Old 02-26-2016, 07:27 PM   #15
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Originally Posted by KoolBRZ View Post
Can you post a video with sound? It could have something to do with your tune or exhaust system. A restricted Cat, or leaky gasket could be affecting it.
It's not sound related, it's just that the car surges forward when coming to a stop. I'm not adding gas either, only brakes.
N1rve
Old 02-27-2016, 03:23 AM   #16
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
what do the revs do when you downshift? just the normal blip or anything extra? do you have a bluetooth obd to log rpm and speed while testing this a few times?
Old 02-27-2016, 02:20 PM   #17
N1rve
N1rve's Avatar
I don't have a bluetooth OBD unfortunately, but let me try to describe the best I can so you can replicate this (maybe?).
You're at 35 MPH, 2nd gear at around 3000-4000 RPM, approaching a red light that's 5 car lengths away. Cute girl on the right side of the sidewalk, shift into 1st gear, car blips, revs up to around 5000 RPM and you brake while coming to the light, the girl gives you the 'wtf, what an asshole look". Now as you're at around 10 MPH with your foot on the brake, as you think the car will come to a complete stop, the car surges forward again, like a jolt.
N1rve
Old 02-27-2016, 02:41 PM   #18
finch1750
finch1750's Avatar
You are trying to downshift going way too fast. Max speed in first is like 35-38mph (don't recall exactly) and the car will NOT let you downshift into max speed anyway as that is already redline. It is probably saving you from an overrev by not engaging right away but instead blipping and hanging the rpms until you slow down before engaging into gear
Basically don't downshift into first going so damn fast and you shouldn't have a problem.
Old 02-27-2016, 03:07 PM   #19
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I'll tell you exactly what it is. When you shift into first at that speed, you engage the lockup converter, and the surge you feel at 10 mph is when the TCU has to take pressure off the lockup converter in order to unlock it. Shifting into first at that speed is hard on the trans, and I wouldn't recommend it. 10 mph is when the speed of the car starts to slow down the engine below a preset point, so the TCU commands the lockup converter to disengage.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
The Following 8 Users Say Thank You to KoolBRZ For This Useful Post:
Demandred7 (03-10-2016), drewbot (03-16-2016), finch1750 (02-27-2016), golfyankee2121 (02-28-2016), N1rve (02-28-2016), new2subaru (02-28-2016), thecarfilmer (02-28-2016), TofuJoe (02-28-2016)
Old 02-28-2016, 10:37 AM   #20
golfyankee2121
Always Moving Forward
golfyankee2121's Avatar
Drives: 2013 Argento Scion FR-S
What he said^^^^^
Like everyone else, if I manually shift from 2nd into 1st at around 10 MPH while coming to a complete stop, the car surges a little bit. When I let the trans shift itself, I don't feel it nearly as much. This is exactly why I seldom manually shift into 1st gear.
IMHO, the only circumstance I could see it being necessary to shift from 2nd into 1st is if you're cruising at like 15-20 MPH in 2nd gear, and want to accelerate quickly, in which case, the car handles it perfectly and doesn't surge at all.
-J.B.
golfyankee2121 is offline   Reply With Quote
The Following 2 Users Say Thank You to golfyankee2121 For This Useful Post:
Demandred7 (03-10-2016), N1rve (02-28-2016)
Old 02-28-2016, 02:50 PM   #21
I bet it's just the engine coming back to life. Under engine braking fuel is completely cut. At around 1200-ish RPM (I don't remember exactly) injectors start ticking again and the engine surges a little.
MTs do it too.
N1rve (02-28-2016)
Old 02-28-2016, 05:30 PM   #22
Theratt1
Theratt1's Avatar
Drives: Blown engine
I have a gm truck with a heavily modified 4l60e with a lot higher than stock shift pressures. It does the same thing. It's a non issue. Every auto does it on the 2-1 shift. It's just more pronounced because the computer ups shift pressures in automanual mode.
Theratt1 is offline   Reply With Quote
The Following 2 Users Say Thank You to Theratt1 For This Useful Post:
Old 02-28-2016, 08:56 PM   #23
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
Patient: "Doctor, it hurts when I do this."
Doctor: "Don't do that."
I engine brake all the time with my AT, but not from 2nd to 1st.
TofuJoe is offline   Reply With Quote
Old 03-09-2016, 04:40 PM   #24
FT86.ca
Drives: '15 BRZ, '05 Acura TL
Hi All,
It's fine for your AT to downshift into 1st from 2nd IF (a big IF) your BRZ/FRS has a working "rev matching" feature.
If you downshift into 1st and the car feels like it's slowing down due to engine NOT blipping the throttle for you, it may be something like I experienced.
I even made a video about it to show the dealer. Note, the car will NOT let you downshift into 1st if you are going too fast in which your speed with exceed redline in the speed you are going.
In my situation, rev matching would stop after driving 30+ mins in "D" mode. To fix it temporary, I had to restart the engine.
I took my BRZ to the dealer yeasterday and showed them the video I made. They flashed new updated software to the TCM (Transmission Control Module) and so for so good it's fine.
Anyways here's the video. Is the engine "surge" you guys experiencing what I experienced as rev matching not working when downshifting? Hope this helps.
[ame="https://www.youtube.com/watch?v=AYN19T7ySVo"]BRZ Rev matching failure (Automatic 6 Speed 2015) - YouTube[/ame]
Skip to 1:00 where I start downshifting.
Vic
FT86.ca is offline   Reply With Quote
Old 03-16-2016, 11:24 PM   #25
Stevenuhh
Drives: 2015 FRS Firestorm
So my car started doing this also around 10mph whenever I'm slowing down. I'm just driving in its normal mode. Automatic. Right when I hit 10-11mph it surges and slows down abruptly
Stevenuhh is offline   Reply With Quote
Old 03-16-2016, 11:58 PM   #26
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Just because you can....doesn't mean you should.....
How many people downshift to 1st on MT when rolling to a stop? And I bet you it's just as rough feeling
drewbot is offline   Reply With Quote
Automatic Transmission Cooler infamous_s CANADA 7 10-22-2015 06:30 PM
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 10:42 PM
Automatic FRS Surge in Manual Mode N1rve Issues | Warranty | Recalls / TSB 5 02-08-2014 01:28 PM
Automatic Transmission :( Almighty Bob Southern California 14 11-06-2012 02:13 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
