Old 03-10-2016, 10:14 AM   #29
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Black is gps I think, curious about blue (or vise Versa). Antenna is white 1 next to blue
lbroskee is offline   Reply With Quote
The Following User Says Thank You to lbroskee For This Useful Post:
p1l0t (03-10-2016)
Old 03-10-2016, 10:16 AM   #30
p1l0t
p1l0t's Avatar
In hindsight (I went in a different order) this bottom plate should be the first thing to remove (if you really want to take your factory radio apart which I don't recommend at all). It is just 3 screws and then you can switch to a flat head to pop it off like the picture below.
Next you can take off the back plate if you want although there is little reward for doing so, you don't really get to see much you can't already.
This is kind of a blurry picture of the S/N on the back plate I believe it's 313-2194-02
Old 03-10-2016, 10:24 AM   #31
p1l0t
p1l0t's Avatar
The face plate is held on by these two screws and some plastic clips that are easy to see around the outside. They come up with gentle pressure as well no need to go crazy.
Once 'off' you'll notice it's still held on by a few cables. The smallest one pulls out with just gentle pressue no clips or anything. The largest orange/copper colored one you have to lift up the black clip to get it off. Same thing with the white cable but you will want to remove on the faceplate side rather than the radio side.
Clip on, clip off...
When you put these guys back on later you will want to make sure that the little tiny ass tabs on the cables are in the little spot on the clip like so..
Then just press the black clip down gently. This particular picture is actually not the one from the faceplate it's the one that connects the two main boards it's just for example.
Old 03-10-2016, 10:35 AM   #32
p1l0t
p1l0t's Avatar
The two at the bottom of this picture (front of the radio) connect to the faceplate. The one on the side connects the boards.
This shows two of the three cables after the are removed and the serial number of the faceplate board.
With the faceplate off you can see the third white cable that connects to it and the serial number of the bottom board (upsidedown sorry) it's 83BZLRO1039. I THINK the first O is an O and not a 0 as it doesn't have the line through it like the other.
Unfortunately they soldered one of the screws on the bottom board. So I didn't get the radio ENTIRELY apart this time. Although I did manage what I was comfortable with and still got it back together and it still works.
My hypothesis is that this guy is the main memory piece but it's a guess, it could be an XM attachment who knows I'll be googling some serial numbers and doing some manufacturer searches and inquiries to try and find out some more information in the coming days. I'm disappointed I didn't find like an SD card or something I could just tear though on my linux machine and start on the programming already but all these serial/part/model numbers will hopefully lead me to more information.
Old 03-10-2016, 12:25 PM   #33
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
This happens to be the only post I read, just popped in quick but if you want to run waze look into the Ca-Fi headunit. I run waze on that and love it
This is pretty much the solution you're looking for. I'd run it myself but I don't like the low hardware specs.
Luftwaffel is offline   Reply With Quote
The Following 2 Users Say Thank You to Luftwaffel For This Useful Post:
go_a_way1 (03-10-2016), p1l0t (03-10-2016)
Old 03-10-2016, 12:28 PM   #34
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yeah its midgrade at best. I am not a music guy so I dont care haha
p1l0t (03-10-2016)
Old 03-10-2016, 12:28 PM   #35
Luftwaffel
Boost Creep
Luftwaffel's Avatar
How the fuck did they manage to do that? Someone was drunk.
The Following User Says Thank You to Luftwaffel For This Useful Post:
p1l0t (03-10-2016)
Old 03-10-2016, 12:35 PM   #36
Luftwaffel
Boost Creep
Luftwaffel's Avatar
I'm honestly not sure of its audio chops, really. That can all be fixed with a USB DAC piped over to an amp anyway. What I really want is something with 2GB+ memory and a Snapdragon 800 series or comparable proc with at minimum a 1080p resolution. If they're building this, they can build that. Anything else is a compromise.
I'll probably end up going full retard and building another PC to accomplish my goals.
Old 03-10-2016, 01:07 PM   #37
p1l0t
p1l0t's Avatar
I hear that's a widespread problem among Japanese factory workers... (but who knows maybe that piece was built in China)
Old 03-10-2016, 02:02 PM   #38
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
So... Does the 2016 Hyperblue radio have RCA outs for a sub?
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 03-10-2016, 02:23 PM   #39
lbroskee
lbroskee's Avatar
no. only the 2 original radios for the FRS did
these 2:
http://image.automotive.com/f/scion-...ad-unitjpg.jpg
http://www.ft86club.com/forums/attac...6&d=1343093876
Old 03-10-2016, 03:11 PM   #40
p1l0t
p1l0t's Avatar
Originally Posted by lbroskee View Post
Yeah sorry Hyper
Old 03-10-2016, 07:04 PM   #41
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Ugh. I want to add a sub w/o using an LOC, and I want to use a stock head unit, but it's not worth downgrading to the FRS HU. LOC it is...
Old 03-14-2016, 02:36 PM   #42
p1l0t
p1l0t's Avatar
We appreciate you taking the time to email us.* These types of solutions are not possible to incorporate in your vehicle.* I will be sure to document this information as feedback in our database.
- Subaru of America
EL. OH. EL.
I followed up by asking them what OS it uses... I'm sure they'll have a good answer for that... next step is try a bootable USB or CD with linux on it. You never know..
clarion, starlink, subaru, technical
2013 BRZ Nav Stereo For 2016 BRZ Starlink Stereo brzsubarusti13 Audio/Visual, Electronics, Infotainment, NAV 11 02-27-2016 06:33 AM
Starlink and Navigation SPCorBUST BRZ First-Gen (2012+) — General Topics 8 01-18-2016 02:47 AM
2015 BRZ and Subaru Starlink system Ben_G BRZ First-Gen (2012+) — General Topics 3 01-19-2015 06:09 PM
Subaru Starlink for 2014 Models Bristecom Electronics | Audio | NAV | Infotainment 1 01-08-2013 04:25 AM
Subaru BRZ - RAW Subaru | Official Subaru Australia Ad Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 15 07-20-2012 08:20 AM
