#253 | |
My last 4 modern cars (a DSM and 3 Mitsus) were all traded in at around 300K miles and still all had perfectly functioning clutches. I do not drive "sensible" all the time but don't beat the crap out of my clutch and tranny either.
#254 | |
Auto owners ideas of a "clutch". ![]() ![]()
| The Following User Says Thank You to Tcoat For This Useful Post: | soulreapersteve (03-15-2016) |
#255 |
Best description ever!
| The Following User Says Thank You to Tcoat For This Useful Post: | lukey86 (03-15-2016) |
#256 | |
People have the same thoughts about engine braking. "You are putting strain on it". The strain of braking revs is worse that the strain of acceleration revs? How does that work?
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (03-15-2016) |
#257 |
Drives: Corn Juice junkie
Wow, a hilariously satisfying read, this one. 16 Pages, that is commitment to the craft(s), humor and driving
| The Following User Says Thank You to seito23 For This Useful Post: | Tcoat (03-15-2016) |
#258 | |
| The Following User Says Thank You to Riftur For This Useful Post: | Tcoat (03-15-2016) |
#259 | |
Drives: 86
While it does wear due to more use in a general sense, if you engage the clutch when the input/output shafts are in sync, the wear will be negligible whether the shifting is up or down. |
#260 | |
So by not downshifting you save a day on your clutch's life then. Not the "go through clutches much faster" you said before. The whole "brakes are cheaper than clutches" things is just plain silly since both are wear items but the clutch should outlast the brakes by many times over if you don't abuse it.
#261 | |
I went through 2 clutches on my 93 Mustang GT in 5 years. |
#262 | |
Drives: Nevermorange FRS
Most folks aren't rev matching or double clutching, therefore on a downshift the clutch is speeding up an engine, whereas on an upshift it's slowing it down. The friction disk is being applied to retard or accelerate what is essentially a compressor. The requirement in force to slow down an off-throttle engine is much less than to accelerate one. To compound this, on a down shift, the clutch re-engagement is generally slower for your typical driver so the delta between where the revs are when the clutch is disengaged to where the revs are when the clutch is re-engaged is greater, aka: even more work.
PRO86 | WTCC | STL
| The Following 3 Users Say Thank You to rice_classic For This Useful Post: |
#263 |
Benched 86lb
Drives: Ultramarine FR-S
LOL, I remember this epic thread. Glad to see the opinions are still trickling in.
Here's what the 1992 Ford F-Series owner's manual has to say about all this:
#264 | |
Most of my younger day cars fell apart around me and left a perfectly good clutch laying on the ground! Strangely enough the two most powerful vehicles I had were autos (full Hurst shift kits of course) though.
| The Following User Says Thank You to Tcoat For This Useful Post: | Riftur (03-15-2016) |
#265 |
So the moral of the story and 16 pages is:
You can do it wrong, or you can do it right and there's more than one way to do either. edit: who cares.. our Throw out bearings will fail every 50k anyway. Just replace your clutch then.
PRO86 | WTCC | STL
#266 |
| Tags |
| kr-s is colorblind |
| Show us your Custom Roll Cage or Roll Bar and Harness Setup | Black Tire | Tracking / Autocross / HPDE / Drifting | 27 | 02-13-2015 09:59 PM |
| downshift to first | swpbrz | Engine, Exhaust, Transmission | 13 | 05-07-2014 08:33 PM |
| Has anyone actually seen any of the Cusco roll bar / roll cages installed? | xenocharger | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 06-03-2013 06:54 PM |
| Car rattle at neutral. | IloveBaldEagles | Issues | Warranty | Recalls / TSB | 3 | 12-23-2012 06:55 PM |
| Roll stiffness: Springs vs anti-roll bars? | Captain Snooze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 07-24-2012 05:44 PM |
