| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Not a troll
Project Kics 3mm Spacers
Tried searching, couldn't find much info.
So, some quick backstory here, I recently purchased 17x9+35 wheels and 245/40 tires. They fit really well, apart from some slight rubbing on the front spring. My suspension set-up: Stock struts with Tein S-Tech springs, SPC LCAs and camber bolts and SilverProject top hats. I currently have camber right around -2.5 up front and -2 in the rear. Ideally, I don't want to have to get another alignment if I can get away with using a 3mm slip on spacer. What I want to know is, has anyone used a small spacer before and had any ill effects? With the price of the spacer, it's a lot less than getting an alignment, but if it's going to be detrimental, I'll do the alignment. I guess the other option is to dial back the camber a bit, but again, rather not do that if I don't have to |
#2 |
Drives: 2014 Scion FRS (Asphalt)
You should be totally fine with a 3mm spacer. You'll only run into problems if you use gigantic spacers... but that's another story.
| The Following User Says Thank You to tyler_win_photo For This Useful Post: | Cole (03-05-2016) |
#3 |
PM @CounterSpace Garage for spacers.
#4 | |
Proud of BOXER
Drives: Subaru Boxer
Been using these in front for a few years with no issues:
http://www.amazon.com/5x100-Hubcentr...7233220&sr=8-2
| The Following User Says Thank You to Clipdat For This Useful Post: | Cole (03-05-2016) |
#5 |
Not a troll
Ended up going with the Kics.
@CSG Mike couldn't justify buying from an American company when I found what I wanted from a Canadian company at an extremely competitive price. Plus this way I know that I won't get hit with extra fees on delivery |
#6 |
If you ever need spacers again, look up Novustech. They're a local company (based out of the Kitchener area).
You'll be fine with a 3mm spacer, the only other option would be to back off the camber at the knuckle and add more at the top mount.
| The Following User Says Thank You to wparsons For This Useful Post: | Cole (03-06-2016) |
#7 | |
Not a troll
Just checked out Novustech real quick, they only go down to 5mm. I probably could have went with something custom from them, but I'd like for it to not start costing a lot of money |
| The Following User Says Thank You to Cole For This Useful Post: | wparsons (03-06-2016) |
| Project kics conversion spacers | Kwise1 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-25-2014 01:17 AM |
| Project Kics 5x100 to 5x114.3 Conversion Spacers 11mm | smellslikecurry | Brakes, Suspension, Chassis | 0 | 08-22-2014 03:34 PM |
| FS project kics 11mm wheel adapters/spacers | mikey_BRZ | Wheels and Tires | 4 | 02-12-2014 11:59 AM |
| Discover over 50% in savings on these two Project Kics Spacers (Sold in Pairs) | FRSport.com | Announcements, Contests, Giveaways | 2 | 01-16-2014 05:16 AM |
| Wheels Spacers: Ichiba / Kics Project / FIC / H&R / Altrac | Touge Factory | Wheels and Tires | 6 | 11-20-2012 01:37 PM |
