#1121 | |
Drives: Supra, BRZ
Interested.... if still avail. Can pick up today.
1997 Toyota Supra TT 6MT - RR
2014 Subaru BRZ Limited 6MT - WRB |
#1122 |
Drives: 2013 FRS, with boost by ATS Racing
#1124 |
Drives: 2015 Raven FRS
Anyone selling any after market wheels ?
Local in dfw |
#1125 |
Drives: 2013 Raven FRS(Sold): Fiesta ST
#1126 |
Drives: 2020 BRZ PP
OEM header, GS header gaskets, OEM oil filter.
![]() OEM header $75 OBO ![]() Grimmspeed Header and overpipe gaskets NIB $25 ![]() OEM oil filter and crush washer $5 Located in NRH. PM me for contact info. Also have stock intake if anyone is interested. |
#1127 |
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
@Griever423
Gaskets please sent pm. |
#1128 |
#1129 |
Drives: None
#1130 |
#1132 |
Drives: 2017 Halo Toyota 86
Seibon FA Hood for sale 400.00
Sold
previous build thread!
http://www.ft86club.com/forums/showt...236#post962236 Last edited by 20firestorm13; 03-14-2016 at 07:05 PM. |
#1133 |
Drives: '13 BRZ
Custom ~470whp+ capable turbo setup - $6000 OBO
** No shipping, will meet halfway around DFW ** Going a different route with the car so selling my current turbo setup. About 3,000 miles on everything. Made 470whp on e85 @ 19psi (dyno attached), and could easily do a little more. Turned down is about 370whp on e85 @ 15psi, and 300whp on 93 @ 10psi. We had a weird torque dip issue which was also apparent when I was running an e85 OFT tune. I've attached my old e85 tune on the same dyno. Still not sure what exactly was causing this, but it wasn't able to be tuned out. At this point I fully believe it was something mechanical with my motor, as I had the worst torque dip out of everyone at the ATS dyno day last year, but made the best peak e85 power N/A, so who knows. Started with a CX kit as a base and worked with Rob @ ATS Racing to get all the crap stuff fixed / replaced. Exhaust was finished up with a custom 3" cat-back to complete the 3" catless setup. Downpipe was tweaked and we switched out the 5 bolt flange for v-band. Of course a much better turbo as well. Almost everything you need to bolt on a turbo and make over 400whp is right here. The only thing you need is a tuning solution. If you are using Ecutek I can provide you with a base map to get the car driveable once you install everything (you will still need a dyno tune before beating on the car much). Everything else you need is in this kit, including the full 3" exhaust. I would recommend replacing the BOV however as it is a cheap knock-off tial. I had a Greddy FV BOV but have sold it separately already. Looking to sell everything as a kit so currently won't part with anything else separately. Full list below. Let me know if you want additional pictures of anything. Parts list: * Precision Ball Bearing PTE 5558 w/ billet wheel & ceramic coated turbine housing * Black turbo blanket * Oil feed / return lines * Pre-tapped oil pan for the return line * Tial 38mm wastegate w/ CX open dump tube. 10psi spring * CX Racing BOV (tial knockoff, recommend getting a real BOV) * CX Racing Intercooler & charge pipes * CX Racing Turbo Manifold w/ heat wrap * CX Racing 3" Downpipe - w/ heat wrap * CX Racing 3" Front pipe * Custom 3" cat-back, dual exit to two 4.25" Borla tips * Custom 3" intake, routes behind front bumper * All exhaust and charge pipe clamps * ClutchMasters fx350 clutch & lightweight flywheel * ID1000 injectors w/ plug and play harnesses * DeatschWerks 265c fuel pump * Boost control solenoid w/ plug and play harness * Flex fuel sensor w/ blue ethanol content gauge, plug and play via rear o2 sensor input. * Omni 4bar MAP sensor * Radium Dual Catch Cans * Drift Armor crash bar, with custom intercooler mounts welded on. Also is used for the air filter bracket for support. Recently sanded down to get the rust off and painted satin black (picture posted, no pics on car). If you don't want this, the intercooler is "supposed" to bolt right in to the factory crash bar using unused holes. Never tried, but that is how CX set up the kit. The mounts welded on the drift armor bar closely line up with where its supposed to mount on the factory crash bar so you should be able to swap if needed. * Defi Racer blue boost gauge * Innovate wideband. The sensor needs to be replaced and can be picked up for $60-80. It can be used temporarily, just clean and recalibrate it before installing. * Pillar gauge pod. Slightly melted from sitting in the sun before it was installed. This one is thrown in free. ![]() ![]() ![]() ![]() e85 N/A results, same dyno, same car: ![]() ![]()
| The Following User Says Thank You to BRZoomTX For This Useful Post: | Astroboy (03-29-2016) |
#1134 |
Drives: Still deciding
Texas: For Sale Thread
Alright, unfortunately I had to say goodbye to the BRZ this month. IT was flipped and totaled in an accident by a friend driving it.
Lesson learned, dont like friends drive your car. But my loss is your gain. JDL Ultra quiet front pipe - 300 https://jdlautodesign.net/shop/ft86-...et-front-pipe/ I also had the OFT and Shiv dino tuned my car when he was in town and it produced 188whp. He now provides an off the shelf jdl map and i anticipate it gets you right at where I was or pretty dang close. All are in great shape. I can send pictures at request or I will see if I can get them posted up here. Thanks! Last edited by jph11; 03-17-2016 at 12:32 AM. |
| Official BRZ / FR-S TEXAS Spotted Thread | Texas BRZ | Southwest | 1986 | 06-06-2025 01:37 AM |
| North Texas Autocross Thread | nlamon33 | Southwest | 643 | 01-13-2019 09:40 PM |
| Texas Job Hunting/Networking Thread | nlamon33 | Southwest | 41 | 10-29-2014 06:02 AM |
| another texas front LP thread... | zaptorque | Southwest | 34 | 10-22-2013 06:06 PM |
| Central Texas Thread | HillCountryGuru | Southwest | 5 | 03-05-2013 10:46 AM |
