Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
Drives: Subaru BRZ (soon?)
OEM Subaru BRZ connectors
Hello, i am in a process of professionally adapting Lenovo Phab Plus tablet as head-unit.
It will add my own charging, power sequencing, and other electronics to mimic original functionality only by using original tablet functions ( like turn on when car is accessory is turned on, but will not shutdown it by cranking the engine, like original does, basically, will use MCU to track car status, and generate signals for tablet. very simple My original problem, is that i must use original wiring loom, but i have no idea where i get same connectors ( PCB mounted, not wire), just like in original headunit ![]() So i need mail part that is PCB mounted, any idea about part numbers and/or digikey link ? And yes, i will be making DIY guide how to properly install tablet to car ![]() ![]() |
#2 |
Drives: Subaru BRZ '13 WRB
I think you will have to cut connectors, my friend
#3 | |
For power and seekers, i will use standard connectors, and buy adapter from ebay or local distributors, it should work just fine ![]() http://www.digikey.com/product-detai...207-ND/2273586 http://www.digikey.com/product-detai...707-ND/4813976 |
#4 |
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
A - USB
B - Rear Camera Pre-wire C - GPS Antenna D - 10-pin & 6 pin power/speaker harness E - 28 Pin SWC/aux/mic harness F - Antenna G - Sirius/XM antenna --kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
#5 |
Bring out your dead
Bump ^^^^
![]() --kC
#6 |
https://demos.starbase7.net/t3Portal...+2016+MY+FR-S+[05%2F2015+-+]&docid=989162&context=ti
Where to get OEM wiring connectors? | brianhj | Electronics | Audio | NAV | Infotainment | 8 | 02-01-2016 03:50 PM |
Subframe connectors? | zooki | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 12-24-2014 02:17 PM |
OEM Connectors | taylork057 | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 01-17-2014 01:00 PM |
Connectors in trunk | retoocs | BRZ First-Gen (2012+) -- General Topics | 4 | 07-26-2013 03:37 AM |
Oem amp connectors | cruzinbill | Electronics | Audio | NAV | Infotainment | 10 | 01-31-2013 05:47 PM |
