go_a_way1, MisterSheep
Old 02-19-2016, 12:51 PM   #13035
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Originally Posted by stevesnj View Post
It will fall out more. Mine did. Since the lifespan of these is the life of the car I used Loctite plastic epoxy across the base to the socket plastic. Been 8 months no issues.
Another option is you can bend some of the bulb contacts outward more. It will hold itself better in the socket.
dhuang is offline   Reply With Quote
Old 02-19-2016, 03:04 PM   #13036
kch
Senior Misanthrope
kch's Avatar
Flexy time
The Following 2 Users Say Thank You to kch For This Useful Post:
frsvr4 (02-19-2016), Lonewolf (02-19-2016)
Old 02-19-2016, 03:45 PM   #13037
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Originally Posted by NahumCC View Post
Fixed the OLM switchback that fell out. Really hope this doesn't become a regular occurrence.
And so while I was in there I went and changed the halogen bulbs over to the xenons and adjusted the aim of the fogs. Also managed to find 2 of the clips from the OEM fog light kit which popped off but am still short 3 and the dealership couldn't find them in the parts system.
Comparison of halogen in projector housing to the xenon in the other.
Both xenons in and beginning aim adjustment.
Now I just need to get my headlight bulbs to match .
Can you take a pic with just the foglights on?
Old 02-19-2016, 04:25 PM   #13038
stevesnj
stevesnj's Avatar
Tried that too, didn't work...for me at least
My 2016 Build thread
Old 02-19-2016, 05:08 PM   #13039
johan
Drives: '14 981CS, '99 NB1
Wrapped one of my A-pillars in Alcantara from Overland Designs. I don't usually do well with arts/crafts projects, but with some great advice from @Figo (thanks!) and a slow / steady approach - it turned out perfect. Super stoked.
Now I just have to do the other side lol.
johan is offline   Reply With Quote
The Following 3 Users Say Thank You to johan For This Useful Post:
Ammunition (02-19-2016), Figo (02-19-2016), zeal86 (02-19-2016)
Old 02-19-2016, 05:59 PM   #13040
NahumCC
Drives: 2013 FR-S 10 Series
No metal to the bulb contact. It's all molded plastics.
NahumCC is offline   Reply With Quote
Old 02-19-2016, 06:51 PM   #13041
stevesnj
stevesnj's Avatar
Were talking about the electrical contacts in the bulb socket that contacts the metal contacts on the bulb
Old 02-19-2016, 07:34 PM   #13042
NahumCC
Ok, got it. I thought you were talking about the xenon fogs as that's what I was more worried about. If the switchback falls out again I'll try that and see if it gets a snugger fit.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Old 02-19-2016, 09:15 PM   #13043
EINSTEIN562
EINSTEIN562's Avatar
Drives: 2017 Subaru BRZ
Participated in Round 1 of 86CUP at Streets, check out the video:
[ame]http://youtu.be/HoP2orFJMI0[/ame]
Ice Silver 2017 BRZ w/PP 6MT | Driver Mod |
EINSTEIN562 is offline   Reply With Quote
The Following User Says Thank You to EINSTEIN562 For This Useful Post:
Old 02-19-2016, 10:49 PM   #13044
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by trvth View Post
That looks really good. How hard was the install? And where did you source your Schroth?
Thanks! Attaching the harness to the rear seatbelt support was a royal pain in the ass, I won't lie lol. Rest of the install was pretty simple, just time consuming. I got it from soloracer.com.
Here are the photos of where the harness attaches in the rear. Getting the rear plastic interior cover off (and back on) was tough, as was getting the harness loop in there with the right spacers on it without losing everything.
Here you can see the harness attachment loop bolted underneath the seatbelt mount:
justinco is offline   Reply With Quote
The Following User Says Thank You to justinco For This Useful Post:
trvth (02-23-2016)
Old 02-19-2016, 10:56 PM   #13045
Brayden_23
Drives: Asphalt 2015 FRS
Installed my Intec high mount 3rd brake light! Just to tide me over until my Perrin CBE + OP and JDL UEL header come in..
Brayden_23 is offline   Reply With Quote
The Following User Says Thank You to Brayden_23 For This Useful Post:
zeal86 (02-19-2016)
Old 02-19-2016, 11:10 PM   #13046
NahumCC
Nope. The main body ECU won't turn the fogs on unless its powering the headlights.
Now a tech might be able to tell us whether that a change they can make with the shop computer interface.
Old 02-19-2016, 11:59 PM   #13047
zeal86
zeal86's Avatar
Drives:
If it bothers you any, this is what I did to conceal the bracket that supports the 3rd brake light.
Here is the stencil I created in Illustrator just in case you want to try it.
I purchased the sticky-back felt sheet at Michael's for $1.29.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
Old 02-20-2016, 12:29 AM   #13048
choiboie
Drives: 2013 Fr-S UltraMarine
Installed hotchkis springs finally.front sway endlinks were seized. Ended cutting them off. so I'm driving with no front sway attached 😕
Sent from my SM-G920V using Tapatalk
choiboie is offline   Reply With Quote
