#1009 | |
Drives: 2013 Scion FR-S - Argento
#1010 | |
Drives: FR-S 10 Series
Did you also do the tape to cover the gap between the light and the sheet metal as mentioned earlier? |
#1011 |
Drives: 2015 BMW 335i M Sport, 2004 Z06
Does anyone know if there's a TSB that covers this issue? I'm looking at an FRS that is used and outside of the 3yr/36k warranty. The pics show no condensate in the tail light but definitely wet around the edges of the light, at least that's what it appears to be.
If it's out of warranty and I have to buy new lights that can't be cheap. If Toyota will still fix it I won't sweat it. |
#1012 | |
Drives: Asphalt FR-S
#1013 | |
Drives: 2023 Toyota GR86 Premium
I personally tested a variety of silicones and adhesives before going with the 3M Superstrength Weatherstrip Adhesive. It was the best combination of ease of application, seal, longevity, flexibility, and price. I personally haven't seen or heard of anyone with any issues with it drying out, some of which are going on 3+ years of use.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
#1014 |
Drives: FRS
Last I heard, the known defect (TSB) acknowledges only over tightening of the bolts through the gasket, warping the mounting surface allowing water entry. Corporate has not admitted the design mistake allowing the assaultive eroding water flow. I haven't seen anything addressing the engineering flaw with the new twins. Anyone opened the trunk on a new twin to see the design flaw fixed ? |
#1015 |
that's just the blinker fluid
#1016 | |
Bottom line, a TSB is not the same as a recall which is covered regardless of mileage. Interestingly enough, mine dried out over the winter and has not repeated since then. I purchased new/better gaskets but have not installed them. Probably should get around to doing that.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#1017 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
Just bought my car nearly a month ago, and noticed the right rear light has condensation on the top portion where the plastic flattens out horizontally. I'm going to contact the dealer to get this replaced under warranty. You'd think the last year of the car before the facelift/rebadge/tweaks would have worked this issue out by now.
#1018 | |
#1019 |
Sittin' Sideways
So it is a possibility that it'll happen again on a replacement piece? Does it just require a DIY resealing that'll outlive the car? Lol
-O/D
2016 FR-S, Hot Lava |
#1020 |
Drives: 2016 STI DGM
Figured I'd post my experience... I got my car in 2012 and had condensation in both lights. Dealer replaced the passenger side under warranty; however, the drivers side of course didn't decide to have any the day I got the work done. The one replaced has remained ok; however, my drivers side is getting worst. Looks like I'll be going to Tom's for replacements like others have done.
Subaru STI :![]() |
#1021 |
March and April has been rainy enough to finally confirm: after driving through several hours of light to heavy downpour the past 2 months (including an hour of rain driving home tonight), I NO LONGER HAVE CONDENSATION in my original OEM tail lights!!!
After 4 and half years, I can finally enjoy sliding my car around in the rain without getting condensation in my tail lights! Whoohoo! ![]() It just goes to prove.. sometimes if you ignore a "trivial" problem, it actually does go away! ![]() Seriously though, I have no idea why this is the case. I'm guessing there's probably so much gunk built up around the gasket area, no more water can get in lol |
#1022 | |
Driver
Drives: Black 2013 BRZ
| Red tail light photoshops | OwenK | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 68 | 02-06-2013 03:48 PM |
| HKS head and tail lamps | DIG1992 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-19-2012 01:04 PM |
| Tail of the Dragon | Tomcat9700 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 02-10-2012 02:30 PM |
| headlight condensation | MRZ415 | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 01-23-2012 02:24 AM |
| Optional coloured tail lights? | m_life | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-30-2011 06:20 PM |
