Old 03-15-2016, 02:28 PM   #211
Celica00
Celica00's Avatar
Drives: 86
Update: I can now successfully rev match downshift with minimal issues. Turns out, what I was doing to down shift was pretty much held the accelerator where it would need to be and then dump the clutch. Which is fine if I'm planning on speeding up but doesn't help in slowing down.
However, how do you effectively roll from gear 6 to gear 1 to neutral as you near a stop? I haven't found an effective way to do this. I'm assuming this is where heel-toe comes into play. At which case, is it toe to throttle or heel to throttle?
Celica00 is offline   Reply With Quote
Old 03-15-2016, 02:38 PM   #212
Ashikabi
Ashikabi's Avatar
You shouldn't be using heel toe if you're stopping. You heel toe to maintain high rpm while slowing down so you can better accelerate or for managing a drift. If you stop it's pointless. Just keep down shifting until you are going really slow
Old 03-15-2016, 02:42 PM   #213
Celica00
Celica00's Avatar
Drives: 86
My issue I've found with that is that the person behind you has to deal with your flashing brake light due to the switch from braking to blipping as you roll down the gears. does that come with the territory and regular motorists will just think you're a semi-handicapped person?
Old 03-15-2016, 02:43 PM   #214
Blip gas down shift, blip gas downshift, blip gas down shift.
You are thinking it is harder than it is. No heel toe is required (I have never heel toed in my life). I row through all the gears on my way down for every slow down (unless a panic stop of course) and rarely even touch the brakes until 2nd gear.
This of course is day to day driving and track requirements will vary.
Old 03-15-2016, 02:46 PM   #215
Ashikabi
Ashikabi's Avatar
If you slip the clutch a little more you won't need to blip the throttle. Or put it in a lower gear and just hold the clutch all the way in until you reach a good speed. Then if there is an emergency you can just floor it and drop the clutch. I dunno, I just neutral roll to stop but I like to live dangerously
The Following User Says Thank You to Ashikabi For This Useful Post:
Celica00 (03-15-2016)
Old 03-15-2016, 02:55 PM   #216
Celica00
Celica00's Avatar
Drives: 86
How long do you allow your car to engine brake inbetween gears? I find myself going too quickly and end up with 2nd gear revving at like 5k RPM
Brilliant! I never knew pink-haired anime girls were so helpful
Old 03-15-2016, 02:59 PM   #217
Ashikabi
Ashikabi's Avatar
Look man, no need to be facetious, I was trying to help
Old 03-15-2016, 03:00 PM   #218
Celica00
Celica00's Avatar
Drives: 86
Oh no intention to offend. More like good hearted fun. I really do appreciate your info. I've learned quite a bit already
Old 03-15-2016, 03:07 PM   #219
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Gear 6 to 1 puts unnecessary strain on the car. Down shift 6 to 5 to 4 then 3 to 1.
I do 6 to 5 then 4 then 2 and none.
Old 03-15-2016, 03:09 PM   #220
Ashikabi
Ashikabi's Avatar
It's cool, I was half playing too. Unless you're being a total douche I'm super easy to get along with. Mainly here for the lulz
Old 03-15-2016, 03:12 PM   #221
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
OP: I think your over thinking this. Do what is natural. Blipping isn't really necessary. With experience you'll discover the proper speeds to shift up and down.
I'm with Ashi. I tend to get lazy and just coast into a stop. I know. Improper technique.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
Braces is offline   Reply With Quote
Old 03-15-2016, 03:12 PM   #222
Not long. I can't really say X amount as it depends on how fast I want to slow down, what the conditions are, etc. I have been doing it for so long I just sort of do it and don't pay much attention.
Old 03-15-2016, 03:14 PM   #223
Celica00
Celica00's Avatar
Drives: 86
I worded that strangely but I don't go from 6th gear straight to 1st. But it's good to know I can skip a gear here and there.
I've been called a loveable douche before so I guess my humor can seem like a **** sometimes.
Old 03-15-2016, 03:17 PM   #224
I think he meant going all the way through each gear. At least that was how I read it. Doing 6 to 1 is a very, very, very bad idea!
kr-s is colorblind
Show us your Custom Roll Cage or Roll Bar and Harness Setup Black Tire Tracking / Autocross / HPDE / Drifting 27 02-13-2015 10:59 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 09:33 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 07:54 PM
Car rattle at neutral. IloveBaldEagles Issues | Warranty | Recalls / TSB 3 12-23-2012 07:55 PM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 06:44 PM
