when I dip into the throttle. Just a creak/squeak sound. It can also be with a rev match downshift in that range with the clutch fully depressed. It happens every time. I kind of just figured it was something mechanical in the engine. I reckon I ought to set up an appointment at some time or another. The nearest Subaru dealer is like an hour away, thus me putting it off. |
| The Following User Says Thank You to ajaxthebetter For This Useful Post: | FR-Sky (03-27-2016) |
#14 | ||
for my case,,it doesnt happen on high gear tho,, only 2nd/3rd 3500rpm + |
| Weird Chain Noise? | megamarines | Engine, Exhaust, Transmission | 9 | 08-28-2015 03:53 AM |
| help!! weird humming noise?? | sid94 | Issues | Warranty | Recalls / TSB | 3 | 05-17-2014 01:16 PM |
| Weird Noise | FloridaBRZ | BRZ First-Gen (2012+) — General Topics | 7 | 04-25-2014 09:35 PM |
| Weird Noise??? | caradd | Issues | Warranty | Recalls / TSB | 3 | 11-02-2013 12:42 AM |
| Weird noise | Touge_ninja | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-28-2012 02:46 AM |
