Old 03-14-2016, 07:30 PM   #2605
nrevbay
Drives: 2015 Scion FR-S AT
Anybody have this mod with a stock car?
Seems like it was originally designed just for that (stock car), which is exactly what I'm looking for. I just wanna get rid of or minimize the torque dip while keeping the car as stock as possible.
Sorry, car noob here. First time modding. Hence I'm hesitant to do anything outrageous haha.
If there's a better and/or cheaper option for getting rid of the torque dip, please let me know. I want to keep the stock tune.
nrevbay is offline
Old 03-20-2016, 06:27 PM   #2606
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Honestly, i would recommend a Stage 1 OFT tune first, Even though you don't want a tune haha....but the stage 1 tune improves the tq dip a little as well as increases power while keeping the stock noise levels.
If you want more after that, you can get the header and know your good to go because you can disable the CEL code manually if it decides to come on.
Anyways, that's my suggestion.
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline
Old 04-02-2016, 02:30 PM   #2607
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Is it normal to experience harsh vibrations in the cabin after installing these headers?
I finally came around to putting it on, i have the mootiv overpipe, berk catted front pipe and ARK DTS catback. The vibrations are really harsh throughout the cabin, the whole car vibrates during idle and acceleration. It feels like i changed cam profiles more than i changed headers.
I had the exact same set up without headers and overpipe for a long time and did not have any issues with vibrations.
I think i'm rubbing somewhere, perhaps with the overpipe, but clearance seemed fine when we installed everything, i will doublecheck soon but i am curious if such vibrations are common with this header. All the plastics won't stop rattling.
dem00n is offline
Old 04-02-2016, 02:57 PM   #2608
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Did you take into consideration the exhaust system leaning back a little bit under acceleration? Just something you can look into.
B-R-Z is offline
Old 04-02-2016, 06:14 PM   #2609
thriller
Drives: 2016 BRZ Limited Pure Red
I had the same problem when I installed this header a couple months ago with everything else stock. It was crazy noisy too. Turns out it was the head vibrating against the skid plate. I just had to bend the skid plate a little to make it bow down and fit without rubbing. Afterwards, it was as quiet as stock.
You may want to just pull the skid plate off and take a look around. If anything is rubbing, there will be some visible wear on both parts wherever it's happening.
thriller is offline
The Following User Says Thank You to thriller For This Useful Post:
dem00n (04-02-2016)
Old 04-02-2016, 08:26 PM   #2610
dem00n
dem00n's Avatar
Drives: Scion FRS
This makes good sense, i'll have a look again tomorrow.
Thanks.
dem00n is offline
Old 04-04-2016, 10:10 PM   #2611
nrevbay
Thanks.
hey, did you fix the issue? If so, how did you fix it?
nrevbay is offline
Old 04-04-2016, 11:29 PM   #2612
deuncos
Drives: AT Hot lava FRS
Originally Posted by STV3 View Post
Yep with no issues and car is still running strong.
@STV3 Are you running the canned OTS stage 2 tune or did you modify the stage 2 tune yourself in romradier?
deuncos is offline
Old 04-05-2016, 09:39 PM   #2613
dem00n
dem00n's Avatar
Drives: Scion FRS
I noticed that my undertray was bent and straightened it out the best i could. There's still some vibration but not as much. I'm going to double check the undertray later this week to see if i can fit it better.
The best way to diagnosis this problem that i was too stupid to do was to drive around without the undertray on and feel the vibrations.
Honestly, these cars are junked up already so i might as well go to a junkyard and get a fresh one. Mine was seriously beat, but this is 73k in miles so far...
dem00n is offline
The Following User Says Thank You to dem00n For This Useful Post:
FRSBRZGT86FAN (04-05-2016)
Old 06-22-2016, 03:11 PM   #2614
Leland
Drives: BRZ JDL uel headers oft Perrin 2.5
Hello. This is my first post on this forum. When I first read about these headers, I was sure that I wanted to get them but I thought that I would do a little research which this thread provided. Now after reading much of this thread, I am conflicted. I do want to minimize the torque dip. The only engine mods on my car are the Mishimoto intake tube and drop in afe intake dry filter. I do not want a cel, emissions issues or cracked headers to deal with down the road. Should I get these headers?
Leland is offline
Old 06-22-2016, 03:35 PM   #2615
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
It doesn't matter which header you get, if you get aftermarket header you won't pass emissions... unless you live in the state that require emissions.
If you ever get crack on their products, they'll replace it.
ichitaka05 is offline
Old 06-22-2016, 03:51 PM   #2616
Leland
Thank you for your response. I guess that I will just live with the torque dip. My previous car was a 2006 Z4 Coupe 3.0si which had plenty of torque so I really notice the lack.
Leland is offline
Old 06-22-2016, 03:57 PM   #2617
ichitaka05
Site Moderator
ichitaka05's Avatar
Tuning can help lil bit (very small amount) of tq dip. If corn gas (E85) are around your area, you can get flex fuel kit & tuned, that'll help even with stock exhaust system.
Old 06-22-2016, 04:03 PM   #2618
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
False.
If you live in a state where all they do is the OBD2 test you can pass pretty easily so long as your CEL is tuned off.
Summerwolf is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
