#995 | |
I'd request more info on why they think it's PCV and not something else before tearing everything apart. If I had a dollar for everytime a tuner asked me about PCV leaks, including Delicious I could buy an FI kit by now.
#996 | |
Drives: 2015 Raven FRS
#997 |
Anyone that has personally installed the Edelbrock supercharger on a automatic car will you please pm me.
#998 | |
Drives: 2013 FRS
My MAP shows .32 bar at warm idle, the throttle being at 13.7% and accelerator at 0%, and RPM at about 850. On cold start I get: .45 bar, throttle 15.3%, accelerator 0%, and about 950 RPM. Did you measure that with a warm engine or cold? and what was the RPM/throttle% at that time? I assume you were in neutral? I have a manual, but I bet the values will be similar at the same RPM/throttle. |
#999 | |
Drives: 2013 SWP BRZ Limited
I know for sure 300whp is where the fueling and clutch fall off, because that's about where I'm at right now. I figured there was still some room before a built motor was needed. |
| The Following User Says Thank You to jwvand02 For This Useful Post: | CSG Mike (03-17-2016) |
#1000 |
Drives: 2014 Porsche Cayman S
So, I went for it and got the Edelbrock installed by Neal at The Racer's Line this week and the install went perfectly. No issues to report and a 630 mile road trip the next day.
Note this is a stock vehicle and so the install was not complicated by other factors. Some have asked for driving impressions, so here goes... It does drive like stock with a bigger engine...that description is very apt. The power comes in with a surge and not a thump, but plenty there. The idle does act a little weird when cold, but no stalls and it calms down fairly quickly. There is a little dead zone on accelerator travel, but nothing my brain cannot figure out and just give a little more gas. Overall, I am very pleased as it matches my expectations and is a blast to drive. The issues mentioned above are small...very small. I agree with comments that this is the one to get for the money...incredibly professional kit, easy install and I foresee little maintenance, which for me (trust me) is a blessing.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
| The Following 6 Users Say Thank You to paiceyfan For This Useful Post: | 86 South Africa (03-20-2016), BigFatFlip (03-17-2016), MicheleAbbate (03-17-2016), Nitro22 (03-17-2016), The Racers Line (03-17-2016), TOLM (12-27-2017) |
#1001 | |
#1002 |
Drives: anything you let me
#1004 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Put car on "Acc", press the gas pedal to the floor about 5 time, start car and let idle for a few mins. The nice thing with this kit, my freeway gas mileage is roughly the same as stock (29-30 mpgs, used to be ~32 mpg). Wish I could say the same for city driving
#1005 | |
Drives: 2013 FRS
Looks like the same as my manual car at 950 RPMs, around .45 bar. I would think something like the fuel trims would be abnormal, since it would have extra air at idle if there was a leak and have to compensate by adding fuel. The bouncing idle certainly is a very common air leak issue, I've had it many times in other cars due to leaks. Maybe the manifold pressure isn't the best way to determine if you have a leak... |
#1006 |
Also my milage has gone to shit. Everyday driving 12 mpg.
#1007 |
#1008 |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
