Old 03-11-2016, 03:06 PM   #1709
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
255/40 is doable, i just think its a bit too big of a sidewall especially on an 18inch rim.
in that case go 17x9.5 +40 or 17x9 +35 with a 255/40/17
Jive Turkey is offline   Reply With Quote
Old 03-11-2016, 04:18 PM   #1710
sqd
sqd's Avatar
Drives: '13 SWP GT86
Originally Posted by Mindsucker View Post
No I won't but you're welcome to drop by and pick it up on your way down
Just let me know when you're passing Stockholm so we can meet up
Will do!
Eh, I like it personally, but I'll most likely go 255/35. Wheels are already on their way so no changing that by now
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 03-13-2016, 11:27 PM   #1711
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
Originally Posted by yomny View Post
Thanks man, it's actually about 1" exactly, may seem lower because of the fatties lol. But I actually raised it about 1/8" on all 4 corners after those pics. Rides nice, re aligned it and I have 1.5 up front and 2.5 rear camber all natura(well front struts are slotted, maxed). I need to get control arms and top hats to get those numbers a bit better.
how much did raising it 1/8 inch affect the toe?
spicyricecake is offline   Reply With Quote
Old 03-14-2016, 12:51 AM   #1712
evo8jpp
evo8jpp's Avatar
Drives: FR-S, WRX
Just contributing to the thread from CO. Volk TE37SLs wrapped in 255/35/18
evo8jpp is offline   Reply With Quote
The Following 3 Users Say Thank You to evo8jpp For This Useful Post:
CrispyCheddar (03-14-2016), Metabrz (03-16-2016), Rican_D (03-14-2016)
Old 03-14-2016, 12:57 AM   #1713
s2d4
s2d4's Avatar
That look like it's on the skinny side.
Old 03-14-2016, 03:58 AM   #1714
secret.squirrel
secret.squirrel's Avatar
Drives: GT86
I think I just did a sex wee
secret.squirrel is offline   Reply With Quote
Old 03-16-2016, 01:14 AM   #1715
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Originally Posted by ATL BRZ View Post
Grand Meat Master Jive hath spoken and a new era of 245 tire acceptance for meaty consideration has begun!
Allow me to welcome myself into your midst of meat.
17x9 +42 Mach V Awesome's
245/40/17 Bridgestone RE-11A
Compared to stock: no stretch, no bulge, 100% lean meat.
Whiteline top mounts add enough negative camber for safe OEM lower spring perch clearance.
Lowered 22mm on RCE Yellows. No rub on and off track.
Sorry to quote such an old post... If you had an alignment done, do you know how much camber the top hats were good for? Did you combine them with OEM crash bolts/SPC/Whiteline with no rub?
Joe-G is offline   Reply With Quote
The Following User Says Thank You to Joe-G For This Useful Post:
slow15frs (03-18-2016)
Old 03-16-2016, 11:10 AM   #1716
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
-1.4 degrees camber in front. No camber bolts.
Old 03-22-2016, 11:46 PM   #1717
Njjawn
Drives: None
Quick test fit. 18x9.5 57dr wrapped in 265/35 Yokohama ad08r.
Rubs in the rear, gonna need some more camber (only about 2* right now).
Njjawn is offline   Reply With Quote
The Following 5 Users Say Thank You to Njjawn For This Useful Post:
DuMa (03-24-2016), Hicklinc (02-26-2018), Jive Turkey (03-26-2016), Joe-G (03-24-2016), swarb (03-23-2016)
Old 03-26-2016, 12:00 PM   #1718
Jive Turkey
the tuna, no crust.
i see you're not rolled in the rear. that will give you more room than you think-those ad08's run FAT. trim the rear bumper tab too-or the tire will do it for you.
i just dialed in my car for this season-i'm running a 265/35 MPSS on a 18x9.5 +40 still.
i have NO gap all around this time around, i wanted to see how tight a fitment i can get away with while being functional-so my final specs are -1.8 in the rear (still have clearance) and -2.2 in the front (but in the front i have so much room i am running that much camber for performance reasons).
dont forget to toe in the rear about .08 per corner (.16 total toe in rear). This will make it feel much more stable at higher speeds.
then toe out the front ever so slightly, car will feel wonderful turning in (-.1 total toe front/ -.05 per corner)
The Following User Says Thank You to Jive Turkey For This Useful Post:
Old 03-26-2016, 12:42 PM   #1719
Irace86
Drives: BRZ + Ducati M796
235/40zr18 7.5 +38
265/35zr18 8.75 + 33
No rubbing. Will be dropping an inch on eibach pros
Irace86 is offline   Reply With Quote
Old 03-27-2016, 02:02 AM   #1720
Njjawn
Drives: None
Might have to stop by azp and have then take care of rolling the fenders/alignment. I'm scared to roll these fenders myself, tbh. As you know, my solution has always been "more camber" (lol). I wanna get these to fit without loosing any performance obviously. We gotta meet up again sometime man, and you gotta teach me the ways of this car.
Old 03-27-2016, 02:54 AM   #1721
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Mmmmm meat...
The Following 2 Users Say Thank You to Joe-G For This Useful Post:
Hicklinc (02-26-2018), PeterFRS (03-29-2016)
Old 03-27-2016, 03:24 AM   #1722
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Mounted! So meaty, on the 9, its like its pinched!
Hicklinc (02-26-2018), NABoxer (04-25-2016)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
