go_a_way1
Old 02-18-2016, 07:52 PM   #3515
86Tony
Drives: 2015 AOZORA EDITION
question if i run a type 1s do i really need to add a front splitter?
86Tony is offline   Reply With Quote
Old 02-19-2016, 04:29 AM   #3516
CSG Mike
CSG Mike's Avatar
That depends on your balance preference, and your current suspension setup.
We have a few 1S available to ship immediately.
Old 02-20-2016, 01:41 AM   #3517
86Tony
I'm currently on kw 2 way clubs sport and running 255 re71r . Got people telling me I need a splitter but I'm not too sure. I know it's better to have just not sure if it's nessceray
Old 02-20-2016, 02:37 AM   #3518
CSG Mike
CSG Mike's Avatar
What spring rates are you on? Do you think your car understeers, oversteers, or is perfectly neutral?
Old 02-23-2016, 11:53 AM   #3519
TommyC
Drives: 2016 BRZ
The track wheels I bought are 17x8 with an offset of 50mm. I was going to add a 20mm spacer/adapter front and 30mm in the rear. Is there any disadvantage of using spacers on the track?
TommyC is offline   Reply With Quote
Old 02-23-2016, 03:16 PM   #3520
ka-t_240
In my mind, bolt on spacers just make one more thing you need to worry about and check. I like simple.
Some say spacers bring more stress to your wheel bearings as well, not sure if the spacer cause it or if the total offset of the wheel is the impact.
ka-t_240 is offline   Reply With Quote
Old 02-23-2016, 04:27 PM   #3521
CSG Mike
CSG Mike's Avatar
Adapter spacers give you multiple points of failure. You have to retorque both sets of lugnuts.
I recommend ARP extended studs, and blank spacers. You can stack spacers as you see fit this way.
Old 02-23-2016, 04:29 PM   #3522
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
No concern about loosing the hubcentric feature?
ineedyourdiddly
Old 02-23-2016, 04:31 PM   #3523
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
It's definitely not the spacer itself causing the wheel bearing stress, it's the resulting change in total offset.
I personally wouldn't run spacers on track because I like to keep things pretty simple, but if you don't mind doing a nut and bolt check on them before and after every event, go for it.
A lot of people will argue about the hub centric rings and they're 100% right that they don't support the wheel once the lugs are tight. I've had enough bad experiences trying to make wheels actually seat properly on the hub without them that I'll never run without them again. Wheels should self-center as you tighten the lugs but even a couple of thousandths of run-out can be noticeable and if you're not really careful to gradually tighten each lug nut using your fingertips to ensure it's seated a little bit at a time to let the conical seats do their job you're going to have a bad time.
The Following 3 Users Say Thank You to DocWalt For This Useful Post:
CSG Mike (02-23-2016), strat61caster (02-23-2016), Uplink (02-23-2016)
Old 02-23-2016, 04:35 PM   #3524
CSG Mike
CSG Mike's Avatar
None at all, as long as you torque your wheels carefully.
DocWalt (02-23-2016), strat61caster (02-23-2016)
Old 02-23-2016, 04:47 PM   #3525
strat61caster
I assume you mean what @DocWalt said above?
Many thanks!
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
CSG Mike (02-23-2016), DocWalt (02-23-2016)
Old 02-23-2016, 04:51 PM   #3526
CSG Mike
CSG Mike's Avatar
Ooops @DocWalt beat me to the punch. I get a lot of notifications so i open all of them and then answer them sequentially.... and sometimes that happens lol.
Old 02-23-2016, 04:52 PM   #3527
strat61caster
I won't complain about double confirmation.
ineedyourdiddly
Old 02-23-2016, 06:18 PM   #3528
Pat
Pat's Avatar
Drives: 2023 BRZ
I won't disagree with this. But I will share my personal experience. I have stopped using hubcentric rings and never have a problem. A friend of mine that used to race professionally does the same thing I do and has never had a problem. YMMV
The Following 2 Users Say Thank You to Pat For This Useful Post:
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
