Old 03-14-2016, 06:36 AM   #1
TCR
Drives: 2013 Toyota 86 GT
Airbag Wiring connector
Can anyone tell me how to disconnect the wiring plug on the end of this deployed airbag?
TCR is offline   Reply With Quote
Old 03-14-2016, 07:04 AM   #2
Fricke
Drives: Toyota GT86
Djust stick a small flathead screwdriver in the slits between the yellow tab and the black plug, and then push the yellow tab upp, after that you can pull it off
Fricke is offline   Reply With Quote
The Following 2 Users Say Thank You to Fricke For This Useful Post:
bmacfrs (01-27-2020), TCR (03-14-2016)
Old 03-14-2016, 07:41 AM   #3
TCR
Thanks, will give it a go.
Old 03-18-2016, 02:39 PM   #4
Peaty
Scooby***s Guy
Peaty's Avatar
Drives: 2019 Impreza Sport - MT
Very similar to the attached pics, from my steering wheel install page here:
http://www.scoobymods.com/showthread...76.html?t=4876
Before you unplug or work with anything SRS related, be sure to disconnect the battery wait a few minutes and I like to step on the brake. You want to be sure all the power is out of the system. It's probably not a good idea to pet the cat right before doing too
Peaty is offline   Reply With Quote
Old 03-20-2016, 03:11 PM   #5
thatfrskid
Drives: 2015 Scion FR-S in Asphalt Grey
So I have a related question... how do you over ride those plugs? Small resistor?
thatfrskid is offline   Reply With Quote
WTB: 86 Airbag cover, no airbag needed stevesnj Australia Classifieds 0 02-18-2016 10:17 PM
WTB: BRZ or 10 series/monogram 8 pin connector + length of wiring harness NahumCC Want-To-Buy Requests 4 02-18-2016 06:08 PM
WTB: FRS oem driver airbag, clock spring, both front seat belts, airbag module 14_GT86 Want-To-Buy Requests 3 04-01-2015 01:26 AM
WTB Passenger Curtain Airbag + Wheel Airbag markkisl Want-To-Buy Requests 4 08-26-2014 02:16 AM
Side Marker wiring connector IAMTHEWG Cosmetic Modification (Interior/Exterior/Lighting) 0 03-08-2014 08:08 PM
